smoke from Gallardo engine | FerrariChat
Discussion in 'LamborghiniChat.com' started by happyboy, Jan 14, 2010.
  1. happyboy
    happyboy Rookie
    Apr 30, 2009
    35
    Santa Barbara, CA
    FARHAN MIRZA
    I had a funny incident. drove the Lambo Gallardo upto 90 Miles an hour for 2 miles and parked in the driveway. Heard a spray like noise and smoke come from the engine compartment for a few seconds. Nothing when the hood was opened and after a few seconds the symptoms went away. Drove after than at did the diagnostics check on the dash and no problems. All gages are normal.
    Any suggestions on waht it could have been.
  2. ilconservatore
    ilconservatore F1 Veteran
    May 18, 2009
    8,369
    Cincinnati Ohio
    Did you notice any odors? If its an e-gear car first guess would be a pinhole leak in the high pressure hydraulics that burnt off on the exhaust?
    Maybe an oil cooler line doing the same thing?
    There are also some helpful techs on the ********** forum if you don't get it solved here
  3. ilconservatore
    May 18, 2009
    8,369
    Cincinnati Ohio
    Oh, I'm not allowed to say that word here? Ok, then...
  4. wingfeather
    wingfeather F1 Rookie
    Feb 1, 2007
    3,653
    rock bottom
    Coolant overflow? I'd look into it.
  5. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Definitely sounds like water from somewhere sizzling off of a hot manifold. It could be as simple as leftover water from washing the car that found it's way there or coolant overflow as the previous person suggested.
  6. UroTrash
    Jan 20, 2004
    40,487
    Purgatory
    Clifford Gunboat
    That would have a pretty distinctive smell wouldn't you think?
  7. GuyIncognito
    99,818
    I would think water from washing the car or driving through water on the street seems most likely. anything else would have a distinct odor and/or smoke, or there would be a puddle under the car, low coolant/oil warning, etc.
  8. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    You would think so but if you were outdoors with a breeze and stood upwind?
  9. speedy
    speedy Formula Junior
    Oct 18, 2005
    625
    Plano, TX
    James Gardner
    Farhan,
    I found your problem and it's bad news, buddy. You have to have your motor rebuilt.
    Just kidding. Give us a little more to go on. Smell anything funny? Any idea where in the engine bay it came from? It literally could be a host of things. It's probably nothing serious but you have to find out where it's coming from.
    Drive your car again and see if it happens. If it does, let us know more details.
    Good luck.
  10. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    951
    Arizona
    Jim
    Check all your fluid levels first, it may help you focus your search. Plus you don't want to cause any damage if something is low.
    Cheers Jim
  11. happyboy
    happyboy Rookie
    Apr 30, 2009
    35
    Santa Barbara, CA
    FARHAN MIRZA
    thanks for the responses folks., Its a stick shift No odors, no leaks or puddles even after 30 hours. Drove it for 10-15 miles and could not replicate. No odors of any kind even when idling in the garage for 5 min. Pretty strange though. The only think was I had the A/C low on the lowest setting and the temp outside was 62 degrees. All gages are normal. The steam came from the vents clsoe to the rear mirror, when I got open the engine hood, there was nothing visible and no replication.
  12. Five
    Five Formula Junior
    Jun 15, 2006
    443
    Silicon Valley, CA
    My 2 cents.
    I wouldn't let it slide. I'd get it checked out with a mechanic. Have him look through the engine for signs of any leak and have him run the car and again look for a leak. If he does a good job and can't find anything then let it go but keep an eye open in case it happens again. Also, run it for a bit outside and check under it and check the ground for anything dripping (you said you did but check inside the engine as well, although you probably did that too).
    I would bring it in, though, so they can lift it and look under it, etc. An oil leak can cause a car fire. A leaky water hose will go eventually.
  13. TheGasman
    TheGasman Karting
    Oct 16, 2007
    193
    Ventura, CA
    Gasman
    Farhan, could it have been water from or recent rain? Is the car going back to the shop soon anyway?
    We need to get together for a drive soon. I have a few friends with Porsches in town that are interested.
  14. 96cobrakid
    96cobrakid Formula Junior
    May 24, 2004
    802
    St. Louis, Mo
    Chris
    water from having the AC on?
  15. Skipper
    Skipper Formula Junior
    Sep 24, 2006
    451
    Frank Drebin
    sounds like you have had some issues with the gallardo
    how do you like the car overall?
  16. pdisme
    pdisme Formula 3
    Oct 9, 2006
    1,036
    Tampa, Florida
    Dave
    Was the smoke from the engine compartment or the front trunk area? You initially said engine and then you said near the rear view mirror which is the opposite end of the car. If it came from the front it could be a leak in one of the front-mounted coolers or A/C system since that's about all that's up there other than windshield fluid and battery.
    What were the water temps looking like if you recall after your initial drive that produced the smoke?
