Smoke | FerrariChat
Smoke
Discussion in 'Mondial' started by jose190sl, Nov 9, 2018.
Tags:
  1. jose190sl
    jose190sl Rookie
    Dec 4, 2015
    8
    Hello my Ferrari Mondial 1981 start making smoke, I replace the valve seals and guides and I made service to the 3 head engine parts. After I finish the job the car still make a lot of smoke, I am thinking it may be a valve or check that is sending oil to the combustion chamber, can somebody make a comment.
    Thank you
  2. moysiuan
    moysiuan F1 Rookie
    4,093
    Canada
    What type of smoke? ie. White, blue, black, smells of oil , sweet smelling (coolant), fuel smell, etc.?
  3. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    Do a compression test. Squirt a little oil into each cylinder through the spark plug hole and test again. If the compression readings go up with the oil added, you have worn rings/cylinders. This can cause smoke in the exhaust.
  4. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
    Compression test is always good. As mentioned it can be only 3 types of smoke. Depending the color you should take different actions.
    1. coolant = white and smells usually sweet
    2. oil = blue
    3. fuel = greyish
    obviously you can have a mix of each.
  5. moysiuan
    moysiuan F1 Rookie
    4,093
    Canada
    Since you had the heads off for service, I will make a wild guess that its the head gasket not sealing, and you are getting some sort of coolant blow by into the exhaust. If the car was not smoking prior to the head service, it is probably not a piston/ring problem. Might make sure the head is torqued down correctly, the procedure for torqueing is in the workshop manual.
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    Is there a breather from the rocker boxes to a connection on the inlet manifolds with a valve in the line, a few years since my mondial. If it is obstructed it will not be drawing off the crankcase pressure. I cannot recall the setup but worth a look
  7. jose190sl
    jose190sl Rookie
    Dec 4, 2015
    8
    Hello, I just found that my injectors are sending to much gasoline the upper part of the engine head was full of gasoline, I will check the injectors, do you think this may cause the smoke?
  8. moysiuan
    moysiuan F1 Rookie
    4,093
    Canada
    Sounds like ignition problems, not fuel delivery.
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    I take it, this has the bosch k tronic injection system. ? I have seen something similar where the balance of the fuel delivered to each cylinder was wrong, the engine was misfiring and making smoke- also the oil level in the sump increased, this being due to excess fuel to some cylinders that was washing past the piston rings into the sump.
    The fix was to get an overhaul kit for the injection system distributor head( the casing on the right rear in the engine bay with all the small injection lines atteched to it) turned out this has a diphragm inside that had split, so the fuel supply to each unit was wrong, some cylinders were getting max fuel. The kits can be found on e bay, look on the side of the casing for a bosch number and google it
  10. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    There is still interest in which color smoke and what it smells like :) but too much fuel is not good and is a possible cause for smoke. Can you make a video of te smoke?
    If they are still the first injectors you might want to swap them for new as they wear out at some point. Cleaning these old injectors does not make sense if I may say so.
  11. Streetsurfer
    Streetsurfer Formula Junior
    Dec 16, 2015
    934
    near Chicago
    Ron
    I think it was a bosch unit the 22r used when they added first added the turbo to that engine, circa 86. I had issue with the cold start injector which made it smoke and sputter, spit excess condensation and fuel out, then it got really bad quickly when extreme cold came on. The fuel dilution of oil is not good so do check that and attend to it quickly if it is.
  12. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    Have you tried putting injector cleaner in the fuel yet, it might be worth a try. My mondial used to have the engine cut out when slowing down for a junction, ie coming off the throttle and braking.
    I was not getting any other indication like smoke etc, but a treatment of injector cleaner yearly sorted it out.
    Re changing injectors, mine had the same injectors from the factor in 1987 to 2013 when i sold it, it was still going great guns.
  13. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    I think that it is an excellent suggestion. You can disable the cold start injector by unplugging it on the air house (blue connecter) then at least you know that it is getting fewer fuel when starting cold. Keep in mind that this system supposed to work with this injector so eventually you need to find the root cause.
  14. jose190sl
    jose190sl Rookie
    Dec 4, 2015
    8
    Hello, I send the injector to the Bosch place and the clean and told that it was 3 injector in bad condition, the already fix the injectors and I bought the repair kit for the fue distributor, I will try and I will let you know the results and I will send a video too.
  15. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    Tijn
    There you go! I guess it is just part of the solution though. Ps. It common practice to replace all injectors and they are not so expensive. Old ones have a habit to fail much quicker then new ones even when they are cleaned in a sonic bath.
    For the fuel distributor you will need to have a micrometer. keep in mind you cannot just rebuild it although it seems only rubber O-rings and metal plates. I do think it is a good idea as it is just old rubber inside. Recently I helped out to rebuild a Porsche 924 where the injectors kept on providing the maximum fuel flow even when the flow plate was in it's default position (stationary). all 4 rubber O-rings deteriorated. Have a look on youtube. If they do not work with a micrometer then dismiss such videos.
  16. jose190sl
    jose190sl Rookie
    Dec 4, 2015
    8
    Hello guys, I am panic...…. the fuel distributor and the injector has been rebuild now my problem is the fuel FLOW, how can I adjust the flow, I to much pressure please can somebody tell me how to fix it like kindergarten
  17. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    Put a search in google for the bosch k tronic fuel injection system, it will explain how it works
  18. jose190sl
    jose190sl Rookie
    Dec 4, 2015
    8
    Hello I fix the injectors, the distributor has been rebuild but now I have a fuel flow problems, how can adjust the flow, the micrometer is a good idea but I do not know where to use or what should be measured, I am not an expert so if somebody know where can I see the procedure or a video I will appreciate a lot the help
  19. jose190sl
    jose190sl Rookie
    Dec 4, 2015
    8
    Hello I will do that, at the explanation they show how to adjust the flow and all the things I need to know?
    Thank you
  20. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    The uk volvo owners site has a good write up, lots of others as well. You need to understand how it works before you start messing with it
  21. jose190sl
    jose190sl Rookie
    Dec 4, 2015
    8
    Please confirm if I am correct, the flow will be adjust with the air valve with the screw at the top of the unit?
  22. spicedriver
    Feb 1, 2011
    3,859
    The "mixture adjustment screw", which is located in the middle of the "mixture control unit", and is adjusted with a 3 mm hex head, is for idle mixture. Running mixture is set by the pressure difference between "system pressure", and "control pressure". System pressure is adjusted by adding/removing shims from the "control pressure regulator". Cold control pressure is adjusted by moving the support pin in the "warm up regulator". Warm control pressure is adjusted by moving the "fuel cell" in the warm up regulator. Correct pressure values are in the service manual.
  23. spicedriver
    Feb 1, 2011
    3,859
    This video shows adjustment of the cold control pressure. The tech starts with the pin flush with the housing. The warm control pressure adjustment is not shown, but should be done first. Also with the pin flush with the top of the housing. Then adjust cold control pressure. Ball park numbers for pressures are 5 bar - system pressure. 3.5 bar - warm control pressure. 1.5 bar - cold control pressure.
  24. spicedriver
    Feb 1, 2011
    3,859
    This video shows proper setup, and adjustment of the system pressure regulator with shims. However I DO NOT recommend drilling a hole in the warm up regulator. Adjust the warm up regulator by moving the pin as in the previous video posted.
  25. jose190sl
    jose190sl Rookie
    Dec 4, 2015
    8
    Hello guys, good news, problems solved, the car is working perfect, thank you all of you for your help, I appreciate a lot your comments.
