Smoke in Engine compartment - Need Help! | FerrariChat
Discussion in '348/355' started by TrojanFan, Dec 30, 2013.
  1. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,179
    So. CA & NV
    Peter
    I went to start my 355 this morning and I heard a squealing sound similar to a belt slipping for about 5 - 8 seconds then it changed to a very high pitched tone and smoke started coming from the left side of the engine compartment. The smoke had a burning rubber type smell and seemed to be coming from the area near the left side exhaust manifold shield. Couldn't really tell exactly where. I immediately shut the engine down ant the smoke cleared so no fire. I'm assuming that something was rubbing on something else.
    The last 3 - 4 times I have started the car in the morning I had the same squealing for 5 - 8 seconds and then it went away and the car drove fine. No smoke or burning smell. I had assumed that it was something slipping due to it being cold (in the 40's) as afternoon starts when warmer produced no squealing.
    Before I start tearing into something I know little about, anyone have any suggestions on what I should be looking for?
  2. Kaivball
    Kaivball Three Time F1 World Champ
    Jan 11, 2007
    35,997
    Kalifornia
    My unscientific opinion is that something has seized and the belt is rubbing on it/over it.
    - belt tensioner pully
    - water pump
    Kai
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,624
    San Carlos, CA
    Mitchell Le
    Very bad boy of you not to investigate further.
    Left side of the engine has timing belt for 5-8 bank, and AC compressor.
  4. Kaivball
    Jan 11, 2007
    35,997
    Kalifornia
    Ha, that's right. Maybe the AC compressor seized...
    Kai
  5. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    This is something to check into NOW! If it's the A/C compressor it's not a real difficult fix. If it's the water pump or timing belt tensioner, the engine comes out.
    This isn't something you can afford to ignore.
  6. TrojanFan
    Nov 17, 2008
    5,179
    So. CA & NV
    Peter
    Not planning to ignore. I'll check on the AC compressor first. Major was done about 18 months ago so I'm keeping my fingers crossed that's not the issue.
  7. TrojanFan
    Nov 17, 2008
    5,179
    So. CA & NV
    Peter
    What's the best way to access the AC compressor? Jack up the rear and access from below? I looked but could not find any AC removal threads.First thing I need to do is see if that belt is making the burning and smoke.
    I was having no ac issues prior. Suggestions for checking the AC compressor condition while still on the car? If it is not seized, will it turn by hand with the belt removed?
  8. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    I thought that the alternator was on the driver's side and the AC compressor on the passenger's side.
  9. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Check your p/s belt
  10. fatbillybob
    Aug 10, 2002
    29,163
    socal
    Party at Peter's house let's take it apart! Sounds like bearing seized then belt friction burning on the pully. Don't start the car any more until it is diagnosed. Some things are engine catastrophic. Some things are simple and cheap like $150 rebuild and a new belt. Get the number of the belt to me or Plugzit because we may have the belt in hand. Also, plugzit might have bearings too.
  11. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    Get under there and see what belt is burned up.
    If you take off the belt the a compressor clutch should turn freely it's it engaged so it just spins and spins...
  12. plugzit
    plugzit F1 Veteran
    7,785
    Redondo Beach, CA
    Bruce Bogart
    Do you start the car with the AC on? If not, it's probably not the ac compressor. Yes, immediate attention is required. As for the recent major, it may or may not have included the tensioner bearing for that belt. I suspect not, and that's (hopefully) the problem, as it's a cheap and relatively easy fix. Also as to the recent major, it's hard to know if a bearing is "about to fail", whether a week, a year, or five years, so if that bearing in the, let's say, alternator, goes bad six months later, then you really can't blame it on a sup-par service. What I'm saying is that just because it had a major service doesn't mean that something can't go wrong later.
    BTW, squealing belts and bearings, even for a second, always requires immediate attention to identify the guilty party. Something is dead.
  13. yelcab
    Nov 29, 2001
    13,624
    San Carlos, CA
    Mitchell Le
    Ferrari swapped sides from 348 to 355. Must have something to do with the single t belt and double t belt packaging.
  14. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    I suspect if you remove the A/C compressor belt and the alternator belt and give both a good whiff, you'll be able to tell just from that if either are involved in the problem. Hard to mistake the smell of burnt rubber.
  15. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    That sounds like a bad bearing to me. I would not start the car anymore. Check the simple things first, alternator tensioner bearing, a/c pulley. If those check out then it could be an engine out deal to replace the tensioner bearings, idler bearings, and or the water pump.
  16. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    I don't think anyone answered but you could turn them with tools but my opinion is without taking off the belt you won't be able to feel if a bearing is gone or going. Also no buddy mentioned this but if you coolant dripped on a belt it will squeal for a long time.
    I replaced my coolant thermostat and spilled some coolant down onto belt this caused squeeling belt. Possibly a coolant leak?
  17. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Of course after reading your op again probably should not start smoking from a slipping belt aventually the heat would provide enough friction the pulley should start to turn.
  18. TrojanFan
    Nov 17, 2008
    5,179
    So. CA & NV
    Peter
    No coolant leak or any other leaks that I have noticed. I haven't had the chance to check things out yet. Maybe Saturday.
  19. FlyingAces
    FlyingAces Formula Junior
    Jun 2, 2011
    849
    LA 2 Vegas
    Joejoe
    I used to have these squeaks come and go. I forget which belt was the culprit but I know the sound went away when we tighten the tension on the accessory belt. Doesn't mean you don't have a bearing failure, just the issue with mine. Check that **** bro,
  20. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    A loose belt will certainly squeal like a stuck pig, but typically won't generate smoke like he complained about. That's usually a belt being drug across a non moving part thus generating lots o' heat and friction.
  21. RS6bird
    RS6bird Formula Junior
    Mar 20, 2006
    316
    Lisbon, Portugal
    RS6Bird
    When my car did that, it was a bearing in the gearbox that gave up and caused a part of the casing to break, in turn letting oil out onto a hot engine, provoking smoke. Obviously the initial reaction or thought was water pump/AC, but in the end, it was the gearbox. The result was a damaged central shaft and the decision to substitute the whole gearbox with another one. Now the car runs fine.
    I recall that the squeal in my case was related to speed but not revs, not sure how a water pump or AC bearing failure would react to rpms.
    Good luck and keep us posted.
  22. FlyingAces
    Jun 2, 2011
    849
    LA 2 Vegas
    Joejoe
    keep us posted
  23. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
  24. TrojanFan
    Nov 17, 2008
    5,179
    So. CA & NV
    Peter
    I haven't had the chance to get under the car yet, but assuming that it is the clutch bearing for the AC Compressor, is that something that can be removed with the compressor still on the car? I'd like to avoid having to mess with the refrigerant if I can avoid it.
    Any suggestions on pulling the clutch? I see in the shop manual it calls for a puller. Can that be done with it on the car?
  25. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    No.
