So Where Exactly Did 3X8 Production Numbers Come From? | FerrariChat
Discussion in '308/328' started by Dr Tommy Cosgrove, Feb 11, 2025.
  1. Dr Tommy Cosgrove
    May 4, 2001
    36,431
    Birmingham, AL
    Tommy
    Seriously.
    We all have heard the rumors about the number of La Ferraris, Enzo's etc, that were built and how they are actually more than the factory has published. Those are limited production models and I really have no concern about the total number of them because that is a league I will never play in.
    But what about these total numbers of 308 models that have been floating around forever. I have seen these same numbers published in things like FML way back in 1987 - 712 Fiberglass, 494 GTBi, 1749 GTSi, 3042 GTS QV and so on. The back of every Cavallino has them too. Same numbers.
    I don't think they are right.
    For example, counting the Bi from 80-82 from various sources with chassis numbers online, Urban, The Registry, my documents over the years, etc I'm up to 520 cars and that's only up to chassis 41583. I still have to chassis # 43059 to go presumably the last Bi built (other sources has this as a B QV).
    Mistakes will be made here and there but I'm not so sure these car build totals are accurate at all. Someone had to get these numbers from somewhere back in the 80's and I am beginning to think that they are way off but no one has bothered to actually double check them. They have just been copied over and over again for 50 years without much thought.
    Am I crazy to question this?
  2. energy88
    energy88 Three Time F1 World Champ
    32,210
    West of Fredericksburg, VA
    I'm thinking, shouldn't there be some way to audit counts using earliest and latest VIN numbers? Or did the factory produce cars with large missing gaps in the chronological sequence?
  3. Rifledriver
    37,101
    In general Ferraris numbers are pretty close but any definitive number should be questioned. Ferrari officially does not share records but stuff leaks out, boxes fall off the back of factory trucks etc. There are so many sets of eyes tracking them for different reasons any big discrepancies would be uncovered. And they have been. Its been proven for example there were quite a few more Enzos built than claimed and a good friend has proof there are more FXXs than claimed but both are small production so it is more easily discovered. Also the motives are easily undestood in those cases. Any discrepancy in 82 308s is just bad record keeping and would not likely be a big mistake. VINs get skipped over, sometimes used more than once etc so specific counts based on VINs become hard without access to official records. In my pretty trustworthy record of US vins there were 82 GTB/Si being built as late as 42389 with QVs started at 41701 so there was a lot of overlap. Also counting models based on VIN range is really difficult because 400, 412, Mondial, TR and everything else is built in the same number range. Lamborghini is easy. For every model they have a separate number range. The number range for LM002 is 12001 to 12301 so I know ours was built right in the middle.
  4. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    I think Brian really explained it well. The numbers are close but not gospel with the exception of some of the special cars where there are some well recorded discrepancies.
  5. Dr Tommy Cosgrove
    May 4, 2001
    36,431
    Birmingham, AL
    Tommy
    I have a few more things to check but the Bi number total is more like 570 not 494
  6. bertrand328
    bertrand328 Formula 3
    Jun 1, 2015
    1,620
    France
    Bertrand
    So you have to list them one by one and see at the end ..
  7. Dr Tommy Cosgrove
    May 4, 2001
    36,431
    Birmingham, AL
    Tommy
    I did
    bertrand328 likes this.
  8. Dr Tommy Cosgrove
    May 4, 2001
    36,431
    Birmingham, AL
    Tommy
    I'm working on the Bi QV now. The Bi 2v list is finished.
    I did one on the glass cars but I have to clean that one up a bit on the tail end of the list.
    I'm going to do one last one with the GTSi and that's it. I'll leave the carbed steel B, S and S QV up to someone else. Too many and too much work. The GTSi will probably be the death of me but I'm going to give it a shot.
    ggjjr likes this.
  9. Rifledriver
    37,101
    I have seen so many mis listed I have learned to only count cars I can get a 17 digit vin for. So many GTBs listed as GTS and the reverse. Cars on my list need to be pretty well documented. Mis identification I have little doubt leads to a lot of the bad totals we see.
  10. Dr Tommy Cosgrove
    May 4, 2001
    36,431
    Birmingham, AL
    Tommy
    Same.
    Which is why I am doing everything I can to to cross reference with everything I have collected over the years with every source possible. I'll have mistakes too but the difference in the number total on the Bi end was eye opening which got me thinking about this whole thing.
