Snap, Crackle, Pop - Ground Issue? | FerrariChat
Discussion in '348/355' started by 3forty8, Dec 11, 2007.
  1. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    Heard what sounded like wires shorting in the center console/radio area, so I removed the center console and was able to pinpoint the specific area - it is coming from my shifter/shift gate. My 5/8 bank ECU is also conking out occasionally when I hear the shorting sound (but not consistently). I've checked the wiring from the ECU through the firewall and there is no evidence of worn wires/shorting occuring there. Checked the ground straps from engine to frame and battery to frame and cleaned the contact points. Something is grounding out on my shift linkage - anybody had anything similar? Besides checking the ECU grounds to the motor this evening, any other thoughts on what I should be looking for?
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    Have a look at the switch for the reverse lights. Remove the shift gate to have a looksy. :D.
    Then what you will want to do is completely remove the climate control panel and have a look at the connections for the HACV ecu's. Here's the how to http://ferrarichat.com/forum/showthread.php?t=19629
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Is your orange light on (that circles your cig lighter)? If that plug to the cig illumination comes undone, the wires pull it back toward the shift box, and it is an open wire that can short to any metal that it touches.
  4. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    I think I would recommend getting in there with a multi-meter and checking your ground cables. It's possible that the cable terminals are fine but cables themselves may have excessive resistance, particularly if the negative cable still has the bullet connection in it.
    Or for a test, you could just take a jumper cable and run it from the negative terminal on the battery to a good, solid spot on the engine or transmission, then take the car for a drive and see what happens. Make sure the jumper is firmly attached so it doesn't come undone.
    It IS possible for a badly grounded drivetrain to seek the path of least resistance and ground itself though the shift cables. I would think that the possible problems mentioned by ND and Ernie would blow a fuse if they were direct grounds, but they would be easy to check and they ARE in the right area.
  5. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Good points!
  6. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    Ernie, No Doubt, Miltonian - thanks for all the advice guys. When I put the center console back in I cleaned all the contacts for the switches, gauges and A/C control and then applied Stabilant. I disconnected the cig lighter & light (I don't use it anyway) and checked the reverse lights switch. That thing was corroded like crazy (underneath the rubber boot where the pink wires are soldered to the switch). Cleaned the corrosion off and applied Stabilant. I haven't been able to go for a test drive yet as my daughter was asleep by the time I was done and starting the car up tends to wake her up - go figure!
    I've purchased some beefy power/ground cables and connectors and my next steps are to get rid of the bullet disconnects in the power and ground lines and check the reverse light wires for a short (every other connector has been relatively clean - it's odd that one was in such poor shape relative to everything else). I replaced all the relays this past weekend as preventative maintenance and checked the fuses while I was at it. No blown fuses and no evidence of fuse blocks melting. I really appreciate all the advice and assistance - I think I speak for a lot of guys on the board when I say your help turns what could be a frustrating ownership experience into a fun hobby. Wrenching is almost as fun as driving - almost!
  7. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  8. ernie
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    Thanks for the update Eric.
    Glad I could be of help.
