Slow in, Fast Out is a myth | Page 3 | FerrariChat
Discussion in 'Tracking & Driver Education' started by rob lay, Aug 28, 2012.
  1. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    64,649
    Southlake, TX
    Rob Lay
    the clip is the apex in most cases. exceptions are of course when you don't want to clip.
    what I'm saying in your terminology then is F1 drivers seem to be Honey Badgers about clipping the corner they don't give a **** about hitting it or being 1-2 feet off.
    IMHO the perfect line will always clip some part in the turn except cases like a combination turn where you give up clipping one of the corners (usually the first).
  2. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    Rob, these guys repeatably hit a braking point within a couple of meters from 180MPH or more and you're telling me they miss apexes by a foot!
  3. rob lay
    Dec 1, 2000
    64,649
    Southlake, TX
    Rob Lay
    yes! no one believes me, just watch them, they hit apexes, but they are constantly missing apexes by 1-2 feet too. obviously it isn't that slow or they wouldn't be doing it. as posted much of it has to do with those cars and aero vs. sports cars, it just isn't as critical for them. I imagine it is staying full throttle not upsetting the car and letting it roll smooth without any input just for the sake of clipping the corner.
  4. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    Not true, there is a turn at Thunderhill, turn 8, where the clipping point is well past the geometric apex, and believe me, you do want to clip it. You might want to call it a late apex but that just reinforces my point about apexes being dynamic.
  5. rob lay
    Dec 1, 2000
    64,649
    Southlake, TX
    Rob Lay
    I don't understand, but I've never used the terms clipping, dynamic, or geometric.
    I'm using apex as what you are turning around or aiming for. It is easy when it is the point you are clipping the curb. In cases of two 90 degree turns exiting onto a straight you may apex around the first corner several feet out from the curb.
    I'm not wrong, you just aren't understanding me because I'm trying to mix in your language I don't fully understand.
  6. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    This is my point, what they're aiming for might be different from what you're aiming for or what you think they should be aiming for because of the different car characteristics and what preceded and followed the turn or sometimes because of a following or leading car.
  7. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,959
    Richmond
    Pete
    I think he's saying they don't hit the same spot every lap, they're off by a couple of feet each time. I've seen it as well, but I think with the tires as much of a moving target as they seem to be and the lack of testing, it's to be expected to a degree. I've seen some truly good qualifying laps where the drivers don't appear to be off an inch, but it must be when they have that golden lap with the tires spot on that they can do it. Schumacher in Monaco and Vettel in Montreal stick out in my mind.
  8. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    #58 PSk, Aug 30, 2012
  9. mousecatcher
    mousecatcher Formula 3
    Dec 18, 2007
    2,116
    san mateo, ca
    Exactly, and that's why the article is wrong.
    Imagine the 3 simplest, constant radius lines through a uniform corner. These lines follow the inner radius, the middle radius and the outer radius. The innermost line has the slowest entry speed (tighter radius) but is the shortest line. The outermost line has the fastest entry speed, but is the longest line.
    What "slow in" refers to is not to actually be slow, it's that you enter slower than the fastest possible entry speed. Even when the time in the corner is the same for 2 different lines, the better line is the one with a faster exit speed (just considering a standalone corner). For a uniform corner, that line MUST be the one with the slower entry speed, since the faster exit speed is a result of being able to get to power sooner -- relative to the fast entry line.
    Now we take that to the extreme and we have the line with the fastest exit speed, and the slowest entry speed relative to all other lines that spend the same time in the corner. In other words: slow in, fast out.
    This line also happens to be the safest line, since by definition you have the most room from apex to exit. By definition, because to have the fastest exit speed you have to be able to add as much power as possible as soon as possible, and that can only occur if the radius opens quickly -- which gives you the most room for error.
  10. mousecatcher
    Dec 18, 2007
    2,116
    san mateo, ca
    Your terminology is very nonstandard. The "apex" is well understood to be the part of the turn where you come closest to the inside edge of the road. It is different for every car and every tire. Nobody means the geometric apex when we just use the word apex by itself. Unless of course they just happen to coincide.
  11. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    You're right, I suck at explaining things, never have been very good at expressing myself. Sorry :(
  12. rob lay
    Dec 1, 2000
    64,649
    Southlake, TX
    Rob Lay
  13. rob lay
    Dec 1, 2000
    64,649
    Southlake, TX
    Rob Lay
    I'm not talking about aiming point. It will be hard to convince me that the fastest line around a corner in F1 is 1-3 feet out from the curb (not talking wet line either). I think the fastest line around a course for F1 cars is hitting apexes (track edge/clipping), but it seems to be less important than sports cars.
    Of course maybe I wasn't the fastest driver, it was more important to me I hit the apex than be fast. :D;)
  14. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,279
    Huntsville, AL., USA
    Andrew
    It depends if it's a compound corner or not.
