Slow Down Light | FerrariChat
Slow Down Light
Discussion in 'Boxers/TR/M' started by Red Head Seeker, Sep 30, 2010.
  1. Red Head Seeker
    Red Head Seeker Formula 3
    2,443
    San Francisco Area
    Mark
    Hello Everyone; Took my "Redhead" out for a spirited drive ( Is there any other kind). Ran Great....pulled strong up to 7,200 rpm. Drove for an hour and then noticed the "Slow Down cyl 1-6" light came on. Even with the light on I felt no difference in preformance. Car still pulled strong up to shifting at 7,200 rpm....Sounded great!!!. Car is a 1991 Testarossa with a custom exhaust (I fabricated) no cats,no pre cats with a flowmaster muffler. The custom exhaust has been on the car for over 1,000 miles with no "Lights" coming on of any kind. I did hook up both O2 sensors in the custom exhaust. Any & All "suggestions" Greatly Appreciated......Mark.
  2. Steve Magnusson
    26,842
    Without any catalytic structures, it must just be a false signal. You can swap the two slowdown light ECUs (located inside the RR wheel arch) and see if the "problem" moves to the 7-12 light. Also, if your 1-6 self-test isn't working well every time that would be another sign that your 1-6 slowdown light ECU is just flaky.
  3. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,425
    Alabama (was Mich.)
    Jeff
    If it was my car I'd remove the thermocouples and their corresponding ECUs completely, they are not needed on a car without cats or precats. I would also remove the air pump and it's associated hardware, you will have to make a pair of block-off plates to cover the air injection ports in the bottom of the cylinder heads (very easy). Getting all that crap out of there will take 20 pounds of the weight of the car. Removing the cats and precats also reduces weight...the TR need is heavy and anything done to lighten the car is good.
  4. Red Head Seeker
    2,443
    San Francisco Area
    Mark
    I would be curious/wonder why?, that this was not an issue after first installing the "New exhaust" ( No cats, No pre cats). Why did it take 1,000 miles for the light to come on. I have read on other "Slow Down" light inquires that a machine can be attached to find out "What Code" appears to indicate what caused the "Slow Down light" to activate. Should I do this?. Always a great service both you "Steve" & "Jeff" ( Carguy) provide....I have a large home near San Francisco ( I'm Straight), my home is always welcome to you "2"....Mark.
  5. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,425
    Alabama (was Mich.)
    Jeff
    I'm not sure about what "machine" would access the codes, but I'd imagine it's a Ferrari-Only item that plugs into the socket located under the left rear fender. The thermocouple ECUs are known to have issues...but it is odd that your light is on now of all times....after a thousand miles without precats or cats. I have a few of those ECUs laying around, if you want I can send you a known good one to try out?
    But really....just yank those things out of there!
  6. Steve Magnusson
    26,842
    #6 Steve Magnusson, Sep 30, 2010
    Because they are pieces of cr*p? ;) Seriously, I'm on my third set so you having only one go bad is better than average performance, and yours going "bad" has nothing to do with your changing the exhaust system IMO.
    No "codes" in a TR, the slowdown warning light ECU is supposed to turn "on" the slowdown warning light when the voltage from the thermocouple exceeds a certain value (as this thermocouple voltage should be proportional to exhaust gas temperature). Either something has gone wrong with the voltage detection portion or the lamp switching part inside the ECU itself.
  7. Steve Magnusson
    26,842
    Forgot to add that a bad (open) connection between the thermocouple and the ECU will also cause the warning light to go "on" so you can try cleaning/reseating the thermocouple connections.
  8. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,268
    Mel
    I replaced the OEM Thermocouple sensors and the problem was solved (in my case) .....
  9. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Greetings.. If your running test pipes thru out including pre cats I would not worry about it.. Everyone is right.. these components are flaky and were put in place to also detect exhaust temps so you would not over heat the cats and light up like a torch.. The ecu's are known to be flaky.. I would remove them also but I need to find a cap to close up the thermo coupler hole in the test pipe.. I leave them so I dont have a leak in the system.. I honestly think my ecu's are shot.. at immediate start up my lights do not illuminate at all during self test..
    R
  10. Mr.Chairman
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Maybe when you changed them over to the new system you damaged the sensor or wire.. Still not a biggy.. I would not worry about it..
