Small parts syndrome | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by oofazi, Feb 28, 2014.
  1. oofazi
    oofazi Karting
    Apr 13, 2013
    71
    Salisbury UK
    #1 oofazi, Feb 28, 2014
    Chaps,
    In your annals of knowledge of part numbers, can you tell me what the part numbers for the parts of my car are please? The frim I have gone to are a well know breakers, but they directed me to their website which not only shows limited resolution on the exploded views, so you cannot discern what the part is supposed to look like in artists hand, some I do not believe are on the exploded views at all!
    I am after the following which I sent directly to the firm:
    1. heat control slider surround in black plastic, showing 2 dots for hot and cold. I need 2.
    2. aerial surround/ screw down cap that finishes this off properly - I need 1.
    3. bottom screw in rear quarter light metal surround missing - I need 1.
    Does any one know what these part numbers are?
    Thanks in advance.
  2. dstacy
    dstacy F1 World Champ
    Jan 23, 2006
    11,998
    GMT -5 & GMT +1
    Dave
    257-86-198-00 is the whole control, you can't buy just the trim
    107472 is the entire antenna, sorry again no trim available
    There is no screw listed in the parts manual for your side window trim. It is a stainless steel screw.
    Hope that helps
  3. Ashman
    Ashman Three Time F1 World Champ
    Sep 5, 2002
    33,280
    MA
    For the screw, just take out one of the others and take it to any good hardware store, which should have a supply of the right metric size in stainless steel to match. Don't tell the clerk at the checkout that it is for a Ferrari! ;)
  4. rustytractor
    rustytractor Formula 3
    Mar 25, 2012
    1,078
    London
    Russell Schacter
    I've needed an aerial base surround screw for my 400 since I got it but I don't think it's as simple as buying one based on a part number.
    Last year at Silverstone Classic there were at least 7 365/400/412's which is the most I've seen in one place. I deliberately checked all of the aerials for continuity - there was none as each aerial was different. I think 2 of the cars may have had the same type but it was different to mine so odds are most of these had been replaced at some time over the years.
    Either that or ferarri just threw in whatever was available at the time which wouldn't surprise me at all.
  5. oofazi
    oofazi Karting
    Apr 13, 2013
    71
    Salisbury UK
    Thanks for your replies so far.....
    A well known breakers has just tried to charge me £93 for something called 'air duct' , with no screw or aerial cover in stock.
    For which I have set the same photos to you all.
    I am FAR from impressed, what other GOOD breakers do you know?
    I need to know.....
    Thanks in advance.....
