Small leak from pumpkin | FerrariChat
Discussion in '348/355' started by vinny, Sep 17, 2017.
  1. vinny
    vinny Karting
    Nov 1, 2003
    167
    R.I.
    Vincent Pitocco
    I have a small leak dripping off the bolts on the pumpkin. The fluid is clear. Would it be hydraulic fluid for the clutch? What would be probable cause?…thanks in advance Image Unavailable, Please Login
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Could be clutch fluid (likely) or flywheel grease.
    Might be throw out bearing seals
  3. vinny
    vinny Karting
    Nov 1, 2003
    167
    R.I.
    Vincent Pitocco
    Do you think I could get the rest of the driving season out of it before I repair it
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Likely it wont hurt anything for now but that is a straight out guess because anything could happen.
    Why not just take it apart, not too difficult and have a look, then you can tell us if it will make it the rest of the season.
    This way you can see it is not anything major.
  5. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Well, you are in the NE so we don't have more than 6-8 weeks at best left, so likely yes. I'm Assuming this is a gated car? If so, check the brake fluid level (non F1 share the same resivior for brake and clutch)
  6. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Either a leaky throwout bearing, leaking triple seals, or both. You'll have to remove the clutch bellhousing to inspect, and see for sure what it is.
  7. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    I wouldn't recommend continuing to drive around under the circumstances. Diagnosis is as stated above, and not a particularly difficult repair ( there are numerous threads and videos on DIY repair and the parts are cheap). As I recall, I believe the pipe coming off the brake fluid reservoir for the clutch is high up, so it doesn't take much of a leak on a longish drive to get air into the line and then you're stuck. For 3 or 4 hours work and $150 or less worth of seals and fluid not worth the risk.
  8. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,332
    Atlanta, GA
    Steve D.
    Plus if it is the triple seals (which would be a good idea to do while you're in there), more leakage just leads to having to do a flywheel service.
    sjd
  9. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,662
    San Carlos, CA
    Mitchell Le
    welcome to the throw out bearing leak. If your TO bearing needs replacement, it is not a cheap part.
  10. vinny
    vinny Karting
    Nov 1, 2003
    167
    R.I.
    Vincent Pitocco
    I just viewed your thread on bellhousing removal....very helpful!...thanks for posting!
  11. vinny
    vinny Karting
    Nov 1, 2003
    167
    R.I.
    Vincent Pitocco
    The leak stops after a few drips and starts again after a drive.....I will check it out and post what I find.....thanks for all the replies
  12. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    As long as it's only a few drips and you keep an eye on the level, you will be ok until the crap weather comes.
    vinny likes this.
  13. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Glad it helped.
    Keep us posted on what you find.
  14. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I agree if its a few drips and only when hot likely not ahuge problem but then keep a close eye on it.
  15. AceMaster
    Feb 6, 2009
    34,782
    Ontario, Canada
  16. vinny
    vinny Karting
    Nov 1, 2003
    167
    R.I.
    Vincent Pitocco
  17. m.stojanovic
    m.stojanovic F1 Rookie
    3,297
    Serbia - Niš
    Miroljub Stojanovic
  18. vinny
    vinny Karting
    Nov 1, 2003
    167
    R.I.
    Vincent Pitocco
  19. MD Clutches
    MD Clutches Rookie
    Jul 31, 2017
    3
    Andrew Holman
    Easy way to tell fluids apart, is one mixes with water ie brake fluid, one doesnt ie gearbox oil.
    both will start to contaminate your flywheel grease as some will travel down the shaft and into dual mass system when driven. Oil will also contaminate yoru clutch plate and it doesnt come out.
    So I always suggest sooner rather than later.
  20. yelcab
    Nov 29, 2001
    13,662
    San Carlos, CA
    Mitchell Le
    You know, I think Eurospares sells triple seals that are Viton now. The seal is pliable, and does not need the heat and shrink and wait method the crazy Ferrari engineers designed in. What a design ! I can see it now. Hey it is leaking, and one seal is not enough, how about three! Si, that is going to do it.
    vinny likes this.
  21. AceMaster
    Feb 6, 2009
    34,782
    Ontario, Canada
    Thanks, you can do it...it's not a difficult job, just takes time and patience. ;)
  22. AceMaster
    Feb 6, 2009
    34,782
    Ontario, Canada
    Easier way than that - one is black and very stinky (gear oil), one is clear/orangey and a little bit sticky (especially when dry) and almost scent-less (brake/clutch fluid)