    R
  11. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,941
    For a cap to close up the thermocouple hole you could use a ball-bearing that sits in the tapered-seat of the hole (acts as the sealing element) and then any kind of cap nut. If you use the original cap nut it ought to work best as the hole will center the ball nicely.
  12. Melvok
    Jul 25, 2008
    14,268
    Mel
    Cap to close: you could use an old coupler....
  13. Red Head Seeker
    2,443
    San Francisco Area
    Mark
    Many Thanks to "All" for your insights & inputs. To me the greatest part of this website is the free & open exchange of knowledge, if only our government was as effective as this. If I am ever in a bar, to all invovled the drinks are on me...."Only Top Shelf" for my friends......Mark
  14. GregTe
    GregTe Formula Junior
    May 3, 2004
    544
    Maine
    In just took my car out for the first ride this year, the slow down 7-12 light is on, it comes on the second you start the car stone cold and never shuts off. Mine also has a buzzer that won't go off, is this related to the slow down light?
  15. GregTe
    May 3, 2004
    544
    Maine
    I did try switching the two ecu plugs under the rr fender, the light still stayed on 7-12. One thing I did just do is remove the dash and instrument cluster to re-dye, could I have disrupted something under there?
  16. Steve Magnusson
    26,842
    #16 Steve Magnusson, May 16, 2011
    Yes, in normal operation, the wire that the warning light grounds to turn on the red dash light also turns on the buzzer when grounded.
    Unplug the warning light ECU 4-pin connectors (you can leave the thermocouples connected), and turn the key "on" (no need to start the engine) -- if the warning light still comes "on" and stays "on", you must have shorted/pinched a wire to ground during your dash reassembly.
  17. GregTe
    May 3, 2004
    544
    Maine
    Update... I traced the wires to the conectors (just above the rear right shock tower), cleaned/taped them up,uplugged and replugged them and now my light and buzzer are gone :) . I didn't really see a problem, must have been dirty connection... I hope that solves it.
  18. Mr.Chairman
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Greetings.. that is usually where the problem is.. Glad you found your problem.. Sometimes the ecu's get really flakey.. they can shut down a bank as well.. Drive on brother..
    R
  19. Fritz Ficke
    Fritz Ficke Formula 3
    2,266
    Tucson, AZ.
    Fritz Ficke
    I thought it might be good to to get a 'speed up' light to replace the 'slow down' light for the Alfetta :)
  20. Gary Diercks
    Gary Diercks Rookie
    Sep 11, 2007
    18
    Muscatine, Iowa
    Gary Diercks
    Have a 93 512TR W/34,000 mi. Have had absolutely no problems BUT, after installing the "Delubozpart", catless test pipes, both of the yellow "Slow Down" lights come on intermittently after only approx. 5 minutes of driving. Mostly they come on during slow or steady driving. Actually had one of the "Slow Down Engine Lights" come on after a run through the gears. Have cleaned plug contacts. No change. Test Pipes have already turned a blueish color. Thermocouples are still located in the "Precats". Car has a "Tubi" Exhaust silencer/Muffler. What should I do next short of removal and replacing the stock Catalytic Converters. Suggestions?
  21. Gary Diercks
    Gary Diercks Rookie
    Sep 11, 2007
    18
    Muscatine, Iowa
    Gary Diercks
    Previous post should be "Yellow Check Engine Cyl. Lights, 1-6 & 7-12" are coming on after approx. 5 minutes of operation. A "Slow Down" light only flashed on once for a very short time. Sorry for the mistake.
  22. dontilgon
    dontilgon Formula Junior
    May 30, 2011
    336
    NY/PA
    Joseph
    Did you ever solve this problem?
  23. Gary Diercks
    Gary Diercks Rookie
    Sep 11, 2007
    18
    Muscatine, Iowa
    Gary Diercks
    NO!!! 512TR is just sitting in my garage. Sure would like to solve this problem. May have to trailer it all the way to Chicago just to get this solved. Car runs great but don't want to run it with warning lights showing. They only come on @ less than 3300 RPM. Anyone have any suggestions?
  24. ants2au
    ants2au Formula Junior
    Nov 19, 2003
    798
    Sydney Australia
    Anthony
    If its Check engine lights, you need to get the codes out of the 2.7 ECU. that will at least give you a hint on what might be wrong.
    Do a search on here. plenty of info on how to get the codes from the flashing CELs.
