News
Slow Window Fix... “Accelerator” module
Discussion in 'Boxers/TR/M' started by vincenzo, Apr 15, 2020.
  1. tf308
    tf308 Formula 3
    1,122
    Virginia Beach
    Tim
    I asked because if you made them, I would buy one. I’ve been waiting to see if I can get one of your fuse blocks for my 308qv.
    512tr has the updated mechanism...no pulleys or wires
  3. samsaprunoff
    samsaprunoff F1 Rookie
    3,191
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Tim,
    Gotcha. My apologies, as I did not understand the context of your post!
    As for my blocks... I may have have found a supplier of the base material, which is what has been holding me back. Previously I had to buy the base material in large sheets which was difficult to source and was pricey to transport (it is/was not locally stocked). I am checking into the new material's specs (flammability rating, UV resistance, heat/temp resistance, etc) and if it checks out I will order some and get a few blocks milled to see how I like them. If all checks out I will order more material and bug my machinist buddy to work his magic.
    As for Vincenzo's application... I did not dig deeper to see what car he had and so I simply was speaking about the window motors in general terms. I did not realize that the TR does not have window motor cables... Do do they use a direct drive mechanism?
    Cheers,
    Sam
  4. DonB
    DonB Formula Junior
    395
    Florida
    Don Bartz
    Thanks!
  5. tf308
    tf308 Formula 3
    1,122
    Virginia Beach
    Tim
    I think the TR has the cables, but the 512tr does not. One of the many upgrades to the 512tr.
  6. ago car nut
    ago car nut F1 Rookie
    4,962
    Madison Ohio
    David A.
    The TR does have the cables.
  8. DonB
    DonB Formula Junior
    395
    Florida
    Don Bartz
    This is for Sam..
    If you were referring to doing fuse blocks again, I'm still in for replacements for my 308 and BBi.
    Keep us informed.
    Don
