So I found a 360 carbonfiber rear hatch now what? | FerrariChat
Discussion in '360/430' started by 02360spider, Jun 26, 2020.
  1. 02360spider
    02360spider Formula 3
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
  2. one4torque
    one4torque F1 Veteran
    5,737
    Houston
    One4torque
    there is a high and low cost option.....
    high cost.... source the fancy acrylic clear center section......
    low cost.... have a race-inspried poly clear center section fab'd using al bracing...... if done properly this can be functional and look good.
    Not sure what you will do for the side slats.... perhaps the factory parts fit here..... need to look at how this was fitted on the challenge car for ideas.
    You 'might' need engine cover hood lock down pins/locks to run this......
    will be curious to see the wgt savings of this w/ acrylic vs stock w/glass...... 80lbs?
  3. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    So the site im checking out has different thickness also different adhesive what are the best options? Image Unavailable, Please Login
    Sent from my SM-N975U using Tapatalk
    So the site im checking out has different thickness also different adhesive what are the best options? View attachment 2963604
  4. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
  5. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
  6. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  7. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  8. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Did you buy it 02360Spider ? I have a spare OEM CS rear glass .
  9. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  10. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    Do you think number 10 from my 360 will bolt up to mount the side louvers?
  11. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    Yes I bought it only $750 shipped
  12. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    Is it glass or the lexan?
  13. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    there are two kinds of carbon fiber grills, the standard 360 sets flush with glass. CS over laps the glass help secure it down but they are 1450.00 per side or now even more if you can find them
  14. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Lexan glass CS
  15. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  16. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Just cross references same part number so yes
    02360spider likes this.
  17. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
  18. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    Now the real question is how much you want for that glass?
  19. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    is that factory part ? 750.00 sounds like a hell of a good deal man !
  20. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
  21. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    Never seen a aftermarket one so I would say yes lol.
  22. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Damn it man I would have bought that !
  23. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Wend you get it take better picks of it
  24. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    Will do
  25. CarbonDan
    CarbonDan Karting
    191
    PNW
    I also have a spare lexan rear panel. Brand new reproduction. Will let it go cheap, pm me if anyone is interested.
    Part number 67404300 for 360 Challenge Stradale
