SLOW BATTERY DRAIN | Page 2 | FerrariChat
SLOW BATTERY DRAIN
Discussion in '348/355' started by Waggntx, Apr 23, 2024.
  1. m.stojanovic
    m.stojanovic F1 Rookie
    3,303
    Serbia - Niš
    Miroljub Stojanovic
    We don't know what current is Alice's tender capable of providing, it could be just 1 amp or even less. If the battery "tender" can provide 3A, I would call it a (small) battery charger.
    steved033 likes this.
  2. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    494
    Victoria, B.C, Can.
    John Glen Wesanko
    I found on my 1990 348 the parasitic drain that was killing the battery was the "brain boxes" in the front of the center console. These two black boxes control the crazy mad mouse seat belts and are always "ON" when the battery is connected. I could hear a relay clunking when connecting the battery. Once I removed these units and converted the belts to manual the problem was eliminated.
    308 GTB and Qavion like this.
  3. Waggntx
    Waggntx Rookie
    Mar 25, 2022
    36
    Alice Franke
    I have been using a Cen-Tech float charger. I believe the amp output is only 0.25A. I probably need a higher amp output trickle charger, huh?
  4. m.stojanovic
    3,303
    Serbia - Niš
    Miroljub Stojanovic
    When everything is good, the "normal" battery drain is in the range of 0.03 to 0.05 A (30-50 mA). With this level of battery drain, a 0.25 A battery maintainer could probably do the job provided the battery is almost 100% full when connected. If you have higher drain than mentioned, 0.25 A may not be sufficient. Have you measured your battery drain?
  5. Waggntx
    Waggntx Rookie
    Mar 25, 2022
    36
    Alice Franke
    Here we go again. New battery had been constantly trickle charged (Cen=Tech float charger 0.25A) for 14 days; engine has not been started during this time. Solid green charging indicator on trickle charger indicates full charge. Voltmeter shows 12.5. Started car after disengaging trickle charger and voltmeter shows 14.5. I assume this indicates alternator is working. Shut off engine and reattached trickle charger. Green light solid. After another 14 days, voltmeter shows 12.1 and car will not start. Had to connect full battery booster for engine to start. Still confused about what to do. Help would be appreciated.
  6. sfcarguy
    sfcarguy Formula Junior
    537
    Earth
    Your battery tender is bad. A fully charged battery should be 12.7v.
  7. m.stojanovic
    3,303
    Serbia - Niš
    Miroljub Stojanovic
    Have you measured the parasitic drain of your battery?
  8. Qavion
    Qavion F1 World Champ
    14,583
    Ian Riddell
  9. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,415
    Atlanta, GA
    Steve D.
    Clean the bullet connector under the airbox to the starter...You haven't given details of what happens when it doesn't start. is it NOTHING, or a big click? is it cranking at all/just slowly?
    sjd
  10. jfink
    jfink Rookie
    33
    Charlottesville, va
    jon fink
    @rifledriver, I have 3 355's , all FHP and one in each variant.
    Two questions for you:
    1) do you know a good psychiatrist ?
    2) I am in Virginia....do you know of a reputable shop that can rebuild my alternator ? My issue is strange...I have a 1 of 1 Gated GTS in Blu Pozzi...really great car but twice now I have lost my battery after driving 25-50 miles....no warning...just warning lights and then nothing. My flat bed driver is now on my christmas card list, and I know all his kids names. Joking aside this is vexing..Could it be that in as little as two weeks my battery could get that weakened.
    While my car looks really nice on the back of a flat bed, I much prefer good inputs at 75 MPH into the twistys. Have any sage advice other than to answer question 1 ?
    Appreciate it and cheers, Jon
  11. Rifledriver
    37,288
    I have not yet found a reliable replacement for the one that retired.
  12. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,282
    CT
    John Kreskovsky
    Time to start carrying a fully charged spare battery in the funk. ;)
  13. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,922
    Richmond
    Pete
    Most of the time it's just the voltage regulator, which can be replaced without even removing the alternator from the car iirc. It's a standard denso part, usually like $40. In a pinch you could buy a similar capacity denso alternator for a Honda or Toyota and swap out the regulator, though it's a lot cheaper to buy it separately.
  14. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,922
    Richmond
    Pete
    Where are you in VA? Sportscar workshops in Richmond do most of the local Ferraris. Most likely your voltage regulator is fried and that's an easy fix, see above.
  15. jfink
    jfink Rookie
    33
    Charlottesville, va
    jon fink
    @bobzdar , I will contact them. I am in charlottesville so not so far away from me. Is there a test to see if it actually is the voltage regulator ?
  16. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,922
    Richmond
    Pete
    I don't know if there's a way to test that is the regulator, but it was cheap enough (~$40) and it was visibly fried, so I just replaced mine and it fixed the problem.
