So My Noise Issue Has Been Found, I Need Help With Next Step | FerrariChat
Discussion in '456/550/575' started by F355 Fan 82, Jan 13, 2018.
  1. F355 Fan 82
    F355 Fan 82 F1 Veteran
    Jul 22, 2006
    9,063
    So as you may remember I posted about the noise my transmission was making, I called Tim Stanford and he recommended to another place because he does not work on newer cars like mine. So the issue with my car, and I just picked it up today after a week, the issue is that basically
    the vehicle was driven for too long with the gearbox oil not set to the correct level which has damaged internal components. They checked the gearbox and it was too low to indicate on the dipstick. The filled it with 2.5 quarts of Shell 75w-90 full synthetic to get it to the proper level, tested it and it was still whining. They also filled the gearbox with 4.75 quarts of Redline 75w90.
    So now the issue is I bought the car, major service included, which I found out now from this other shop wasn't really a major service but a cambelt service and an oil change and the car now needs things like spark plugs as well. Anyways that didn't bother me as much bc I felt I got a good price on the car but anyways, I dont know every thing included in a major but I was told the car would get a major before I got it. I got a receipt for $2500 of work for belts and fluids changed. Anyways this gearbox oil was too low and the tech who saw it now think I may have potentially damaged it on the 125 mile trip home bc it was low on fluid or it could have been damaged before I got it 400 miles ago. Either way the car was given to me with too low fluid which was the major problem.
    So now the car drives fine, the issue is isolated to 6th gear and Im going to avoid it till the issue is figured it out with the dealer I bought the car from. So now, who is to blame for all this? The tech here says its not my fault they released a car low on gearbox fluid especially if they did a major service before selling it to me. I don't want to name names on the internet bc I genuinely believe it was an honest mistake that just turned out to be super pricey..The dealer I bought the car from is very reputable and the shop he had the service done at, they're very reputable too. Perhaps it was just an error on the techs part bc I spoke with a super knowledgable tech out here and he explained how complicated and time consuming servicing the 575 gear box is. Either way the receipt for the major is in the dealers name, not mine so im not even really a customer of the shop who did the work. The receipt for the major includes a part that says "top up all fluids".....well the gearbox fluid wasn't topped up and I have pics of the dark brown fluid that came out and the shop kept to show me vs the light yellow/brown fluid they just put in.
    So if this was your car and you've put just 400 miles since you bought it, whats the next step, the shop out here says the car was given to you in this condition and the major service that was done should have noticed the low fluid for starters. Whether the damage was done before or after, the low fluid was an issue from the service and 6th gear more than likely was not damaged in the 400 miles ive driven it unless it was damaged on that highway drive home short on fluid.
  2. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,643
    SF Bay Area, CA
    Ruben
    #2 Il Tifoso, Jan 13, 2018
    Wow, I feel for you... sorry that you experience started out this way!
    Did the car have any oil leaks? How was it that it was 2.5 quarts too low?
    I hate to say this, but cars are usually purchased “as is”. Perhaps you may want to consider getting an estimate and having a dialogue with the selling dealer about ways they can cover all or part of the repairs. I’ve had a good outcome with this approach when I purchased my 412 from a dealer across the country and the car showed up with an unexpected ding. They ended up covering the cost of the repair.
    I’m not sure if there may be any legal recourse for the repairs, should the dealer deny any responsibility, but will let the attorneys amongst us to chime in. IMHO going back to the shop that supposedly did the major on behalf of the dealer will probably not lead to any satisfactory outcomes.
    Either way, I wish you the best of luck and let us know how it turns out.
    Ruben
  3. F355 Fan 82
    Jul 22, 2006
    9,063
    also the only reason i ask is rebuilding the transmission i was told is very very expensive like 15-20k. The receipts for the car go back 10 years, it looks like the last time the gearbox was serviced was 2013, the tech out here though said if they did a major service that should have been in there. It says on the receipt they topped off all fluids, this was really empty so he said they gave me a car low on fluid and me immediately driving it home 125 miles could have been what caused it bc its only 6th gear which is what I used on the trip home. For now 1st-5th work fine and finally got to enjoy driving it today.
