Slow down light stumping me. | Page 3 | FerrariChat
Discussion in '348/355' started by yelcab, Jun 23, 2017.
  1. Qavion
    Qavion F1 World Champ
    14,505
    Ian Riddell
    I'll see what I can do, Ernie, but I'm not a subscribed member, so I'm limited as to how many pics I upload. I used the back part of the metal pins to hold the diode and resistor in place (lightly crimped). I also put those soft yellow rubber plugs (included in the plug kit) around the diode and resistor before crimping to protect them.
    For extra hold on the diode lead and resistor lead (wire), I doubled it up (bent the lead back on itself so that two parts of the wire were crimped).
    If it was longer term, I would put sealant in the plug holes for weatherproofing.
    If I get the chance, I'll try to incorporate a number of pics into one to save bytes.
    Cheers
    Ian.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Great!
    Thanks Ian.
    Or make it in pdf form and then post the pdf diy.
  3. f355spider
    f355spider F1 World Champ
    18,055
    As an FYI, a friend had slow down lights on a F355 spider he was having hell with trying to figure out. He ended up replacing all the catalyst ecus, and thermoprobes and still had the dreaded light. He took to the dealer...they back probed the wiring and find broken or spliced wires on the Motronic wiring harness where it went through the firewall. They suspect someone messed it up at the last major service. Once the wiring was fixed, all good.
