Snap Ring Removal During Oil Change? | FerrariChat
Discussion in '360/430' started by Mad Scientist, Jan 1, 2011.
  1. Mad Scientist
    Mad Scientist Rookie
    Sep 4, 2009
    43
    San Antonio, TX
    John K
    Changed the oil in my F430 yesterday. I purchased the kit from Ricambi which includes a filter to be put into the gearbox housing. However, there is a snap ring holding the filter in place. I tried several different screwdrivers, etc. but couldn't get it out (It kept sliding around its slot which didn't help matters any.) So, I just proceeded with the rest of the oil change without removing the gearbox housing filter. For those of you who have done this before, does anyone have any suggestions?
    Mad
  2. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    I have changed the oil in my 360F1 several times, but the one in the gearbox housing only once. I recall using special snap ring removal/lacement pliers, which you can purchase in any automotive parts store.
  3. bmw550i
    bmw550i Karting
    Feb 1, 2008
    208
    I have changed my own oil in my 430 a few times now and skipped this step each time ..curious was the mesh filter dirty at all????
  4. vaporhat
    vaporhat Rookie
    Jul 31, 2006
    42
    [I know this is a post from the grave, but I thought I would help the next who uses the search tool]
    No special tool available. I used two screwdrivers. One to hold the ring in place to prevent it from spinning, the other to gently pry the ring off it's seat using leverage
    against the pointed end of the segmented ring.
    I replace the mesh, ring, and seals every annual. My mesh was clean.