  4. Konadog06
    Konadog06 Formula Junior
    Aug 22, 2007
    963
    Daytona Beach, Florida
    Bill
    Should you need trans work there is only one shop to do the work. It is there specialty.
    *Serkan Ozsavasci, owner.
    754-205-0812
    Email [email protected]
    516 NE 26th Court
    Pompano Beach FL 33064
    In the mean time unless I missed something the current fill math does not add up. Capacity is 1.18 US gallons. You said, first 2.5 qts then 4.75 qts. That comes to 7.25 qts vs just under 5qts capacity. Am I missing something?
    Bill
    FL
  5. F355 Fan 82
    Jul 22, 2006
    9,063
    I just copied from his email, perhaps he added 2.5 qts then flushed it and added 4.75 of a different type? They have different names I see
  6. Konadog06
    Aug 22, 2007
    963
    Bill
    K, thought it must have been but just making sure you were aware.
    B
  7. tazandjan
    39,170
    There actually is no such thing as a major on our V12s. That term actually belongs to the V8s and flat 12s (although not used by Ferrari) that had to have the engine removed to replace the cambelts. That is pretty major. Colloquially, it has come to mean the 5 year interval when you replace the cambelts. But there is no guarantee all the other fluids/filters needed to be changed at the same time. If you are on a two year schedule for replacing transaxle fluid, that may not line up with the 5 year belt change, same for power steering fluid, coolant, and F1 fluid (3 years, not in the manuals). Mine gets serviced pretty strictly by the intervals recommended by the maintenance schedule (plus coolant and F1 fluid not in the schedule), so all the fluids do not get changed when the cambelts get changed. So is that a "major" or just a cambelt, oil change, brake fluid, and environment filter change? Not a major to me.
    Sounds like this is between the selling dealer and you. Without stripping her down, you have no way of knowing what was affected. Remember that the 575M transaxle is pump lubricated, not splash lubricated. As long as there was enough oil in there for the pump to keep pumping, damage should have been minimized.
  8. F355 Fan 82
    Jul 22, 2006
    9,063
    Looking over the last 5 years of receipts on the car my new tech, who btw is the most knowledgable guy I've ever met, I need to thank Tim Stanford for referring me to him. He looked over all the receipts and the dealer I bought the car from keeps noting the the donax added when the clutch was replaced 3000 miles ago as the gear oil but this tech is noting The 1 container of donax that is noted on the clutch change, 1) it is not enough and 2) is not the correct fluid according to him, it is not gearbox oil, its automatic transmission fluid or power steering fluid to top off the F1 tank more likely but nowhere on there does it say that the gear oil was changed. Its nowhere on the receipts. Shell 75w90 full synthetic is the gear oil that Ferrari recommends and thats what he topped it off with and he says there is no 75w90 on any of the receipts from the shop servicing it the last few years, he was looking through them all and could not find it. This tech then flushed it and added redline full synthetic specially for a transmission that is with a transaxle like the 575.
    So basically the dealer I bought it from is saying the donax was the gear oil and it was changed in 2014 and the tech here is saying donax is not gear oil and the gear oil hasn't been changed since the Ferrari dealer serviced it in 2013.
  9. tazandjan
    39,170
    Donax covers a wide variety of lubricants/fluids depending on the suffix attached to it. Donax TX is basically synthetic ATF, while Donax UB is actually brake fluid, and there is also a TA that is an earlier version of TX. Your tech is correct, though, none of them go into a transaxle and that was probably power steering or F1 fluid. Since there is no change interval for the F1 fluid in the maintenance schedule, it was probably put into the power steering system (2 year interval, same as transaxle oil).