    Unfortunately I can't remember which circuit this is... I recall one track where it looked like 3 small right turns, but the way the cars took it was to hit the apexes of 1 and 3 and drift out 5 feet from the apex of 2 - the effect was that they were taking all three corners as one smooth and very large corner that kept the cars more stable for continuous power, rather than trying to keep in tight at the second apex in that series and unsettling the balance. So, I'd say it's rare but not impossible that the fastest line is to miss the apex.
    Can anyone remember the track? I'm really struggling here. I don't think it's a current one on the calendar. :eek:
    All the best,
    Andrew.
  15. rob lay
    Dec 1, 2000
    64,649
    Southlake, TX
    Rob Lay
    I already said I'm not talking about combination corners, this is single corners!
  16. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    I thought the apex of a turn was the point where the car had the greatest amount of steering lock turned into the corner - which COULD be the point closest to the curb or edge of the track (and usually is) - but not necessarily.
  17. rob lay
    Dec 1, 2000
    64,649
    Southlake, TX
    Rob Lay
    most "amateurs" that suck like myself talk about apex being where you turn in, clip curb, and where you hit track exit (2 off many times :D).
    if you start analyzing lines like a decreasing radius turn you might have the track turn in, point in middle of track where you had the most steering input, where you clip curb on back side, and then track exit.
  18. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,239
    Atlanta
    Tom Spiro
    At Winfield they taught the apex is where you stop slowing and turning in, and start accelerating and drifting out.... it can move but there is an ideal apex for every car.
    As for the F-1 guys, and from the pics shown - Monaco, its critical to hit your apex lap after lap... there no room for error. at Montreal only place that its critical is the chicane at the entrance to pit straight...
    In F-1 and to some extent modern ALMS Prototype racing its about rotation vs. "clipping an apex". if you look at the f-1 cars they rotate around a lot of the sharper bends, and simply slam on the brakes & down shift as late as possible and get back on the power ASAP, that is where the time is made up ... not in traditional 1970's racing style.
    Nick Mason was talking about modern F-1 cars, and how difficult they are to drive becuase you have to adopt a completely different driving style that seems very un natural compared to the cars that he routinely drives. even his 78 F-1 312T3 is more about traditional lines and slip angles, todays cars demand the following sequence:
    full throttle, down shift, brake, rotate, full throttle up shift... try that in your track car ... and you'll be off.
    That being said most F-1 drivers today learn the craft on go karts, so that is the style they use.... a fast shifter kart is full on all the time, and you rotate "thru" the corners. The apex is not really relevant in F-1 UNLESS you are at a tight track like Monaco.
    At Spa this weekend... there are several turns that you need to be spot on apex wise... Eau rouge, and the run up from malmady... back to start finish... the hair pin is not so important as its so slow...
    But for Rob, keep focused on apex and exit speed... that is the "fast" way around.
  19. texasmr2
    texasmr2 Two Time F1 World Champ
    22,232
    Houston
    Gregg
    Great thread.
  20. b-mak
    b-mak F1 Veteran
    I use much of the same language you're using and understand you completely. Fundamental corner theory.
    I'm actually concerned for those who don't understand you.
    I would appreciate it, though, if you expanded on what you mean by "dynamic". I think I know, just not certain.
  21. b-mak
    b-mak F1 Veteran
    #71 b-mak, Aug 31, 2012
  22. mousecatcher
    Dec 18, 2007
    2,116
    san mateo, ca
    Yes, that's right. In fact the apex may not be the closest to the inside. Turn 2 at laguna, for example. I guess I oversimplified.
  23. rob lay
    Dec 1, 2000
    64,649
    Southlake, TX
    Rob Lay
    you understand him completely, but you don't understand dynamic? well then you understand the same amount I do which isn't completely.
  24. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    Having raced bikes and go carts with some success, I think that the following is true: there are three kinds of corners: 1. Those that lead to a straight, 2. Those that are an exit from a straight, and 3. Those that lead to another corner. There are variances to those three, such as their cornering speed, i.e., fast medium or slow. That said, you need to analyze the corner to see whether you wish a high exit speed, high entrance speed, or highest cornering speed. I used to diagram a track to see what the optimum should be, then walk it to set the apexes. Riding would determine the specific braking and turn in points with traction determining when to start with the throttle. We used to spin the rear tire to force oversteer on some corners (we'd call it backing in), but not much whelspin off the corner bucause it slowed the acceleration.
    Might not work for everyone, but it did work for me.
    Art
  25. fatbillybob
    Aug 10, 2002
    29,487
    socal
    I never think of slow in fast out or fast in fast out. My friend, another SCCA racer, does not use these terms either.
    He coined the phrase, "you need to driver angrier everywhere.."
    There is a fine line between "driving angrier everywhere" and driving in anger and making mistakes lossing time. I don't know where that line is but i do know that I can always find a half second if someone pisses me off.
