"Slow Down" light on 550? | FerrariChat
Discussion in '456/550/575' started by darrahc, May 5, 2004.
  1. darrahc
    darrahc Rookie
    Apr 30, 2004
    16
    Any idea why the "slow down" light comes on in my 2001 550? The owner's manual refers me to a page that doesn't exist (3-34 I think), so it's not much help. Is this something I did, and/or is it something I can fix without getting to my dealer (currently ~300 miles away from me)? Tx.
  2. AnotherDunneDeal
    AnotherDunneDeal F1 Veteran
    Jun 2, 2003
    6,109
    N.Richland Hills, Tx
    James Dunne
    Your catalytic convertor is heating up too much is usually the tyrant for that. Just give your dealer a call and see if they can diagnose on the phone. They will usually give you an idea over the phone but still will suggest you take it in.
  3. Bart
    Bart Formula 3
    Nov 1, 2003
    1,522
    Orange County, Calif
    Bart
    Either that or you have not warmed up enough. I get a "SLOW DOWN" when I am going less than 5 mph in the parking lot. I just wait until the beast is warm. Use the oil temp gaunge.
    Never drive less then 12 cylinders
  4. bobafett
    bobafett F1 Veteran
    Sep 28, 2002
    9,193
    It's hard to say w/o a computer hooked up to it.
    I doubt your cats are overheating. On a 550, first they will flash at ~80% critical temperature, and then they will turn on solid. My light came on solid and the car decided to cut power when i was on the freeway once (ironic, the one time I needed it to be reliable), and I checked the cats: cool as the morning air.
    Turns out that the thermocoupler ecu had losts its mind a bit, just a quirk, and they didnt even need to replace them.
    If it happens just this once, let it go. I wouldn't worry. But if you see the light come on again, pull over and *catrefully* try to see if you can tell if the cats are hot. Maybe stick a piece of paper there and see if it lights up. Also, remember that it should flash first.
    --Dan
  5. Texas Forever
    Texas Forever Eight Time F1 World Champ
    BANNED Rossa Subscribed
    Apr 28, 2003
    85,600
    Texas!
    As much as I love the Shark, Ferraris and electronics don't mix. The !$#@$!@ check engine light seems to work on a random number generator. I had to have the seat belt light disconnected because the damn thing would come on if I made a hard right turn. The only way to turn it off was to undo the seat belt.
    Of course, none of this matters when romping from 3rd to 4th....
  6. bobafett
    bobafett F1 Veteran
    Sep 28, 2002
    9,193
    That's a wierd one. I think Ferrari secretly contracted out their electronics to an 80 yr old Lucas engineer. :D
    --Dan
  7. ze_shark
    ze_shark Formula 3
    Jul 13, 2003
    1,274
    Switzerland (NW)
    Do you systematically wait for the 'Check ok' message to come up on the dash indicator before turning the engine on ?
    My dealer insisted at delivery that the self-check time be respected otherwise you may experience the wonders of italian gizmotronics ... such as spurious "slow down" lights.
    Btw, page 3-34 does exist in my edition of my manual (edition 1a January 2001) and indeed refers to excessive temp in the exhaust system.
  8. darrahc
    darrahc Rookie
    Apr 30, 2004
    16
    I talked to the folks at Algar in PA and they seem to think it's the thermocoupler. I had it towed down there from Pocono and will hopefully get more details tomorrow.
  9. stephens
    stephens F1 Rookie
    Feb 13, 2004
    4,647
    Australia
    Stephen S
    Seems to be a common problem. I had both thermocouple units changed to fix the problem.
  10. ze_shark
    ze_shark Formula 3
    Jul 13, 2003
    1,274
    Switzerland (NW)
    Just for kicks and if you don't mind sharing, what was the parts/labour cost to change these thermocouplers ? Any warranty coverage ?
  11. stephens
    stephens F1 Rookie
    Feb 13, 2004
    4,647
    Australia
    Stephen S
    I'll check the invoices and let you know. Wasn't big dollars though, less than $1500AUD ($1000USD) for both units fitted. They are easy to access, being mounted in the engine bay.
  12. ze_shark
    ze_shark Formula 3
    Jul 13, 2003
    1,274
    Switzerland (NW)
    I guess I have to apologize for my humble reference points. A 1K$ invoice for thermocouplers which should be reliable in the first place is not exactly what I'd call peanuts.
    A quick story: I own a '99 Audi S4 biturbo, bought new. Great car except that it warps brake rotors. This winter, at 70'000km, the water pump broke down. Car is 4.5y old. Audi came to my house, picked up the car, and offered spontaneously to replace the water pump for free, considering it was abnormal to have any such failure on their cars.
    When the car was 1y old, they made a recall because a protection steel pad under the engine was at risk to break loose, operation required taking the engine out (2 days of work).
    Responsible and proactive attitude towards known quality problems, and responsible attitude towards abnormal failures.
    Should not we expect MORE from a company who's cars cost 4x as much ?
  13. bobafett
    bobafett F1 Veteran
    Sep 28, 2002
    9,193
    Thermocouplers and all "emissions" related items are covered under a 7 year warranty by law, at least here. So if they are bad, they get changed for free. And every maranello is within 7 years right now...
    --Dan
  14. ScuderiaLV
    ScuderiaLV Karting
    Dec 6, 2006
    230
    Las Vegas, NV
    Don C.
    Has anyone blown a cat on their 550? If so did you repair or replace (oem or aftermarket)?
    We were on a driving trip and everything was great. Went about 150 miles and stopped to top off with gas. When we got back on the road the car seemed sluggish. Then I got the slow down light when I was accerlating the car (aound the speed limit :)). I slowed down thinking something was not right. Then the car started sounding like a Volkswagen Beetle. We limped back to the town where we got gas and had it transported back home. Today, I found out I blew out one cat and the other is looking to go. FYI, '98 550 with 14,700 miles.
    Also, this is not the end of the story. Let's just say we started with a 550, 355, Countach and Z8. Finished with a Z8 and CLS500.
  15. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    I had the same problem on my 456 and it was traced down to the relay that controls the thermocouple.
    I would strongly recommned that you start from there, as they are inexpensive to buy and easy to replace.
    To test it you can just switch them around (left to right and viceversa) and see what happens.
    On the 456 they are under the hood, just above the side vents; I do not know where they are in the 550, but they must be in a similar location.
    Good luck.
  16. Doug n Terri
    Doug n Terri Rookie
    Mar 12, 2004
    21
    Thousand Oaks, CA
    Doug Anderson
    Hello - I am curious - it's been about 2 months now, what is the current situation? In addition to the Slow Down light, did the Check Engine Light or Malfunction Indicator Light (MIL) light up?
    DOUG
  17. ze_shark
    ze_shark Formula 3
    Jul 13, 2003
    1,274
    Switzerland (NW)
    My car started doing this too, but upon hooking up an SD2, what we found is that it's actually the battery which is getting old and whose voltage dips when the starter motor runs.
