Slow Down Light AFTER parking? | FerrariChat
Discussion in '348/355' started by huzilulu, Aug 29, 2011.
  1. huzilulu
    huzilulu Formula Junior
    Apr 20, 2011
    340
    Houston
    Huzi Husain
    So... I washed my 98 355 last night, and put her to sleep... woke up bright and early and decided to take her to work with me... Drove about 10miles at an avg speed of 45mph... got to the office, parked (no shade, so under the Dubai sun)... no lights/no CELs/nothing...
    Got to my table, worked... 2 hrs later, decided to go get a coffee... go outside, start the car, and the SLOW DOWN light starts blinking! I haven't even reversed yet, and the car has been sitting for the last 2 hours... the CATs cannot have heated up that fast! Or could they?? (These are the original headers and cats on the car from 1998 and have a little over 35000 miles on them)...
    Where to start? Replace Cats? Thermocouples? or the ECUs? I did have codes 1445, 1448, 1449 earlier which I re-set to see if they would come back... Should have brought my scanner from home... arrghh... will check what code is showing when I get back home tonight...
  2. 355Aussie
    355Aussie Formula Junior
    Jul 3, 2007
    688
    George
    Don't replace cats. Try O2 sensor first.
    Better still and I do not know the laws over there but why don't you punch the cats out and just have hollow cats then you should never have a slow down light.
    What scanner do you use for reading codes?
    I would like to have one of these to do the same?
  3. huzilulu
    Apr 20, 2011
    340
    Houston
    Huzi Husain
    Emissions testing is not a problem for me, but I do intend to ship the car back to Texas next summer when I move back to Houston - is TX emissions a pass/fail without cats?
    I bought my scanner+software of www.scantools.net --> many options on hardware and software. I bought the OBDLink (hardware) that supports plug-in adapter, wifi and bluetooth and got the ScanXL software from them as well -> currently the software is offered free as opposed to the regular price of $89. The hardware does come with free software of its own incase you don't want to purchase better software... Im quite happy with it - it reads the codes on the F, as well as my other cars without issues.
    For my issue - is there a way to test O2 sensors? thermocouples? ECUs? Test as in know if they work or not before having them replaced...
  4. 355Aussie
    Jul 3, 2007
    688
    George
    I'm in Australia so emmissions is not a big issue for me hence the hollow cats.
    For you Texas may be an issue.
    I do not know how to test the thermocouples or O2 sensors but you could swap them from side to side and this may correct itself if the sensors are fine.
    Alternatively you could buy a new thermocouple, O2 sensor and thermocouple station and at least you know they are brand new.
    I replaced all these brand new a while back and have never had any issues since. I suppose as the car is 16 years old why not replace them brand new?
    Just what I did but don't have to do on your end.
  5. k17har
    k17har Karting
    Sep 3, 2009
    144
    london, uk
    kayer
    I have the same issue and I have been told its the cat ecu, swap the left and right to test them. the 2 sit near the wheel arch. Follow the cat wires. It's an easy process.
  6. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,742
    The CAT ECU (slow down system: SDECU) can fail. Probably the case here.
    Its job is to protect the CATs from thermal destruction. It is a pain in the @$$ and costs $600 (a few years ago) to replace. It reads off the thermocouple (which rarely fails) and sends a signal to the engine ECU which turns on the light and a code. You an unplug it and make the error go away but don't do this unless you actually know the cat is not overheating.
    Has nothing to do with either O2 sensor.
  7. f355spider
    f355spider F1 World Champ
    18,055
    +1. The tip off is this happened after washing the car. The catalyst ECUs are prone to water instrusion as they age. The epoxy they use to seal them up (black on early versions, green on the latest updated ones) can shrink, and allow water, and dirt to enter causing failures.
    There are several threads on this site on how to narrow down the bad one. Try a thread search.
  8. huzilulu
    Apr 20, 2011
    340
    Houston
    Huzi Husain
