Small ground clearence pf NNO | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by noviyecco, May 15, 2007.
  1. noviyecco
    noviyecco Formula Junior
    376
    Ukraine,Kyiv
    Peter Fromel
    Which solutions are there of that problem?
  2. Scuderia-San-Antonio
    Feb 27, 2005
    1,567
    San Antonio
    Wes
    Are you calling Carbon short? ;)
    My translator must be broken, this **** be gettin old...
  3. noviyecco
    376
    Ukraine,Kyiv
    Peter Fromel
    ...what do you mean?
  4. ^@#&
    ^@#& F1 World Champ
    12,091
    is that the translation?
  5. MGD416
    MGD416 Formula 3
    Jun 4, 2006
    2,385
    yeah what the hell are you talking about, no abbreviations please, just english words
  6. rmk
    rmk Formula 3
    Mar 24, 2002
    2,409
    Please.... Call it an Enzo.
  7. Tobias
    Tobias Formula 3
    May 22, 2004
    1,683
    NY
    I thought the Enzo had the capability to raise its nose to make traveling over speed bumps and inclined entraceways easier?
  8. TexasMike
    TexasMike F1 World Champ
    Feb 17, 2005
    10,485
    Austin, Texas
    Michael C
    It does
  9. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #9 Napolis, May 15, 2007
    The Enzo has a lift system that works under 15 MPH that can help get you over speed bumps and onto driveways. A very important dimension is the distance from the tip of the nose to the center of the front wheel the shorter coupled with curving up of the bottom makes a huge difference and makes a car much more drivable on the street. 60ies race cars had shorter front overhang and were curved up but this wasn't too efficient aerodynamically and required winglets "Canards" The Enzo is more modern in design which is better aerodynamically but harder to drive on the street. This was a big issue we addressed in P 4/5. We shortened front overhang, curved up, and used winglets. This is one reason P 4/5 is much more drivable on the street than an Enzo.
    Compare the Noses and you'll see the difference. Note how long and flat front overhang is on FXX/Enzo vs P 3/4 vs P 4/5 which is inches shorter than the Enzo's front overhang and unlike the Enzo curves up.
    On the track this isn't an issue but keep in mind as you reach 300KPH the downforce pushes the body towards the ground which can also become a clearance issue.
  10. MGD416
    MGD416 Formula 3
    Jun 4, 2006
    2,385
    I see what you mean, it makes sense, the p4/5 is just a great car performance wise, style wise, and practicality wise, it is a killer car created originally by a great company and then made better by their consumer, it is fantasic.
    I didnt really understand the guys question but now I got it
  11. ^@#&
    ^@#& F1 World Champ
    12,091
    #11 ^@#&, May 15, 2007
    cool
  12. rossocorsa13
    rossocorsa13 F1 Rookie
    Jun 10, 2006
    2,557
    Nashville, Tennessee
    M
    Jim, did you let Top Gear put test numbers down on your car? I thought you said you wouldn't let anyone actually run it through the normal series of benchmark automotive tests. And how current is that issue, and, more importantly, did they film it?
  13. darth550
    Jul 14, 2003
    61,125
    In front of you
    BCHC
    #13 darth550, May 15, 2007
  14. RoWis
    RoWis F1 Rookie
    Apr 19, 2006
    4,845
    Vancouver, B.C.
    Damn man your P4/5 in really low in that pic!
  15. Pav
    Pav Formula 3
    Jan 18, 2006
    2,159
    Warsaw, Poland
    Michal
    HAHAHAHAHAHAHA, this is tight!
    Very informative Jim, thumbs up!
  16. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    That came out last fall. It was filmed by French TV and Rene Arnoux who also tested it was interviewed by Top Gear as well. That track was only good for 200 mph but P 4/5 will top out at 233. It's top end is only higher than an Enzo's because it has a higher rear ratio due to taller tires. An Enzo will pull it's red line in top gear as well but due to lower gearing will "only' reach 225. 0-100 KPH P 4/5 is about 3.2 seconds which is a touch faster than a Enzo due to lower weight.
    At speed down force lowers the car considerably. At speed a Veryon lowers to about 2.5 inches.
    On the street rear overhang is also important. The shorter the more drivable.
    The Veryon has very short front and rear overhang and doesn't need a lifting system to keep from scraping. If you look at off road vehicles you'll also see short over hangs as you will on WRC's. It's interesting to note that the 288 GTO was originally designed as a "Killer B" Rally car but was never raced. I'm not sure it's front overhang vs a 959 Porsche would have worked so well.
    This is an issue with all Street Driven Supercars. A lifting system helps as does an angled aproach to driveways. Some have installed teflon nose tip skid plates which might help.
    Peter
    How are the roads near you? Is this a big issue?
    Your English is fine.
    Проигнорируйте людей оскорбляют вашу английскую язык.
    Best
  17. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
  18. MGD416
    MGD416 Formula 3
    Jun 4, 2006
    2,385
    now I realize what an ass i sounded like, sorry peter didnt realize your were from the ukraine
  19. noviyecco
    376
    Ukraine,Kyiv
    Peter Fromel
    Thx for advice,I will,most of the roads are in bad conditions,only 2 in perfect condition here ,Kyiv:
    1)direction to inter.airport Borispil
    2)to Luxury Village Konche Zaspa
  20. JMOrem
    JMOrem Formula Junior
    Jun 7, 2004
    322
    Frisco, TX
    Jared Orem
    Good God. I had no idea.
  21. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Put's that car in a totally different light. I still rue the day I didn't snap up a Paris to Dakar 959 that Jackie drove to 5th oa for 175K...
    MGD 416
    Who there among us hasn't at times...
    Best
