Slow Down 5-8 and Cam Extension Rebuild | FerrariChat
Discussion in '308/328' started by Imatk, Sep 16, 2025 at 11:30 AM.
  1. Imatk
    Imatk Formula Junior
    May 6, 2007
    815
    Ok so this might be a long read.
    I took my car into a Ferrari shop to get a leaky cam extension fixed.
    The cam had to be removed and pin had to be drilled out.
    The cam was reinstalled and no leak. But there was apparently a noticeable "miss."
    It didn't have a miss before.
    The shop owner expected it to be fuel related so they put some injector cleaner through the car but it was still missing.
    My thought, was that since the coupler had been removed, and reinstalled that maybe the rotor was no longer in the right "spot" to fire the spark plugs.
    I was told this was impossible since the pin is what situates the extension so there would be "no way" it would be in the wrong spot.
    So if that is true, and they added fuel injector cleaner and that didn't solve the issue, my next thought would be, ok it has to be electrical.
    Wires are brand new as are extensions (and again this was not happening before the cam work).
    So I figured I would drive it a bit and see if the miss "clears" itself if it indeed was fuel related.
    Today I drove 30 minutes on the freeway at around 80mph to go to another shop to get something fixed on an AC line (not related to the issue)
    As I was driving back the other 30 minutes on the freeway this time around 70 ish mph the "Slow Down CYL 5-8" Illuminated.
    Then it went off. I slowed down to about 60 and it would occasionally turn on and turn off.
    I then pulled off of the freeway and took surface streets back home driving no faster than 40 mph and it stayed off the entire time.
    The 5-8 bank WAS the cam that was removed.
    So can someone please tell me what this is if it's not an issue with the rotor and cam extension?
  2. jhh925
    jhh925 Karting
    78
    Reno
    Jens
    This is a guess, but if that were my car and I was experiencing this issue, here's where I'd start:
    - My guess as to what's going on is that in the course of fixing the leaky cam extension, the shop had to remove the distributor cap, etc. In so doing, they loosened one of the ignition wire connections in the distributor cap. (My car is an '87 328, but I assume the ignition wires work the same ... the wires are inserted into connection holes in the distributor cap, then there's a small set screw that's tightened from inside the distributor cap that pierces the ignition wire, creates the electrical connection, and holds the wire in place). So, one or more of the ignition wires to bank 5-8 is intermittently failing, causing a misfire in that cylinder, sending raw fuel down the exhaust, which is then getting converted in the cat, causing the cat exhaust outlet temps to go up, triggering your "Slow Down" light.
    Again, this is my initial guess, and it's where I'd start.
    - I'd pull the spark plug wires from the plugs cylinders 5-8.
    - Then I'd gently remove the 5-8 distributor cap from the cylinder head - don't remove any of the ignition wires from the distributor cap.
    - Then I'd clip one lead of an ohm meter to the post that the ignition rotor spins by, and the other lead to the connector inside the spark plug extension at the other end of that ignition wire.
    - Then I'd wiggle the ignition lead all along its length, especially at (i) the connector to the extension, and (ii) the connection to the distributor cap.
    - If the lead is correctly and tightly fastened, the resistance reading should be some four-figure value (I recently tested mine, can't remember the numbers, but it will be lower for the shorter wires, higher for the longer wires).
    - If the reading tends to jump around, especially going to infinity (open circuit) for a particular ignition wire, then I'd re-do that ignition lead connection in the distributor cap.
    "But," you say, "the ignition wire set is new." Right, but the wire set is sold separately from the distributor caps, and the wires need to be correctly and securely fastened to the distributor cap in order to install the new wire set. So my hypothesis here isn't about a bad wire set, it's about a failed installation or a clumsy tech who was rough with the distributor cap while doing the leak fix. My limited experience (and maybe my own clumsiness) would suggest that the ignition wire connection to the distributor cap is easy to mess up.
    If you do this, let me know what you learn.
  3. Imatk
    May 6, 2007
    815
    Thanks for the reply. AFAIK the wires were never removed from the cap... but I honestly don't know for sure.
    For the test... are you talking about a continuity test meaning setting the ohm meter to continuity, clipping one lead to a post on the inside of the cap, the other led to the corresponding wire extension and seeing what readings I get?
  4. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,908
    Mike 996
    Post 2 makes sense as a possible cause of the misfire; a "mechanic" putting in a can of fuel injector cleaner and thinking it will fix it does not! ;)
    Imatk likes this.
  5. Imatk
    May 6, 2007
    815
    Yeah me too, I'm just trying to understand the test. I'm not a whiz with electrical and multimeters.
  6. jhh925
    jhh925 Karting
    78
    Reno
    Jens
    I'm not suggesting they were. What I'm suggesting is that when the mechanic removed the caps from the distributor mounts and shoved the distributors to the side, and then likely kept jostling them as he was doing the re-sealing work, that in the course of doing all that one or more wires were slightly loosened in their mounts in the distributor cap.
    Basically, yes, if the "readings [you] get" are in ohms, but - and this is probably just semantics - you can't really do a straight "continuity test" on ignition wires because the wires themselves have pretty high internal resistance compared to plain copper wire. It's easier to set your DVM to ohms to read what the total resistance in the wire is. I'm doing this from memory, but my wires were in the neighborhood of 700-900 ohms for the shortest wire and maybe 5000-ish ohms for the longest? What you're looking for are readings in the hundreds or thousands of ohms. You just don't want to see infinity or something in the hundreds of thousands of millions of ohms.
    In my mind, a plain "continuity test" is just setting the DVM to give you a beep if there's a closed circuit, and my Fluke won't beep over 40 or 50 ohms (or something like that). Again, to-mahto, to-mayto.
    Imatk likes this.
  7. Imatk
    May 6, 2007
    815
    Ok awesome thank you so much for the explanation. I'll set it to ohms and see what readings I get.