    I went back in my FML archives and found an issue with "total numbers" by year on the cover. This was about Aug 87. The totals by year cannot possibly be correct - unless they are counting MODEL year and not year built (and I understand the concept of model year is quite different depending on the market, etc. - a discussion you have clarified here for us many times).
    This started out as a simple hunting expedition for something else, then I fell down a rabbit hole.
    I'm old school. I went to Office Depot and bought several 200 page spiral notebooks and a bunch of pencils and started writing numbers down with big spaces between to fill in with details as I stumble across a particular car here and there. Eventually I will put them on some form of spreadsheet and upload it but for now it's all hand written. I started with the Bi because of the low numbers. It's finished so I'm working on the B QV now and will finish with the GTSi simply because I'm 57 and that was the car being built when I discovered Ferrari at 12 years of age so it holds a sentimental place with me even though the model is just not the series' shining achievement. Someone has to give a **** about them so it may as well be me.
    4re308 likes this.
  11. dyerhaus
    dyerhaus Formula Junior
    Nov 4, 2012
    898
    Santa Rosa, California
    Christopher Dyer
    I did this (am doing this) with the 308 and 208 GT4s. I've found the published numbers that you see in books like Keith Bluemel's "Original Ferrari V8" to be accurate (although my total count is one more 308 than his, and one less 208 than what's in that book). I'm trying to verify a lot of other stuff now like options, current colors, location, etc., and also trying collect photos for each car. I have a loooooooooooong way to go.
    https://308gt4.com/chassis/
    4re308 and Dr Tommy Cosgrove like this.
  12. ChevyDave
    ChevyDave Formula Junior
    Dec 21, 2019
    411
    Pacific Northwest, USA
    Dave W
    Really admire you Dr. Tommy - and Chris - for taking on these kinds of projects; especially considering the many, many sources of contradictory data and the fact that factory record keeping may have left a little to be desired......:rolleyes:
    @Dr Tommy Cosgrove Maybe tackling the dry sump steel cars would be a bit less daunting and provide a decent jumping-off point for the person that wanted to tackle the balance of the carb'd 308 cohort...
    - Dave
    4re308 and dyerhaus like this.
  13. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    12,083
    FRANCE
    Why would you start again what our very own forum member Robert Retzlaff has been doing so well for so many years?
    Rgds
    https://308gtb.de/
    4re308 likes this.
  14. ChevyDave
    Dec 21, 2019
    411
    Dave W
    @nerofer - The reasons Dr. Tommy wants to create his own databases is a question you'd have to ask Dr. Tommy. He expressed reluctance to tackle the carb'd steel cars and GTS QVs due to the sheer number of cars involved, and I just tried to offer a way to eat the car'b steel elephant one bite at a time.
    No disrespect to Mr. Retzlaff - I think his work is fantastic - but even he notes the potential shortcomings in his database.
    - Dave
  15. Dr Tommy Cosgrove
    May 4, 2001
    36,431
    Birmingham, AL
    Tommy
    I don't think anyone has bothered with the carbed GTS, GTSi/Bi or GTS QV with any serious effort.
    The lower production cars like the glass ones and carbed B's are manageable but the others are just too numerous and have changed hands a lot. I'm an idiot for trying the GTSi but I'm doing it.
    What is fun is trying to peg the test cars serial numbers that were in road tests I read about back in the day. I have the blue 1982 GTB QV in CAR narrowed to two possibilities. The B QV R&T tested in Aug 83 is down to five possibilities. It has a deep front spoiler so that will narrow the five down some too.
    4re308, dyerhaus and ChevyDave like this.
