SLOW BATTERY DRAIN | FerrariChat
SLOW BATTERY DRAIN
Discussion in '348/355' started by Waggntx, Apr 23, 2024.
  1. Waggntx
    Waggntx Rookie
    Mar 25, 2022
    36
    Alice Franke
    Replaced weak battery in 1999 355F1 spider. Attached battery tender via + and - sites in engine compartment. Without problems for 30 days during which car was started 3 times for 15 minutes/ea and driven once for 15 miles. Battery tender blinking "red" after 30 days indicated need to recharge with battery charger. After recharging, all was well with battery tender showing "green". Repeated 30 day period above and result was same; i.e. weakened battery charge requiring full recharge. What am I doing or not doing? Could my new battery be bad? Thanks in advance for your help.
  2. sfcarguy
    sfcarguy Formula Junior
    525
    Earth
    30 days is pretty normal for a Ferrari battery to discharge. I wouldn’t leave a new Ferrari off of a tender for more than 4 days.
    These cars just have a lot of parasitic draw. Maranello has bothered with optimization on this front.
  3. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,312
    Southern New Jersey Shore
    Phil
    The way I'm reading the original post, the OP is connecting the car to a tender.
    But to the engine compartment posts.
    OP, connect the tender directly to the battery. Pull the front passenger wheel, remove the battery cover, and install a "tail" (wire leads) from the battery up into the little cubby space where the a/c ports are. Then connect your tender to those leads and see if that makes a difference.
  4. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    Maybe the tender is shot?
    Rifledriver likes this.
  5. Waggntx
    Waggntx Rookie
    Mar 25, 2022
    36
    Alice Franke
    The battery tender was placed immediately after replacing the battery and left plugged in 24/7.
  6. Waggntx
    Waggntx Rookie
    Mar 25, 2022
    36
    Alice Franke
    If I can totally recharge the battery through the terminals in the engine compartment, then why would my battery tender hooked up to the same terminals not maintain the charge?
  7. sfcarguy
    525
    Earth
    Got it. Read your initial message wrong.
    What tender are you using?
  8. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,312
    Phil
    My guess - there's too much resistance between the engine compartment posts and the battery to enable a tender (trickle charger) to keep the battery adequately charged.
  9. Rifledriver
    37,089
    Id be surprised. If it cant handle 3 amps whats it doing with 80 or 90 from the alternator?
    Waggntx and sfcarguy like this.
  10. Rifledriver
    37,089
    This is not going to be resolved with internet guess work. Are you equipped and capable or interested to do a little serious electrical diagnosis?
    The battery should be load tested and the output from your tender should be tested for starters. Also the car needs to be tested for static parasitic draw.
    Also the alternator should be load tested. Alternators in 355 have a very real reliability issue. My rebuilding shop retired off what I paid him over the years rebuilding 355 alternators.
    Dominik B., steved033 and sfcarguy like this.
  11. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,721
    The car has a drain larger than the battery maintainer can supply.
  12. Qavion
    Qavion F1 World Champ
    14,268
    Ian Riddell
    Did you assume it was weak (through age/poor starting) or did a tech diagnose the issue? Was your old battery on the same tender before?
    I don't see an issue with using the engine bay terminals. It just means you can't charge your battery with the battery cutoff switch in OFF.
    The engine bay terminals are normally disturbed during engine outs. Did you check the terminals for security? Note that the starter and alternator are attached to the engine bay terminals. I think if you had an issue with these terminals, you'd have other problems.
    Note also that the engine bay terminals are attached to the battery bus terminals in the passenger footwell (behind the relay panel) and the battery (and rest of car) is attached to the passenger footwell terminals.
    It might be a good idea to invest in a cigarette lighter voltmeter so you can monitor your electrical system.
  13. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,051
    Atlanta, GA
    Steve D.
    Disconnect the positive, and read the amps by attaching a meter in series. If you see more than a whole amp, start pulling fuses to isolate the circuit that is causing the trouble.
    Got a window switch that's sticking?
  14. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,312
    Phil
    But doesn't that prove my point? 3 amps from the tender might not be enough to keep up with the parasitic drain of the radio, immobilizer, etc, and also charge the battery, or charge it enough. The alternator producing 80-90 amps can.
  15. Rifledriver
    37,089
    Except that was not your point. You mentioned resistance. You said nothing of a drain. Do you understand the difference?
  16. m.stojanovic
    m.stojanovic F1 Rookie
    3,219
    Serbia - Niš
    Miroljub Stojanovic
    The first thing I would do is disconnect one of the battery terminals and insert an ammeter (set at 10A range) to see if there is excessive parasitic drain. The same measurement can be done if the ammeter is connected to the terminals of the battery disconnect switch (while it is "off", of course).
    steved033 and Qavion like this.
  17. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    756
    Vermont
    john truskowski
    Just a "side question" for you. If you had a dead 355 alternator, who would you send it to for rebuilding? Knock-on-wood mine is currently OK (95 2.7) but it would be nice to know who to turn to if and when. Thanks.
  18. sfcarguy
    525
    Earth
    I would find a highly reputable local shop. A fair amount of these kinds of places are still around. Rebuilding a Ferrari alternator isn’t different from any other car and OEM parts are available (mostly).
  19. sfcarguy
    525
    Earth
    Well it looks like I spoke too soon because my local alternator/starter shop seems to have closed
  20. m.stojanovic
    3,219
    Serbia - Niš
    Miroljub Stojanovic
    Rebuilding a Denso alternator is very easy. The somewhat difficult part is getting the alternator out. After that, it's a 15 min. job if you have the parts ready (easy to get). The special tool required - a good Phillips screwdriver.
    sfcarguy likes this.
  21. jjtjr
    Aug 29, 2016
    756
    Vermont
    john truskowski
    Yeah, that is the likely route I would go anyway. Hunting down the complete kit (bearings, windings, etc) would be the bigger challenge in my opinion.
  22. cactussed
    cactussed Formula Junior
    Mar 12, 2008
    286
    It's tilting and rotating it to the exact angle it pops out of the subframe. It looks for all the world like it won't fit, and then somehow it just slips out effortlessly (fnarrr).
  23. steved033
    Apr 12, 2017
    10,051
    Atlanta, GA
    Steve D.
    If the car is pulling 3A when it's doing NOTHING, you have a problem, not just parasitic drain...
    IMO, nothing before 2000 should need a battery tender.
    sjd
  24. johnk...
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    My '85 308 QV will suck a battery down in a few weeks if not disconnected just on the drain from the clock. Been like that since new.
  25. steved033
    Apr 12, 2017
    10,051
    Atlanta, GA
    Steve D.
    #25 steved033, Apr 26, 2024
    Yeah, weeks, not days.... and not 3A worth. You've traced it to the clock?
    How much power does it pull? Have you measured?
    edit: consulting the internet, the average car battery has a capacity of 48 Amp-hour (Ah). so that's 48000 mAh (milliamp hours). There's 720 hours in a 30 day period... if i'm doing my math correctly, 48/720 is how many amps you're pulling if you're draining your battery in 30 days.... (.066A, or 66 mA)...which is a lot.
