Slow down light with gutted stock cats? | FerrariChat
Discussion in '348/355' started by cladd2000, Jun 2, 2011.
  1. cladd2000
    cladd2000 Formula Junior
    519
    If your stock cats are gutted and re-installed, how will that effect the chances of a slow down light and engine bank cut-off that comes with it?
  2. f355spider
    f355spider F1 World Champ
    18,044
    The system will still work as designed. It can also malfunction just as before... ;)
  3. Chris Honeywell
    Chris Honeywell Karting
    Nov 11, 2007
    98
    Trowbridge UK
    Chris Honeywell
    My cats are gutted and i get a slow down light occasionally, if i keep driving its normally off within 15 mins not to reappear for a couple hundred miles..
    Never had one bank shut down either.. I think with me its more a occasional fault with one of the CAT ecu's
  4. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    If you don't have real cats then I would disconnect the exhaust ECU. It isn't really monitoring anything at that point, and an extended slow down light will shut you down.
    BT
  5. cladd2000
    519
    At what level should I disconnect? At the ECU itself?
  6. Mera
    Mera Formula Junior
    Aug 13, 2005
    768
    Milwaukee, WI
    Rodney Dickman
    I'm looking to do this also. Wondering how it is best accomplished.
    Rodney
    1990 348TS
  7. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    494
    Victoria, B.C, Can.
    John Glen Wesanko
    I've had first hand experience with this problem on my recently aquired 1990 348 ts. When cleaning up the engine compartment I noticed the harness at each ecu was unplugged.So of course I plugged them back in and soon after starting getting erroneous "slow down" lights that will shut down the related cyl bank after about 5 minutes.After doing much research and monitoring the Cats with a lazer temp guage I simply unplugged both ecu's and stowed the loose plugs with a tye wrap.These ecu's are notoriously unreliable and expensive.I seem to remember Ernie posting about this and I believe he did the same.This is a prime example of how a poorly engineered vendor part can make a "monitoring system" more problematic and more expensive to maintain than the system it is protecting!
  8. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Yes I did. I completely removed the stupid things from the car.
  9. FerrariDeeJay
    FerrariDeeJay Formula Junior
    Jun 2, 2009
    418
    Chino, CA
    Michael
    I have a 1995 355 Spider and installed straight pipes about a year ago. I disconnected the Cat Temp ECU's and the only problem is the dash slow down lights stayed on. Easy solution is to remove the bulbs so you don't have to look at the red slow down lights all the time. But car runs fine without them. (My car has two).
