SLOW DOWN LIGHT | FerrariChat
SLOW DOWN LIGHT
Discussion in '456/550/575' started by arkferrari, Mar 26, 2018.
  1. arkferrari
    arkferrari Karting
    211
    Hot Springs, AR
    B.F. Mitchell
    Both catalytic converters have been removed from my 99 456M GTA; they are not being replaced. I am attempting to eliminate the amber flashing "Slow Down" light. My research tells me that the 02 sensors are sending misinformation to the ECUs causing the SDL warning. Before replacing the sensors, can I install 02 sensor spacers (Spark Plug Non-Foulers) and using the old 02 sensors see if the SDL goes off? My research says the sensor spacers are needed when the cats are missing; is this true? Are special spacers necessary for Bosch or NTK sensors or will generic brands at AutoZone work? To complicate the matter, is there room for the spacers with the rear 02 sensors? How difficult a job is it to access the rear 02 sensors? Thanks for the help.
  2. arkferrari
    arkferrari Karting
    211
    Hot Springs, AR
    B.F. Mitchell
    107 views thus far.....107! And no, zero, zilch replies or comments. I was expecting something......
  3. franschman
    franschman Formula Junior
    Dec 18, 2017
    362
    Holland
    Bart
    The sensors are all readily accessible, but no clue how to fool the ecu.
  4. tazandjan
    39,187
    You got one from John in the tech forum.
  5. arkferrari
    arkferrari Karting
    211
    Hot Springs, AR
    B.F. Mitchell
    I've looked in the Tech Forum and can't find a response. Please advise. Thanks
  6. INRange
    INRange F1 World Champ
    12,581
    Virginia/Florida/Caymans
    JD
    I would drop Gothspeed a message and see what he says. I believe your thermocouplers have their own ECU and that the SDL circuit is separate from the engine ECU.
  7. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    And a couple on F-Life ;)
  8. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    I think the temp sensors are giving you that signal, not the lambda sensors. I put catalyzers on my 456M and the light disappeared. The car ran much better with the caralyzers and used less fuel too. No need to run without cats.
  9. tazandjan
    39,187
    I probably saw it on the other site.
  10. Adam3442
    Adam3442 Rookie
    May 3, 2018
    11
    Adam Larman
    When I've removed cats before (albeit not Ferrari's) I normally put an extension on the lambda fitting. This moves the Lambda out of the direct travel of exhaust gasses and they read less and more in line with the reading they should get when cats are still fitted.
