Smart guys out there please verify my timing procedure | FerrariChat
Discussion in '308/328' started by [email protected], Aug 14, 2009.
  1. andy2175m4@yahoo.com
    [email protected] Formula Junior
    Dec 7, 2008
    473
    Los Angeles, CA
    Andy Rein
    IF: All is well, and all you need to do is change the timing belts, here is my brief summary of how to set the timing of 4 cams, 2 belts and 1 crank: Tell me if I am wrong:
    1. remove spark plugs, remove flywheel peek-a-boo cover, rotate crank to set flywheel at 1-4 TDC timing mark.
    2. remove cam covers, visually verify 4 cam notches line up with 4 cam bearing cap notches.
    3. clamp cams with wood clamps.
    4. compress belt tensioners, remove old belts, install new belts, release belt tensioners.
    5. visually verify flywheel is still on 1-4 TDC timing mark.
    5. visually verify 4 cam notches line up with 4 cam bearing cap notches, tweak cam pulleys +/- 1 belt cog or so, as required, to perfect aligment.
    6. slowly rotate crankshaft 360 to verify no valves are hitting pistons.
    Is this correct ? I just read the WSM and that's how it seems to me.
    The guy trying to reassemble his engine had a piston getting cozy with a valve...seems to me the above would be the way to line it up.
  2. Harry
    Harry Karting
    Nov 1, 2003
    101
    Germany
    #2 Harry, Aug 14, 2009
    Just some remarks:
    - since the cam cover is open, you should verify valve clearance and adjust if necessary
    - it might be worth to replace the oil seals (for this, either cams or pulleys need to be removed)
    - to "tweak" the timing, the pulleys need to be removed and you have to play the "pin in one of the holes"-game. If you start this, the use of a degree wheel and a dial indicator are essential for proper results. Interesting stuff, but as a beginner, take your time. Start to measure time now by days, not hours. Reminder: You will need a new o-ring and locking washer for each cam pulley.
    - you forgot to tighten the tensioners after rotating :)
    Regards
    Harry
  3. mustardfj40
    mustardfj40 Formula 3
    Jun 17, 2004
    1,142
    Northen California
    Ken