  10. GTS Bruce
    GTS Bruce Formula Junior
    Oct 10, 2012
    804
    Orchard Park NY
    Bruce Roche
    I Didn't see your original post. My 6th gear got noisy. Burned fluid. Upon tear down 6th gear was walking and rounding off the teeth. The rest of the box was fine. The new 6th gear cluster was thicker than the original. After correct set up with the New cluster and much cleaning and flushing it runs quiet. I have heard other early 575 having the same problem of losing 6th. NJB fixed mine. total cost including parts $10,000. The only damage was the 6th gear cluster. Good luck. Lots of labor involved.. If I remember correctly the gear clustered around $2500 at the time. Brand new piece from Italy rather than Use an off shelf piece.Thats when the difference in thickness was noticed. GTS Bruce
  11. F355 Fan 82
    Jul 22, 2006
    9,063
    #11 F355 Fan 82, Jan 14, 2018
    My problem and whats irking me badly is this. The tech I used in miami is literally one of the best in the world, he doesn't advertise himself and was working on some of the best Ferraris in the world at his shop. Tim referred me to him, he was about to begin work on an F50, people dont send F50s to guys unless they're the best. Small shop and he does all the work. The guy went over all my cars service records with me and basically explained to me in each one how the shop doing the work the last 5 years basically isn't doing this properly bc they say we did something but dont write out exactly what was done the way he does. He got frustrated trying to repeatedly get through to them that donax wasn't the gear oil he was mentioning could have been the issue and he was just flabbergasted at how this shop is so well known. He said the 575 gearbox is a tricky one to fill and different from others and he showed me exactly how its done and its time consuming. The dealer I bought car from wants me to take car to him this week, another 100+ miles away, and drive it with the mechanic he's been using to service his cars forever. He was willing to acknowledge that if there is an issue he would fix with the mechanic he knows and trusts.
    Here is what I dont like about that
    The mechanic and his shop that worked on it have made basically "wholesale" work on the car for the last 5 years according to this tech just by looking at receipts on the car and how things like the clutch disc were changed with customer supplied parts(possibly the dealer) a few years ago and how they considered that a clutch change and how they thought donax was gear oil, and just overall how they bill so few hours to do such major things they have claimed to the car over the past 5 years ie 1.5 hours of labor for an annual service on the car every year. If they do admit there is an issue and they missed it the dealer wants to fix it with these guys bc he's so used to their cheap prices and apparently sometimes mediocre work. I thought I was getting a "major service" when I bought it 6 weeks back bc the paper work says major included, but I got a $2500 belt service and the tech here is telling me it needs spark plugs and more which I will do soon once this is resolved. I've learned a ton this week and really more than anything wish the dealer explained this all more, but its ok you live, you learn, and im learning an expensive lesson thus far. The dealer is saying the guy I use charges too much out here and the quote im getting of $15-20 thousand isn't going to fly with him bc if there's an issue they can put in a used gearbox for $5-6k and solve the issue. The tech out here said thats an awful idea bc they numbers wont match and will hurt the car in the long run. The dealer rebutted with this
    "With regard the numbers matching, there are many cars that have had major components changed by Ferrari under warranty and no one seems to care. Classiche certification is just another money maker for Ferrari. Chris Evans, a British collector paid $37m for an original California Spider, classiche certified then found out Ferrari had installed a new period engine and restamped the block."
    So now if there is indeed an issue next week when they look it, they want to put in a different transmission vs rebuilding bc its obviously cheaper for them but in reality i just want the guy in miami to work on it bc he's really the nicest,most genuine, and knowledgable tech I've ever worked with on any car ever. I will never go to anyone else but him moving forward and if you want his info pm me and ill give it you.
    So knowing all this, how would you approach going forward. I just want the car fixed if it is their fault, but I also want it fixed properly not some half ass manner but they feel the indy shop im using is just too much money. Just yesterday a 2004 575 red with black/red interior sold at mecum kissimee for $135K + whatever fees they charge. Its a beauty and I want done perfectly.
  12. henryr
    henryr Two Time F1 World Champ
    22,414
    Atlanta
    Juan Sánchez Villa-L
  13. asgor
    asgor Formula Junior
    Sep 8, 2016
    715
    Virginia, USA
    Terry, you know a whole lot more about these things than I do but I noticed that the user manual that came with my 456 does mention Shell Donax TX as one of the options for transaxle fluid (auto box). I understand that a 456 isn't a 575, but it does seem as Donax is indeed a Ferrari-approved transaxle lubricant at least for some models. See attachment.
  14. fatbillybob
    Aug 10, 2002
    29,005
    socal
    True...Ferrari basically wants you to take these cars to Ferrari dealers and just open your wallet and not ask questions. I you started a thread on what is a "major service", no one would agree.