  16. Rifledriver
    37,101
    Tommy
    80 FNA cars
    308 GTSi 31325 ZFFAA02A2A0031325 1980 Red X
    308 GTBi 31327 ZFFAA01A4A0031327 1980 X X
    308 GTSi 31337 ZFFAA02A9A0031337 1980 X X
    308 GTBi 31345 ZFFAA01A6A0031345 1980 White Tan
    308 GTSi 31355 ZFFAA02A0A0031355 1980 X X
    308 GTBi 31367 ZFFAA01A5A0031367 1980 X X
    308 GTBi 31369 ZFFAA01A9A0031369 1980 Red Black
    308 GTBi 31371 ZFFAA01A7A0031371 1980 X X
    308 GTSi 31375 ZFFAA02A6A0031375 1980 X X
    308 GTSi 31377 ZFFAA02AXA0031377 1980 Red Black
    308 GTSi 31381 ZFFAA02A1A0031381 1980 Red Black
    308 GTSi 31387 ZFFAA02A2A0031387 1980 X X
    308 GTSi 31409 ZFFAA02A8A0031409 1980 Black Black
    308 GTSi 31417 ZFFAA02A7A0031417 1980 Red Tan
    308 GTSi 31431 ZFFAA02A1A0031431 1980 X X
    308 GTBi 31439 ZFFAA01A4A0031439 1980 X X
    308 GTSi 31473 ZFFAA02A6A0031473 1980 X X
    308 GTSi 31475 ZFFAA02AXA0031475 1980 Red Tan
    308 GTBi 31485 ZFFAA01A0A0031485 1980 X X
    308 GTSi 31495 ZFFAA02A5A0031495 1980 Red Tan
    308 GTSi 31521 ZFFAA02A2A0031521 1980 Red Black-Tan Seats
    308 GTSi 31523 ZFFAA02A6A0031523 1980 X X
    308 GTSi 31575 ZFFAA02A3A0031575 1980 X X
    308 GTSi 31595 ZFFAA02A9A0031595 1980 X X
    308 GTSi 31599 ZFFAA02A6A0031599 1980 X X
    308 GTBi 31605 ZFFAA01A6A0031605 1980 X X
    308 GTBi 31621 ZFFAA01A4A0031621 1980 X X
    308 GTSi 31623 ZFFAA02AXA0031623 1980 X X
    308 GTSi 31627 ZFFAA02A7A0031627 1980 X X
    308 GTSi 31661 ZFFAA02A7A0031661 1980 X X
    308 GTSi 31663 ZFFAA02A0A0031663 1980 X X
    308 GTBi 31673 ZFFAA01A1A0031673 1980 Red Black
    308 GTSi 31677 ZFFAA02A0A0031677 1980 X X
    308 GTSi 31679 ZFFAA02A4A0031679 1980 X X
    308 GTSi 31681 ZFFAA02A2A0031681 1980 X X
    308 GTSi 31691 ZFFAA02A5A0031691 1980 X X
    308 GTSi 31693 ZFFAA02A9A0031693 1980 X X
    308 GTSi 31695 ZFFAA02A2A0031695 1980 X X
    308 GTBi 31711 ZFFAA01A5A0031711 1980 X X
    308 GTSi 31713 ZFFAA02A0A0031713 1980 X X
    308 GTSi 31717 ZFFAA02A8A0031717 1980 X X
    308 GTSi 31721 ZFFAA02AXA0031721 1980 X X
    308 GTSi 31733 ZFFAA02A6A0031733 1980 Black Tan
    308 GTSi 31737 ZFFAA02A3A0031737 1980 Red Tan
    308 GTSi 31741 ZFFAA02A5A0031741 1980 X X
    308 GTSi 31749 ZFFAA02AXA0031749 1980 X X
    308 GTSi 31751 ZFFAA02A8A0031751 1980 X X
    308 GTSi 31753 ZFFAA02A1A0031753 1980 Grey Red
    308 GTBi 31769 ZFFAA01A3A0031769 1980 X X
    308 GTBi 31771 ZFFAA01A1A0031771 1980 X X
    308 GTSi 31775 ZFFAA02A0A0031775 1980 X X
    308 GTSi 31777 ZFFAA02A4A0031777 1980 X X
    308 GTSi 31793 ZFFAA02A2A0031793 1980 X X
    308 GTSi 31795 ZFFAA02A6A0031795 1980 Red Black
    308 GTSi 31799 ZFFAA02A3A0031799 1980 Red Black
    308 GTSi 31817 ZFFAA02A1A0031817 1980 X X
