SLOW DOWN LIGHT FLASHING FOR A WHILE THEN NOT | FerrariChat
Discussion in '348/355' started by curtis13, Oct 29, 2010.
  1. curtis13
    curtis13 Rookie
    Sep 20, 2010
    35
    Destin fl
    Curtis
    ok guys. sorry for the stupid posts. i have read all the posts about this problem and cant get right.
    i replaced one of my cat ecu's to fix this and i cycled the battery and drove it through two heat cycles. the light went away and then about 10 minutes later it came back flashing in my face...... oooooo lovley.......
    it could be that i didnt reset the car correctly, i turned the battery off for about 30 minutes.
    my question is why in the world would it go away and then come back. i have tested both cats and they are not anywhere near overheating and this was city driving i was just cruising around town.
    i have my bypass valve wired open becuase it doesnt work for some reason.
    any help, again.......
    thanks guys
    curtis
    850-259-7223
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,595
    San Carlos, CA
    Mitchell Le
    If you are absolutely sure that the cats are not overheating, and the ECU is fine, then the only thing left if the actual thermocouple needs to be replaced.
  3. GerryD
    GerryD Formula 3
    May 5, 2010
    2,444
    North of TO
    Guido
    make sure your engine oil is not overfilled/
  4. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,961
    MD and NE
    Robbie
    There are 3 cat ecu's---you test all of them?
  5. 355 Shwing
    355 Shwing Karting
    Sep 9, 2009
    157
    Gulf Breeze, Fl
    Craig Payette
    I'm running test pipes, and I disconnected the damn things all together. If you're running test pipes, you don't need them. Even if you aren't running test pipes, you still "probably" don't need them. Ask Ernie about this. Those ECU's never worked the way they are supposed to.
  6. curtis13
    curtis13 Rookie
    Sep 20, 2010
    35
    Destin fl
    Curtis
    i still have the stock cats.... they dont rattle and i also have a temp gun and they are not overheating at all. i am thinking about pulling the bulb. love my car but damn the exhaust!!!!!!!!!
  7. WATSON
    23,717
    WI
    Wish I could help, but I am too new to this and still learning.
    For my education, what temp is "overheating"?
  8. ronrob
    ronrob Formula Junior
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    I suggest that you address 285ferrari's question (fourth post). The fact that the light went out for a short time does not necessarily mean that all ecu's are in good shape. Have you tried the usual trick of fitting the good (new) ecu to each ecu site successively and firing up for a reset each time?
  9. windsock
    windsock Formula 3
    1,153
    2.7 or 5.2? Wiring open the bypass valve can create false warnings on a 5.2. Also ensure that the thermacouplers on the RH side go to the correct location on a 5.2. If they get crossed it will cause false warnings as well. There are alot of ECU failures and connector problems with the catalyst monitor system. If you have only one catalyst functioning on a 5.2 it will cause false warnings as it has a plausabilty program to compare temperatures from side to side.
    This should get you started, good luck.
  10. curtis13
    curtis13 Rookie
    Sep 20, 2010
    35
    Destin fl
    Curtis
    its a 99 5.2 i have ordered one new ecu for the exhaust and i tried swapping it to all the 3 positions with no avail. my bypass is wired open
    i have not tried switching the probes on the right side. thats a good idea.
    thanks for the info.... shes getting a good waxing tomorrow and i will do that change then
    i will post tomorrow in the pm
    thanks
    curtis 850-259-7223
