Hey everyone! Just a question - do your "Slow Down" lights (one for cylinders 1-6 and one for 7-12) come on independently of each other, or do both of them come on at the same time? Mine are coming on at the same time from time to time and I don't think that's normal? Thanks!
Well....once the engine is started it's not "normal" for them to come on at all They work independently--each bank has it's own "ECU". They fail often and give erroneous readings. They should come on together for a few seconds as a self-test when the key is turned to position "II" (BTW there is no position "I"), but to come on together at the same time while driving is a bit suspicious. Are the thermocouples actually inserted in the exhaust or have they been removed and tied to the chassis? Do they come on exactly at the same time or approximately at the same time?
Lol yeah they come on often while driving, even at lower rpms (2k) while cruising. They seem to go off once the car warms up (usually) although today they did come on after about 20 mins of driving. And they do come on exactly at the same time when they do come on. And interestingly enough, the 1-6 only comes on when turning the key to the II position (the 7-12 is off at that time). Any ideas? I think this might have to do with my previous threads on intermittent no power. I was thinking of rigging up a system to check for spark plug firing and voltage at the coils while driving, but knowing that the lights should come on independent of each other makes me think I should fix that problems before diving in to the engine voltage? Sent from my Nexus 10 using Tapatalk
Hi Joe, these lights re a PITA .... often caused by bad contacts .... clean then ... and hope it helps ...
Cool thanks, so they are hooked up to their own ECUs, huh? I would think someone just wired the lights together (to explain why they come on at the same time) but only the 1-6 comes on when the key is in the "II" position and the engine is not running (which I understand is correct?) Any ideas?
take out the instruments and have a look how those 2 lights are connected. normaly both lights have to go on when ignition is on and will go out after the engine is running, may be also when only ignition is on and engine is not running after a while they will go out, but don´t know this
Yes, another part of this car that sucks. These ECU's are glorified on/off switches. They run about $600. Very pricey for a light switch. I've replaced both over many years. I've considered tearing one of the old ones apart to see if I can fix it and re-seal it. Thee problem is the backing is like an epoxy. It originally sealed the unit but it shrinks, cracks, and allows moisture inside. Many people disable, or remove these especially if they have modified the exhaust. These sensors are for detecting when your cats are overheating. If you're not aware enough to know that your cats are clogged and getting hot, you probably shouldn't own this car.
Disconnect PLUS from battery, connect PLUS cable 20 secs to earth ... Ecu's are now reset. Connect .... Should be no more lights ... normally. But DO read this thread ... (made for 512TR, hope it brings you something for TR) ... or just a info ...
Mel that only works on the 512TR. OP has a 1987 Testarossa. Sounds like the self-test function is not working on the 7-12 ECU--not uncommon. The 1-6 is working correctly (at startup at least). As others have said, it's important to know if you actually have an overheat problem (blocked catalyst) or an indication problem. If indication only you'll have to decide how important it is to repair. If you don't have hollowed-out cats it would be best to have the system operational or monitor your temps frequently (IR gun for example). The overall system is simple but the CAT ECUs are crap. There were three different iterations of the ECU during production and even the last ones were unreliable. Start by checking the connections at the ECUs--there is a rectangular panel above your cyl. 1-6 (RH) fuel accumulator. Remove two 10mm (wrench) bolts and unclip the large wire harness attached to it. Carefully withdraw panel to access connections. Each termocouple will have two wires going to their respective ECU (one wire is red, the other yellow). On my '88, at the ECU end one thermocouple has a green band, the other a red band: green=cyl. 1-6, red=cyl. 7-12. My (2nd design) thermocouples have two bullet connectors that plug into the female plugs on the ECU (1st design screwed in (I think). Also on each ECU is a four pin plug (only three pins are used)--these are also color coded red and green. There should be a black (ground) wire for each. Next, there is a green with white trace wire that connects the two ECUs, then goes from the 1-6 ECU through connector C7, to the fuse panel "w" connector, terminating at fuse#22. Finally, there is a red wire (on the 7-12 ECU) and a green wire (on the 1-6 ECU) that go to each dash light & the warning buzzer. I would start at the ECUs since they are easier to access. Make sure your connections are correct and serviceable (not corroded). Moisture was a problem in the engine bay, the third design finally incorporated weatherpack connectors to try to make the system more reliable. Check the thermocouples at each end. Check the ground. Let us know what you find. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Another quick question - how can I tell if a cat is obstructed / clogged? Is it as simple as feeling the air pressure exiting the exhaust?
The Tubi shouldn't make any difference, the thermocouples are between the Tubi and the manifolds. If your temps are actually high it's because your cats are clogged (the honeycomb matrix inside breaks up over time and can obstruct the airflow).
Maybe, unless both are clogged (which your lights are indicating is the case) so there wouldn't be any comparison left to right. The IR gun I mentioned should give a good indication after the car has been driven, but honestly the best way is to physically inspect them. Here are some (lousy) shots of my pre-cats for reference. Sorry I don't have photos of the inside of the cats themselves. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
OK work begun. Here are the connectors behind the panel. There are three conductors in the wires but the lines from the ecus look like they have 4? there's a white wire in the ecu line that doesn't connect to anything in the green connector. Same thing for the red side.
Hmmm with the green and red connectors disconnected, should the 1-6 light still be coming on when ignition is in II position ( engine off) Sent from my Nexus 10 using Tapatalk
Lol frankly I expected something cooler looking than just a piece of plastic on the backside of the ECUs
Hmm with the engine off and the key completely out, I'm seeing voltage on the connectors: Green: Green wire: 2 volts Green wire junction with green wire with white stripe: 3.4 volts Black wire: 0 (as expected) Red connector: Red wire: 1.8 volts Green wire: 3.4 volts Black wire: 0 Sent from my Nexus 10 using Tapatalk
That is correct -- that line from the warning light ECUs is not used. No, it should not. Is the (annoying) "buzzer" that normally comes on with either of those lights still connected?
With the key in the on position, I'm seeing these voltages: Green connector: Green wire: 1.1 volts Green w green with stripe:11.8 Black:0 Red connector: Red wire:11 volts (the green wire in the corresponding location on the green connector only measured 1 volt! Problem?) Green wire: 11.8 Black:0 Sent from my Nexus 10 using Tapatalk
