Snapped clutch cable or broken fulcrum | FerrariChat
Discussion in '206/246' started by VicJano, Apr 20, 2015.
  1. VicJano
    VicJano Karting
    Dec 17, 2011
    233
    Kingston upon Thames
    Chris O'Connor
    I've got a clutch pedal sitting on the floor with no resistance. Does any one have an opinion as to how likely it would be the fulcrum broken as opposed to the cable. I suppose I'm asking has anyone heard of a fulcrum breaking or are they pretty much bullet-proof?
    Thanks Chris
  2. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #2 synchro, Apr 20, 2015
    It is a long shot but has your clutch pedal return spring broken?
    If so your clutch cable may be OK. Open the front bonnet, remove the plastic batchboard and look at it in the pedal box.
    It happened to me, the spring broke at the fixture hole.
  3. VicJano
    VicJano Karting
    Dec 17, 2011
    233
    Chris O'Connor
    Thanks. Would I still feel some resistance if it was the pedal spring?
    Chris
  4. VicJano
    VicJano Karting
    Dec 17, 2011
    233
    Chris O'Connor
    Can someone help with info on clutch pedal please. Does the pedal have a return spring attached or does the helper spring by the clutch housing do the returning job?
    Thanks in advance.
    Chris
  5. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    No.
    When mine broke I had to slip my foot underneath it to return the pedal
  6. VicJano
    VicJano Karting
    Dec 17, 2011
    233
    Chris O'Connor
    Thanks, at the pedals I can only see one spring and that seems to be attached to the brake pedal. Does the helper spring at the clutch housing return the clutch pedal to up off the floor?
    Thanks in advance. Chris
  7. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    Clutch does have a return spring at the pedal. Clearly visible and explained in Synchros post above where he posted a detailed photo of the assembly.
  8. VicJano
    VicJano Karting
    Dec 17, 2011
    233
    Chris O'Connor
    Thanks. So its the nearest lever with spring attached? See pic
  9. TheMayor
    106,140
    Vegas baby
    Mine broke just like that. The cable snapped. The cable should snap before the fulcrum.
    Once you replace it you'll be shocked at how good the feel is.
  10. VicJano
    VicJano Karting
    Dec 17, 2011
    233
    Chris O'Connor
    #10 VicJano, May 5, 2015
  11. ENZOSON
    ENZOSON Formula Junior
    660
    Erie, Colorado
    PIETRO
    There are 2 return springs right? One at the pedal (as shown in the photo from Syncro ) and one at the bell housing. My pedal spring broke a few years back (got a new one from GT Parts) but the clutch still worked (just felt "funny"). The bell housing retun spring was doing the work...
    Cheers
    Pietro
  12. Dino Club Germany
    Dino Club Germany Formula Junior
    Nov 10, 2008
    549
    Germany
    N. Schumacher
    The helper spring under the hood does the job. To adjust it correct it a kind of science as the spring has at first to give some resistance by pushing the pedal and after a specific point it supports. The correct angle of the 90 degree lever has to be adjusted by the length of the clutch cable with the connecting end in the front and in the back. If you do it wrong it e.g. keeps the pedal to the ground or you may have the clutch always pushed a bit.
  13. VicJano
    VicJano Karting
    Dec 17, 2011
    233
    Chris O'Connor
    Thanks for all your advice on this.
    Chris