    308 GTSi 31819 ZFFAA02A5A0031819 1980 Red Black
    308 GTSi 31821 ZFFAA02A3A0031821 1980 X X
    308 GTBi 31831 ZFFAA01A4A0031831 1980 Silver Black
    308 GTBi 31849 ZFFAA01A1A0031849 1980 X X
    308 GTSi 31853 ZFFAA02A5A0031853 1980 X X
    308 GTBi 31879 ZFFAA01AXA0031879 1980 X X
    308 GTSi 31883 ZFFAA02A3A0031883 1980 Black Tan
    308 GTSi 31901 ZFFAA02A1A0031901 1980 X X
    308 GTSi 31927 ZFFAA02A8A0031927 1980 X X
    308 GTSi 31929 ZFFAA02A1A0031929 1980 X X
    308 GTSi 31931 ZFFAA02AXA0031931 1980 X X
    308 GTBi 31939 ZFFAA01A2A0031939 1980 X X
    308 GTSi 31941 ZFFAA02A2A0031941 1980 X X
    308 GTSi 31945 ZFFAA02AXA0031945 1980 X X
    308 GTSi 31947 ZFFAA02A3A0031947 1980 X X
    308 GTSi 31951 ZFFAA02A5A0031951 1980 X X
    308 GTSi 31955 ZFFAA02A2A0031955 1980 X X
    308 GTSi 31959 ZFFAA02AXA0031959 1980 X X
    308 GTBi 31983 ZFFAA01A5A0031983 1980 Red Black
    308 GTSi 31991 ZFFAA02A6A0031991 1980 X X
    308 GTSi 31997 ZFFAA02A7A0031997 1980 X X
    308 GTSi 31999 ZFFAA02A0A0031999 1980 X X
    308 GTSi 32001 ZFFAA02A3A0032001 1980 X X
    308 GTSi 32031 ZFFAA02A1A0032031 1980 X X
    308 GTSi 32037 ZFFAA02A2A0032037 1980 X X
    308 GTSi 32041 ZFFAA02A4A0032041 1980 X X
    308 GTBi 32049 ZFFAA01A7A0032049 1980 X X
    308 GTSi 32053 ZFFAA02ADA0032053 1980 Red Tan
    308 GTSi 32055 ZFFAA02A4A0032055 1980 X X
    308 GTSi 32057 ZFFAA02A8A0032057 1980 X X
    308 GTSi 32073 ZFFAA02A6A0032073 1980 X X
    308 GTSi 32075 ZFFAA02AXA0032075 1980 X X
    308 GTSi 32085 ZFFAA02A2A0032085 1980 X X
    308 GTSi 32087 ZFFAA02A6A0032087 1980 X X
    308 GTSi 32113 ZFFAA02A3A0032113 1980 Red Tan
    308 GTSi 32117 ZFFAA02A0A0032117 1980 X X
    308 GTSi 32119 ZFFAA02A4A0032119 1980 X X
    308 GTSi 32121 ZFFAA02A2A0032121 1980 X X
    308 GTSi KOENIG 32167 ZFFAA02A4A0032167 1980 Black Black
    308 GTBi 32173 ZFFAA01A8A0032173 1980 X X
    308 GTSi 32175 ZFFAA02A3A0032175 1980 Red Black
    308 GTSi 32177 ZFFAA02A7A0032177 1980 Blue Brown
    308 GTSi 32193 ZFFAA02A5A0032193 1980 X X
    308 GTSi 32197 ZFFAA02A2A0032197 1980 X X
    308 GTSi 32205 ZFFAA02A8A0032205 1980 Red Tan
    308 GTSi 32207 ZFFAA02A1A0032207 1980 X X
    308 GTSi 32209 ZFFAA02A5A0032209 1980 X X
    308 GTBi 32217 ZFFAA01A2A0032217 1980 Red Black
    308 GTSi 32221 ZFFAA02A6A0032221 1980 X X
    308 GTSi 32231 ZFFAA02A9A0032231 1980 X X
    308 GTBi 32253 ZFFAA01A6A0032253 1980 X X
    308 GTSi 32265 ZFFAA02A4A0032265 1980 X X
    308 GTSi 32269 ZFFAA02A1A0032269 1980 X X
    308 GTSi 32271 ZFFAA02AXA0032271 1980 X X
    308 GTSi 32275 ZFFAA02A7A0032275 1980 X X
    308 GTSi 32285 ZFFAA02AXA0032285 1980 Red Tan
    308 GTSi 32287 ZFFAA02A3A0032287 1980 Red Tan
