360 - Slow down light | FerrariChat
360 Slow down light
Discussion in '360/430' started by Chrisv123, Sep 11, 2020.
  1. Chrisv123
    Chrisv123 Karting
    108
    Chris
    New 360 owner 6-speed MT!
    I have a blinking check engine light (Orange) , loss of engine power....seller noted in “near future” I should replace 02 sensors...any ideas? Have been driving it a lot recently. “Slow down” appears right around 65 mph
    Any help would be appreciated, thanks!
  2. S F
    S F Karting
    May 13, 2016
    167
    Texas
    Blinking check engine light is usually a sign of a severe misfire. Driving like this can cause damage to your cats so I wouldn't drive it any further than absolutely necessary.
    I would pull the codes on the car but if you want to just throw parts at it then I'd do O2 sensors, MAFs, coils and plugs.
    EastMemphis likes this.
  3. wbt
    wbt Karting
    Nov 28, 2014
    234
    New Zealand
    Wayne
    Explainer about your slow down light https://technistrada.com/content/7-ferrari-slow-down-light-explained
    Either a spark/fuel/ignition issue is causing a misfire and putting raw fuel into the cats (creates overheating causing slow down light), or the cat ecu has failed and is shutting down half the engine. Definitely get it checked out.
