Small Brass Nut Found Where Does It Go | FerrariChat
Discussion in '308/328' started by Lawrence Coppari, Feb 7, 2017.
  1. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    While draining the radiator portion of the cooling system of my 1987 GTS today, I dropped the plug that drains the radiator in the channel that catches the draining coolant and discharges it through two small holes on either side. While fishing for the plug and washer in the channel below where the plug screws in I found a small brass nut. It takes a M5 0.8 screw and measures 5/16 inch diametrically across the flats. Does anyone know where it goes? The nuts on the back of the fans are all present.
  2. wildcat326
    wildcat326 Formula 3
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    Horn compressor mount? My car is in the shop at the moment, but I seem to recall the fasteners being pretty small, and right in the area of the radiator bleeder.
  3. Rifledriver
    37,122
    I'm not sure it goes to that car at all. If it does a 5mm brass nut would be electrical. There are no exhaust fasteners that small. I do not believe the heater fans use anything like that. The fuel pump uses a 5mm nut for the ground wire but Bosch uses steel there.
  4. Rifledriver
    37,122
    Brass is never used for general purpose fastening.
  5. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Hood badge nut?
  6. Rifledriver
    37,122
    I suppose it could be a badge fastener.
  7. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Hate losing my nuts!
  8. Dr Tommy Cosgrove
    36,455
    Birmingham, AL
    Tommy
    I was just so thinking of something to say myself... :)
  9. Dr Tommy Cosgrove
    36,455
    Birmingham, AL
    Tommy
    This thread title is just begging for it!
  10. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,223
    Gold Coast, Aust.
    Patrick
    Yes, "On the brass monkey" came to mind
  11. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    My bride says I lost mine too
  12. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    For sure it's a horn compressor electrical connection nut...know how I know...I dropped mine down there next to the radiator. Yours has probably been replaced already when they dropped it...
  13. Lawrence Coppari
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    The car has not been serviced by anyone but me since 1996. There have been several coolant changes and I would have noticed it by now.
    The horn works and sounds as if it is located in the driver fender somewhere. What else must I remove in order to see if the compressor nut is missing? The car is on my lift and the spare tire and liner near the windshield are removed.
  14. Lawrence Coppari
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    Hood badge is tight but there might be two nuts and adhesive that hold it.
  15. Rifledriver
    37,122
    The horn uses spade connectors. No hardware needed.
  16. buzzdoc
    buzzdoc Karting
    Oct 28, 2016
    56
    Georgia
    Michael
    The 2 nuts that hold the horn compressor together may be as small as 5mm, but I don't recall them being brass. It's been a month or two since I had my compressor apart cleaning/lubricating it.
  17. Lawrence Coppari
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    How do I get to it? There is a horizontal plate in front of the front wheel secured by a number of screws. Do I remove the plate to get at the compressor?
  18. Lawrence Coppari
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    I'm beginning to think this may have been road trash that somehow got into the channel. There were some small pebbles in there too.
  19. buzzdoc
    buzzdoc Karting
    Oct 28, 2016
    56
    Georgia
    Michael
    Don't know if the location is the same on your QV (mine is an 82 GTSi), but the compressor pump is right behind the radiator on the right side in front of the spare tire compartment. There was nothing to remove to get to my pump. 2 nuts and it comes right off.
  20. Alden
    Alden F1 Rookie
    3,631
    Central Florida
    Where I come from the "loose nut" always belongs behind the steering wheel. :)
    Alden
  21. Lawrence Coppari
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    Compressor is located inside the driver side fender on my 1987 GTS. Hope to get a good look at it today but I think it has spade connectors as RD indicated. If it has no nuts, I'm going to assume the brass nut was road trash.
  22. wildcat326
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    It does have spade connectors for the power supply, but also has mounts to secure the thing to the frame. As Rifledriver mentioned, though, brass not used for general purpose fasteners. Which leads me to...
    Stupid question: You sure it's brass and not yellow chromate plating, which was standard in these cars?
  23. Rifledriver
    37,122
    Mounting fasteners are not 5mm.
  24. Lawrence Coppari
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    #24 Lawrence Coppari, Feb 9, 2017
    That's what I also think because it would be rather puny. And it is a 5mm .8 pitch because that is what tap fits it perfectly.
    A magnet does not attract it. Here's a picture.
  25. Lawrence Coppari
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    Now that I look at the posted picture, the color is a little off. It has more a yellow tone to it. Ruler is an inch ruler.