    308 GTSi 32295 ZFFAA02A2A0032295 1980 X X
    308 GTSi 32315 ZFFAA02A4A0032315 1980 Red Tan
    308 GTSi 32317 ZFFAA02A8A0032317 1980 X X
    308 GTSi 32321 ZFFAA02AXA0032321 1980 X X
    308 GTSi 32323 ZFFAA02A3A0032323 1980 Red Black
    308 GTSi 32325 ZFFAA02A7A0032325 1980 Red Tan
    308 GTBi 32327 ZFFAA01A9A0032327 1980 X X
    308 GTSi 32331 ZFFAA02A2A0032331 1980 X X
    308 GTSi 32333 ZFFAA02A6A0032333 1980 X X
    308 GTSi 32335 ZFFAA02AXA0032335 1980 X X
    308 GTSi 32341 ZFFAA02A5A0032341 1980 Black Tan
    308 GTBi 32357 ZFFAA01A7A0032357 1980 Red Beige
    308 GTSi 32363 ZFFAA02A4A0032363 1980 X X
    308 GTSi 32375 ZFFAA02A0A0032375 1980 X X
    308 GTSi 32377 ZFFAA02A4A0032377 1980 X X
    308 GTSi 32379 ZFFAA02A8A0032379 1980 Red Black
    308 GTSi 32387 ZFFAA02A7A0032387 1980 X X
    308 GTBi 32401 ZFFAA01A6A0032401 1980 X X
    308 GTSi 32403 ZFFAA02A1A0032403 1980 X X
    308 GTSi 32411 ZFFAA02A0A0032411 1980 X X
    308 GTSi 32431 ZFFAA02A6A0032431 1980 X X
    308 GTSi 32433 ZFFAA02AXA0032433 1980 X X
    308 GTSi 32457 ZFFAA02A2A0032457 1980 X X
    308 GTBi 32471 ZFFAA01A5A0032471 1980 Black Tan
    308 GTSi 32473 ZFFAA02A0A0032473 1980 X X
    308 GTSi 32487 ZFFAA02A0A0032487 1980 X X
    308 GTSi 32491 ZFFAA02A2A0032491 1980 Red Tan
    308 GTSi 32507 ZFFAA02A2A0032507 1980 X X
    308 GTSi 32509 ZFFAA02A6A0032509 1980 Black Black
    308 GTSi 32553 ZFFAA02A9A0032553 1980 X X
    308 GTSi 32555 ZFFAA02A2A0032555 1980 X X
    308 GTSi 32557 ZFFAA02A6A0032557 1980 X X
    308 GTSi 32559 ZFFAA02AXA0032559 1980 Black Red
    308 GTSi 32561 ZFFAA02A8A0032561 1980 X X
    308 GTBi 32571 ZFFAA01A9A0032571 1980 X X
    308 GTSi 32573 ZFFAA02A4A0032573 1980 X X
    308 GTSi 32575 ZFFAA02A8A0032575 1980 Silver Bordeaux
    308 GTSi 32577 ZFFAA02A1A0032577 1980 X X
    308 GTSi 32579 ZFFAA02A5A0032579 1980 X X
    308 GTSi 32581 ZFFAA02A3A0032581 1980 X X
    308 GTSi 32583 ZFFAA02A7A0032583 1980 X X
    308 GTSi 32585 ZFFAA02A0A0032585 1980 X X
    308 GTSi 32589 ZFFAA02A8A0032589 1980 X X
    308 GTSi 32595 ZFFAA02A3A0032595 1980 Red Black
    308 GTSi 32599 ZFFAA02A0A0032599 1980 X X
    308 GTBi 32605 ZFFAA01A0A0032605 1980 X X
    308 GTSi 32607 ZFFAA02A6A0032607 1980 X X
    308 GTSi 32611 ZFFAA02A8A0032611 1980 X X
    308 GTSi 32617 ZFFAA02A9A0032617 1980 Red Tan
    308 GTSi 32619 ZFFAA02A2A0032619 1980 X X
    308 GTSi 32641 ZFFAA02A6A0032641 1980 X X
    308 GTSi 32643 ZFFAA02AXA0032643 1980 X X
    308 GTSi 32671 ZFFAA02A4A0032671 1980 X X
    308 GTBi 32687 ZFFAA01A6A0032687 1980 X X
    308 GTSi 32693 ZFFAA02A3A0032693 1980 X X
    308 GTSi 32697 ZFFAA02A0A0032697 1980 Red Tan
    308 GTSi 32711 ZFFAA02A1A0032711 1980 X X
