Slowdown Light (very specific) | Page 3 | FerrariChat
Discussion in '348/355' started by eckeph, May 9, 2023.
  1. eckeph
    eckeph Rookie
    Dec 30, 2022
    33
    Erik Phersson
    Yes, I understand that is the correct operation. But my valve only opens if I have re-routed the hoses so there's permanent vacuum to the valve which makes it open even at idle. If the hoses are routed as they should be, the valve doesn't open at all.
  2. Qavion
    Qavion F1 World Champ
    14,584
    Ian Riddell
    Are you getting 12 volts from the ignition at the solenoid plug? The ECU sends an earth/ground to the solenoid on the other pin at high rpms, but because the ECU output is transistorized, there may be a small voltage present with the key on (and at idle).
  3. Qavion
    14,584
    Ian Riddell
  4. Qavion
    14,584
    Ian Riddell
    12 volts should be on the green/black wire of the black bypass solenoid plug (i.e. not the blue one). The other wire is blue/yellow. This has the small voltage or earth on it.
  5. eckeph
    eckeph Rookie
    Dec 30, 2022
    33
    Erik Phersson
    The coil works since the vacuum valve opens when I put 12V on the pins.
    I have checked and the blue connector is on the right valve as per instructions earlier in this thread.
    I have also tried the dummy loads so it can't be a real cat temp issue.
  6. eckeph
    eckeph Rookie
    Dec 30, 2022
    33
    Erik Phersson
    Thanks, I will check as soon as I get some help
  7. eckeph
    eckeph Rookie
    Dec 30, 2022
    33
    Erik Phersson
    Ok, the connector has 6V on it regardless of the RPM of the engine. That's between the green/black and the blue/yellow
    Qavion likes this.
  8. Qavion
    14,584
    Ian Riddell
    (EDIT)
    I meant checking the voltage on each wire to ground, but anyway, your check is showing that the ECU is holding the voltage at 6 volts, which I recall is normal for low rpms. Did you monitor the voltage when driving? Depending on the car, the ECU doesn't rely solely on rpm values, but throttle position and possibly other factors. I haven't tested it myself on a static car to see if it the bypass valve behaves the same with the engine not under load. Anyway, for my peace of mind, could you recheck the voltage on the green/black wire only. The car doesn't have to be moving.
    As you have fitted Technistrada dummy plugs to the main cat ECU thermocouple wiring, it's unlikely that the main cat systems are generating the warning lights.... unless you have a thermocouple ECU wiring or Motronic ECU issue. Do you have 12 volts power at the thermocouple ECU plugs? (on the green wire/pin 1)
  9. Qavion
    14,584
    Ian Riddell
    #59 Qavion, Sep 22, 2024
    I was under the impression that there were only two variations to the bypass system. Both had thermocouples on the exhaust bypass valve, but one car didn't have a thermocouple ECU for the bypass system. My confusion wasn't helped by this diagram in the WSM.
    That diagram also shows the thermocouple ECU for the left main cat as being on the right hand side of the car, which seems to be another possible variation.
    Elsewhere in the WSM, there appears to be only two variations. Cars with and without bypass thermocouples, so I suppose your car may be normal for your country.
    Do you know if you have the correct Motronics ECU fitted for your car (assembly number and country)?
    Oddly, the online parts manuals show no bypass thermocouple for any car.
  10. eckeph
    eckeph Rookie
    Dec 30, 2022
    33
    Erik Phersson
    An update. It actually turns out that the connectors on the valves was switched after all. After switching them back everything works as it should. I have no idea why I didn't catch this before, especially since I did check for it.
    cactussed and Qavion like this.