  15. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,643
    SF Bay Area, CA
    Ruben
    To start with, I’m glad the dealer is open to resolving this... it seems like the problem is how each of you is defining “resolving this”. If you were intending to purchase an unaltered, “numbers matching” (is the tranny really stamped with a number that matches that of the car?), then the dealer’s solution is not acceptable. On the other hand, if you want a car that you can reliably enjoy and use, then a new tranny is indeed a fine (and cost effective) solution.
    Are you willing to wait until these cars, wonderful as they are, (hopefully?) get to some value appreciation similar to the $37M California you quoted? IMHO, you’ll be waiting a VERY long time... these are wonderful but not rare cars. I would doubt that a swap would impact resale much if any, but again, MHO. You could also just save the original tranny in case the cars escalate enough in price such that matching numbers matter, drive the wheels off of it in the meantime.
    Another way potential way you could approach this would be to ask yourself: if this had happened 3 years into your ownership, would you be willing to spend $15K-$20K to rebuild or just do a $6K swap?
    Again, best of luck in this - keep us posted how it goes!
    Cheers,
    Ruben
  16. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    You are in great hands with Matt. Super experienced, smart, great guy.
  17. F355 Fan 82
    Jul 22, 2006
    9,063
    #17 F355 Fan 82, Jan 14, 2018
    He just gave the dealer im trying to work with probably the greatest response I've ever seen via email. This is what the dealer said
    "This is what I am questioning, that and the fact that both my tech and a Certified Master Ferrari technician both say that if there was a shortage of fluid in the gearbox, 6th gear would be the last to go, first would be synchro’s in 2nd, then third and so on."
    This is what my guy here said back...(he attached diagrams too to forward the dealer for him and his techs)
    These statements are just technically incorrect. Attached are diagrams of the 575 transmission and as can be seen diagram (main shaft gear and oil pump), 6th gear is the one that is closest to the front of the transmission. The 575 transmission is broken up into case sections as can be seen in the diagram (gearbox case). 4th, 5th, and 6th are all in the forward most case. At the bottom of each case section is a hole that reduces the ability of the oil to flow backwards into the other case sections which will occur during acceleration. Therefore when this transmission is run low on oil, it is actually 1st, 2nd, and 3rd that will receive the majority of the available lubrication because they are in the rear section of the gearbox. The main and input shaft also ride higher in the transmission than there mating gears on the lay shaft. So the reason why 6th is making noise is because its the biggest gear on the main shaft at the top and its in the most forward position of any of the gears. Most likely the damage occurred while 6th gear was under load (car being driven in 6th gear) at highway speeds for a period of time without the proper amount of oil in the gearbox.
    My mind was blown at the level of detail he included, what a brilliant tech and such a great guy to take time to explain it out bc the dealer was trying to say that if the gearbox was low on oil it wouldn't be 6th gear but rather other gears that would have been damaged. Like I said I learned ALOT this week from this incredible tech, really the best I've ever been around with any car of mine.
    Im taking the car up to the original dealer and service shop to see it tuesday, I will let you know how it goes, and yes original numbers matching is important to me bc this car is over $100k its an investment either way, its not going to $37m but its still a decent chunk of money for most people and it needs to be fixed properly. Obviously dealer wants the cheapest way out, but there seems to be pretty substantial proof that the shop that has serviced the car for the last 5 years hasn't added gear oil in any of the receipts and I was told its needed every 2 years and is definitely included in a "major" but either way nothing is noted on the last 4-5 years of receipts from the same shop of the addition of any.
  18. tazandjan
    39,170
    Asgor- Your 456 GTA has an automatic transmission with a torque converter, just like Grandma's Buick has. Makes sense that it would use automatic transmission fluid, which is what Donax TA and TX are. That transmission has no relationship to the manual transaxle found in any F1 Ferrari.
    Fan- Looks like your choice comes down to letting the selling dealer fixing it with no guarantee it will be correct, or taking it to the expert and having it fixed correctly at great expense. While you are at it, if you decide to have the expert fix it, ask him if he can upgrade the retainer for reverse gear introduced at Transmission 1869. Should not be very expensive at all once the transaxle is torn down. Incidentally, have him make sure the rear end was not affected by the low transaxle oil.
