355 - Slow down light on 96 f355 spider | FerrariChat
355 Slow down light on 96 f355 spider
Discussion in '348/355' started by glove, Oct 4, 2019.
  1. glove
    glove Rookie
    Jan 6, 2008
    6
    Indianapolis, In
    Garnell
  2. btween2
    btween2 Rookie
    Apr 18, 2018
    12
    light can come on due to old/crappy battery
  3. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    Anyone for Kettle Corn? Yum! :rolleyes:
    Qavion likes this.
  4. Pangea
    Pangea Formula Junior
    Mar 27, 2011
    442
    Nick
    :D
  5. Qavion
    Qavion F1 World Champ
    14,271
    Ian Riddell
    Did you slow down?
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,550
    San Carlos, CA
    Mitchell Le
    Glove, with a post count of 3 you are not giving us much background to go on. The single sentence trouble description is not much to go on. You have to try a bit harder with more information.
    1. Is it flashing ?
    2. Is it solid?
    3. Did it go on after 3500 and then go off under 3500 rpm?
    4. Does it come on right after you turn on the engine?
    5. When it is on, is the cat converter hot, cold or luke warm?
    6. Does your have have the cats still?
    7. Does it have thermal couples at all?
    8. What about the thermal couple ecus, are they green or black?
    glove likes this.
  7. wbt
    wbt Karting
    Nov 28, 2014
    234
    New Zealand
    Wayne
    Check through this blog post and see if it helps with any of your symptoms. https://technistrada.com/content/7-ferrari-slow-down-light-explained
    Slow down light issues are generally straightforward to solve, try the following checklist:
    Cat temp when it happens (is it glowing red)? If so you have could have raw fuel in the exhaust system and a likely engine misfire. Go to a mechanic.
    Grounding points for all electrical connections in the engine bay - remove, clean, reassemble.
    Cat ECU - very common cause. Remove and replace with new. 2 or 3 needed depending on the car.
    Thermocouples - rarely fail, but it can happen. Results in a solid slow down light.
    glove and Qavion like this.
  8. glove
    glove Rookie
    Jan 6, 2008
    6
    Indianapolis, In
    Garnell
    Thank you for your post. It was very helpful. I haven't changed my ECU's in over 12 years and they seemed to have failed. Will be ordering the redesigned units.
    Sent from my SM-G935P using FerrariChat.com mobile app
  9. glove
    glove Rookie
    Jan 6, 2008
    6
    Indianapolis, In
    Garnell
    Thanks, I discovered bad eco. Will replace.
