Smoke in Engine compartment - Need Help! | Page 2 | FerrariChat
Discussion in '348/355' started by TrojanFan, Dec 30, 2013.
  1. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,203
    So. CA & NV
    Peter
    So the AC system needs to be drained and the compressor removed to get the job done?
  2. TrojanFan
    Nov 17, 2008
    5,203
    So. CA & NV
    Peter
    #27 TrojanFan, Jan 5, 2014
    Finally got some time to get under the car today and the AC belt seems to be ok. It's looking more like the tensioner on the alternator belt side may be the problem. The tensioner has black rubber streaks on it and the top side of the belt, which runs along the tensioner is rough in places like it had melted some. Before I pull off the tensioner and the belt, can someone concur with this novice's assessment?
    Funny that the smoke was coming from the left side of the engine (AC side) when the alternator tensioner is on the right. Maybe blown that direction from the engine rotation?
  3. fatbillybob
    Aug 10, 2002
    29,472
    socal
    Take belt off and feel the parts individually. You can feel rough and sticky bearings. Post a pic of what you find. You may be able to sidestep Ferrari and fix it quicker and cheaper with bearing sourced from
    King Bearing Inc
    701 W Anaheim Street
    Long Beach, CA 90813
    Phone: (562) 437-2201
  4. AUSMANPORFER
    AUSMANPORFER Karting
    Feb 23, 2009
    89
    Lourosa
    Leandro Pereira
    Pelo que foi dito o problema esta no rolamento esticador ou no alternador. A solução e cortar a correia e depois com a mao fazer girar ambos. Um deles não vai girar rolamento esticador ou alternador
  5. Carbuilder
    Carbuilder Formula Junior
    Aug 18, 2012
    550
    Bolton, ON
    Rick
    Exactly what I was going to say.
  6. TrojanFan
    Nov 17, 2008
    5,203
    So. CA & NV
    Peter
    I appreciate the response, but not really much help.
  7. Dino Chang
    Dino Chang Guest
    Dec 29, 2012
    772
    Using google translate, I got the gist of what AUSMANPOFER was saying. It was a valid idea.
  8. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    FYI the loose translation of the above message reads: from what has been said the problem is the tensioner bearing or the alternator. The solution is to remove or cut the belt and rotate both. One of these will not turn.
  9. AUSMANPORFER
    Feb 23, 2009
    89
    Lourosa
    Leandro Pereira
    Correto uma vez que há goma de borracha no rolamento do esticador a avaria esta no rolamento que esta agarrado e a situação e a seguinte: a correia esta em movimento e em contacto com o rolamento este devia girar mas como esta preso a correia ao girar em alta rotação com uma parte fixa aquece chia e faz a dita fumaça e em caso de insistir pode mesmo arder. Motivo porque no 1º post referi cortar a correia porque a mesma tem que ser substituída.
  10. TrojanFan
    Nov 17, 2008
    5,203
    So. CA & NV
    Peter
    Bestilt et nytt belte og peiling i dag. Når jeg har dem i hånden vil jeg komme tilbake under bilen og kuttet den gamle remmen og se hva bevegelsen på dynamoen ser ut. God eller dårlig, i alle fall beltet og strammer peiling må skiftes.
  11. Dino Chang
    Dino Chang Guest
    Dec 29, 2012
    772
    Ja, er fantastisk enhet google translate. Det gjør at du kan faktisk lese hva folk sier, uavhengig av nasjonalitet. Verden er faktisk et mindre sted med bare et klikk. :)
  12. AceMaster
    Feb 6, 2009
    34,797
    Ontario, Canada
    Google translate:
    From what has been said on this issue tensioner bearing or the alternator. The solution is to cut the belt and then rotating the hand both. One of them will not rotate tensioner bearing or alternator
  13. TrojanFan
    Nov 17, 2008
    5,203
    So. CA & NV
    Peter
    Sant nok, men jeg kan faktisk lese noen av de norske. Tre år med High School språket blir tatt i bruk.
  14. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,300
    CT
    John Kreskovsky
    Я думал, что это был Английский выступая форумом.
  15. TrojanFan
    Nov 17, 2008
    5,203
    So. CA & NV
    Peter
    不知怎的,我們離題。我們會盡快給英語
  16. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    ALLRIGHT CHILDREN, STOP PLAYING WITH YOUR MASHED POTATOES AND COMPUTER TRANSLATORS!!!
  17. Dino Chang
    Dino Chang Guest
    Dec 29, 2012
    772
    Good job the Italians use translators, or 99.99% of use will come un stuck when we need parts or are reading the work shop manuals :). Mind you following the WMs and seeing how many inaccuracies are printed, one has to wonder if they even bother with translators :)
  18. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    So peter what was problem
  19. phrogs
    phrogs F1 Veteran
    7,379
    Kzoo Michigan
  20. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    Yup. Nothin worse than doing a search and finding these unfinished
  21. phrogs
    phrogs F1 Veteran
    7,379
    Kzoo Michigan
    Yeah but people dont always do that, and some people have moved on I havent seen the op here in a while.
  22. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    No, other way around unless a UK car.
  23. RandyT
    RandyT Formula Junior
    Aug 16, 2016
    258
    Calabasas, CA
    Randy T
    This thread sure took a strange turn. o_O Peter, what was the problem?
  24. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,060
    Indio Ca/ Alberta
    Grant
    I knew he's likely listening
    Come on Peter
  25. TrojanFan
    Nov 17, 2008
    5,203
    So. CA & NV
    Peter
    Sorry guys. Dragging this out from 4.5 years ago.
    It was the bearing for the ac belt that had worn out and locked up causing the belt to smoke when being pulled around it. Somewhat dufficult to get to but a relatively inexpensive fix
