so my friend just blew his GSR motor | FerrariChat
Discussion in 'General Automotive Discussion' started by Ryan S., Dec 24, 2004.
  1. Ryan S.
    Ryan S. Two Time F1 World Champ
    28,892
    ok, heres the deal
    my friend was coming home from a friends house. the friend who owns the gsr was drunk, so he had a sober friend drive his car home for him. on the drive home, the motor blew. my drunk friend was asleep when it happend, so he doesnt no what the sober friend was doing when it happend. the sober friend said the motor just let go, and white smoke started poring out.
    now my question is, what do you think caused this. this motor was just rebuilt completely by Acura about six months ago. The acura mechanics just said that there was a hole in the block. one of my thoughts is is that the kid who was driving accidently shifted from 5th to 2nd. Id think that youd have to build up some pretty serious pressure to blow a hole in the block.
    the kid who was driving said the motor just "let go", as in oil just came out some how. but do you think just oil leaking out would blow a hole in the block? id think it just freeze the pistons and what not. they were also driving at about 70 mph if that helps.
    anyways, what are your thoughts on what could of happend?
    thanks, lata
  2. isellpower
    isellpower Formula Junior
    Nov 30, 2003
    888
    Midwest
    Jason
    Easy, the GSR was well beyond it's engines safe top speed at 70mph.
  3. Ryan S.
    28,892
    do you think it was a down shift, or a mechanical problem of some sort?
  4. Etcetera
    Etcetera Two Time F1 World Champ
    23,997
    C6H14O5
    Why was the engine rebuilt 6 months ago? It could have been a shoddy rebuild, which I see more often than not these days.
  5. isellpower
    Nov 30, 2003
    888
    Midwest
    Jason
    Sorry Ryan, it was a sad attempt at humor. I meant that the car is not capable of 70mph even with a good motor.
    Just like Korr said, bad rebuild at the dealer.
  6. Ryan S.
    28,892
    my bad, lol
    what you said is true though, lol.
  7. Ryan S.
    28,892
    but do yall think a crappy rebuild could blow a hole in the block? i might be wrong, but itd seem like youd need a huge pressure increase to blow a hole in a block. other than a screwed up shift, what else could make pressure increase that much on a NA car.
  8. Etcetera
    23,997
    C6H14O5
    Don't need pressure, just an odd bit of engine...say a piston, but more likely a connecting rod...to come undone and hence try to free itself in whatever direction it was traveling at the time, barring other bits getting in its way. I've seen a rod break out a portion of the block on a Chevrolet 5.7l while the vehicle was idling.
  9. Ryan S.
    28,892
    thanks for the info
  10. ashsimmonds
    ashsimmonds F1 World Champ
    Feb 14, 2004
    14,385
    adelaide, australia
    Humble Narrator
    not sure what a GSR engine is over there, if someone here told me their GSR engine was rebuilt by Honda then there might be reason for concern... GSR is a mitsubishi "performance" model badge. :D
    anyhoo, now that we've established my circumstances have no relevance whatsoever... :cool: my GSR "let go" once, not as bad as this, and i had a lot less knowledge about what i was looking at back then, so it wasn't much more than a busted belt, siezed water pump, and possible valve/piston collision. this was just under light load at about 20mph in 2nd gear through a busy intersection. :(
  11. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    holes in the block are usually caused by a rod letting go. Cause: bad bearings, over revving, etc. How much oil in the engine when it blew? Since it was rebuilt 6 months ago, I'd want to look at the main bearings, the piston pin areas. Are they blue? If so, lubrication failure, is the bearing surface scarred? could be the result of a bad fit. the motor needs to come apart.
    Art
  12. Artherd
    Artherd F1 Veteran
    Jun 19, 2002
    6,588
    Bay Area, CA
    Ben Cannon
    I suspect a conrod let go.
    Properly built, those engines should be able to turn 9krpm+ for a short time and still be 'OK' (not that I'd do it willingly...) At 70mph, how fast is the GSR motor turning? Unless it's 12k+, I suspect a bad rebuild.
    If the rebuilder didn't torque a rod cap properly, it can come off at any time, and put a hole right through the block, even at idle.
  13. FIAutoSports
    FIAutoSports Formula Junior
    Nov 13, 2004
    620
    Baltimore, MD, US
    John Ritenour
    Just a guess, but I would say he was driving an Acura(Honda) Integra GSR. but you are in AU.
    And it went right after a rebuild at a dealer? Extremely poor workmanship. Those are good motors and come in a variety of trim. Having a GSR motor blow should fall back on the dealer that did the work.
  14. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    I agree. But, I've seen this too many times and it is always a driver error. The motor was rebuilt six months ago, and if your friend drives it spirited/aggressively at all, to the slightest degree, these symptoms would have come up a lot sooner than the not-so-sober night.
    The story you are getting at 70mph is typical. Lets take that speed and add 20 to it for story-error. Now, going 90mph in 5th, dropping it down 3rd, accidentally hitting it into first - could not have been done without a blip. I doubt he did that. Now, trying for fourth and hitting second, that is all too typical. The motor didn't "just go". He mis shifted and is trying to cover his ass. But when misshifts happen, they will result in bent valves, and not a thrown rod. The head would be severely messed up, but this... I guess the only thing I can shed doubt into my own prognosis would be oil level. Lack of it = bam.
