So I need an IT guy to help me find the right solution | FerrariChat
Discussion in 'Technology' started by F355 Fan 82, Nov 14, 2009.
  1. F355 Fan 82
    F355 Fan 82 F1 Veteran
    Jul 22, 2006
    9,063
    I have 9 business locations and I would like to put a small 10-15 inch screen in each of them, these lcd's would have screenshots of our product scrolling but I could add/delete slides from all the screens from say 1 computer. What/who would I need to talk to and what kind of price would I be looking at to get something like that accomplished. Thanks for any insight
  2. becker
    becker Formula Junior
    Feb 20, 2001
    340
    Arlington VA
    Becker Cuéllar
    If u have web access at your locatoins a web page can be set where u can do what yo just stated. If you need it stand alone(no web) is a not that harder depends on what u have. Hope it gave u an idea
    Cheers
    becker
  3. DMC
    DMC Formula 3
    Nov 15, 2002
    2,385
    WI/IL
    Dean
    I agree, the cheapest and easiest would be to set up a web gallery, then have a low-cost PC at each location. Have the PC go to the gallery and let it go to a slide show. Add or remove pictures from the web gallery to control what they show. There are some very low cost small form factor PC's that could do this. They wouldn't even need a hard drive, just need to boot to Ubuntu Linux and fire up a browser. They could boot off a USB stick or maybe an SD card.
  4. DMC
    DMC Formula 3
    Nov 15, 2002
    2,385
    WI/IL
    Dean
    I would start with something like this:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16856167032
    Then you have to add RAM for about $15-20, and easiest to put a small hard drive in for 35 bucks. So you're in to the system itself for around $190 each without an LCD screen. Figure around $100-120 for a 17"-19" monitor and you're looking right around $300 each for hardware. Not sure if there's any specialized hardware that does this but this is pretty easy to do, and the hardware is small and quiet, and can be used for other things if needed.
  5. Waldoonay
    Waldoonay Formula Junior
    Mar 5, 2007
    630
    Ottawa/Abu Dhabi
    Walid Z
    Have you considered a photo frame instead?
    I know Kodak makes a very nice one for around $200 (for the 10") but get higher as you get bigger. They have a wifi chip that you can use to get on the internet and sync to a flicker or similar account. Then it's just a matter of making changes on your online account. Don't quote me on this because I'm not sure if it streams the photos or downloads them to onboard memory but I would take a look there.
    The entire system would be less than 2k I would think.
    Take a look at Best Buy I saw a 10" there.
  6. F355 Fan 82
    Jul 22, 2006
    9,063
    I like all the suggestions, what I'm wondering is there any software where I can choose which location I want to update and do that from say my laptop. It's just assuming we want to update things from day to day at 9 different places, it would get tricky going to each business.
  7. powerpig
    powerpig F1 World Champ
    Oct 12, 2008
    11,078
    Huntsville, AL
    Kevin
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,935
    Central NJ
    Dominick
  9. F355 Fan 82
    Jul 22, 2006
    9,063
    Wow thanks the last 2 responses were very insightful.....the media server,with me not being a technical guy, how difficult would that be to implement. The kodak frame with the ability to login on line seems to be the easiest, but could I really manage 9 screens from just 1 account??
  10. Far Out
    Far Out F1 Veteran
    Feb 18, 2007
    9,768
    Stuttgart, Germany
    Florian
    You can control a million screens with one "account". They just look what pictures are on a certain web server and display them. All you do is update the server.
  11. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,935
    Central NJ
    Dominick
    Question: do the sites have internet access thru say a wireless router (Wi-Fi).
    You need to have this at each site.
    Basic steps to setup solution:
    Install software on one PC
    Upload pictures to Flickr or Kodak site
    Configure each digital frame to connect to your wireless network or Wi-Fi hot spot at each location
    Configure each digital frame to connect to flickr / Kodak site you corrected
    Done
    If you have a PC already - go buy one of these frames and try it out. If it does not suit your purpose, you can always return it and it will only cost you your time :)
  12. powerpig
    Oct 12, 2008
    11,078
    Huntsville, AL
    Kevin
    I have to say that this is probably the best solution as long as you can get them in the size you need. Regardless of the solution, you must have internet connectivity.
  13. GhostRider
    GhostRider Formula Junior
    Dec 20, 2002
    999
    Tulsa, OK
    Matt
    What you are wanting is a "digital signage" application. This is a huge and confusing market right now, with many players, and not much weeding out just yet. Prices vary quite a bit considering what features you are after. I have personal experience with the X2O platform, but there are many others, so much so that there is a Digital Signage Expo. It's big business.
