Slow return to idle on ‘81 308 GTSi | FerrariChat
Discussion in '308/328' started by Smiles, Jun 14, 2019.
  1. Smiles
    Smiles F1 World Champ
    Nov 20, 2003
    16,675
    Pittsburgh, PA
    Matt F
    When I lift off the throttle, my 308 GTSi returns to idle very slowly.
    If I’m cruising and I lift off the accelerator the car doesn’t slow down at all.
    What could be causing this? In my simple mind it feels like a weak throttle return spring.
    Matt
  2. Smiles
    Nov 20, 2003
    16,675
    Pittsburgh, PA
    Matt F
    My first guess was that the floor mat was covering the throttle.
    It isn’t that.
    Matt
  3. syata
    syata Formula Junior
    Feb 23, 2017
    428
    Darn...that would have been too easy. That was my culprit.
    Good luck and let us know what it is.
  4. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    Try closing the throttle butterfly at the intake plenum by hand to see if the it is not fully closed. If that does not work, you may have a vacuum leak.
  5. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Disconnect the cable from the butterfly, and operate by hand.
    If it sticks at all, the problem is in the throttle area. If if doesn't, it's either the cable or the pedal.
  6. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,833
    Cerritos, CA.
    Very rare but it does happen when the return spring on the throttle body breaks.
