Snap Ring CV Joint | FerrariChat
Snap Ring CV Joint
Discussion in '308/328' started by Imatk, Aug 23, 2025 at 8:07 PM.
  1. Imatk
    Imatk Formula Junior
    May 6, 2007
    794
    I'm replacing both boots on my axle and finished (or I think) one side.
    The side that I finished... when I removed the axle the snap ring literally fell out onto the floor.
    So I thought, ok replace the snap ring with the one in the kit. Which I did.
    The thing is... it's on there, it's in the groove, I even tapped it down with a drift to make 100 percent sure.
    But I if I pull up on the joint enough times, the ring dislodges and flies off.
    I figured for it to be secure that shouldn't happen.
    But I've removed it, and replaced it and tapped and done everything I can think of to make sure it's seated, but with enough pulls on the joint it will dislodge.
    Is this ok? Or do I have an issue with my axle?
  2. Newman
    Newman F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 26, 2001
    14,499
    Canada
    Newman
    The spring washer against the joint makes it a challenge getting the snap ring seated. I use a press to lightly push the joint down and the ring goes into the groove.
    Rifledriver likes this.
  3. Imatk
    May 6, 2007
    794
    That's the thing, I'm pretty sure it's in there already.