    308 GTSi 32713 ZFFAA02A5A0032713 1980 X X
    308 GTSi 32715 ZFFAA02A9A0032715 1980 X X
    308 GTSi 32717 ZFFAA02A2A0032717 1980 X X
    308 GTSi 32719 ZFFAA02A6A0032719 1980 Red Black
    308 GTSi 32721 ZFFAA02A4A0032721 1980 X X
    308 GTSi 32723 ZFFAA02A8A0032723 1980 Black Tan
    308 GTSi 32727 ZFFAA02A5A0032727 1980 X X
    308 GTSi 32747 ZFFAA02A0A0032747 1980 Black Black
    308 GTSi 32749 ZFFAA02A4A0032749 1980 X X
    308 GTSi 32753 ZFFAA02A6A0032753 1980 X X
    308 GTBi 32773 ZFFAA01AXA0032773 1980 X X
    308 GTSi 32777 ZFFAA02A9A0032777 1980 X X
    308 GTSi 32791 ZFFAA02A3A0032791 1980 Dark Blue Tan
    308 GTSi 32793 ZFFAA02A7A0032793 1980 Red Tan
    308 GTSi 32797 ZFFAA02A4A0032797 1980 X X
    308 GTSi 32799 ZFFAA02A8A0032799 1980 Red Black
    308 GTSi 32801 ZFFAA02A2A0032801 1980 X X
    308 GTSi 32803 ZFFAA02A6A0032803 1980 X X
    308 GTBi 32807 ZFFAA01A1A0032807 1980 X X
    308 GTBi 32809 ZFFAA01A5A0032809 1980 X X
    308 GTSi 32813 ZFFAA02A9A0032813 1980 X X
    308 GTSi 32815 ZFFAA02A2A0032815 1980 X X
    308 GTSi 32819 ZFFAA02AXA0032819 1980 X X
    308 GTSi 32821 ZFFAA02A8A0032821 1980 Red Tan
    308 GTSi 32841 ZFFAA02A3A0032841 1980 X X
    308 GTSi 32843 ZFFAA02A7A0032843 1980 X X
    308 GTSi 32865 ZFFAA02A6A0032865 1980 X X
    308 GTSi 32869 ZFFAA02A3A0032869 1980 X X
    308 GTSi 32871 ZFFAA02A1A0032871 1980 X X
    308 GTBi 32873 ZFFAA01A3A0032873 1980 X X
    308 GTSi 32887 ZFFAA02A5A0032887 1980 X X
    308 GTSi 32891 ZFFAA02A7A0032891 1980 Silver Black
    308 GTBi 32905 ZFFAA01A1A0032905 1980 X X
    308 GTBi 32907 ZFFAA01A5A0032907 1980 X X
    308 GTSi 32925 ZFFAA02A9A0032925 1980 X X
    308 GTSi 32929 ZFFAA02A6A0032929 1980 X X
    308 GTSi 32939 ZFFAA02A9A0032939 1980 Red Cream
    308 GTSi 32941 ZFFAA02A7A0032941 1980 X X
    308 GTSi 32943 ZFFAA02A0A0032943 1980 Red Red
    308 GTSi 32945 ZFFAA02A4A0032945 1980 X X
    308 GTSi 32947 ZFFAA02A8A0032947 1980 Black Grey
    308 GTBi 32957 ZFFAA01A9A0032957 1980 Black Black
    308 GTSi 32959 ZFFAA02A4A0032959 1980 Red Bordeaux
    308 GTSi 32963 ZFFAA02A6A0032963 1980 Red Black
    308 GTSi 32967 ZFFAA02A3A0032967 1980 Red Black
    308 GTSi 32969 ZFFAA02A7A0032969 1980 Burgundy Black
    308 GTSi 32971 ZFFAA02A5A0032971 1980 Black Black
    308 GTSi 32973 ZFFAA02A9A0032973 1980 X X
    308 GTSi 32993 ZFFAA02A4A0032993 1980 X X
    308 GTSi 32995 ZFFAA02A8A0032995 1980 X X
    308 GTSi 32997 ZFFAA02A1A0032997 1980 X X
    308 GTSi 32999 ZFFAA02A5A0032999 1980 X X
    308 GTSi 33003 ZFFAA02A1A0033003 1980 X X
    308 GTSi 33015 ZFFAA02A8A0033015 1980 X X
    308 GTBi 33033 ZFFAA01A8A0033033 1980 Black Black
    308 GTSi 33037 ZFFAA02A7A0033037 1980 X X
    308 GTBi 33075 ZFFAA01A2A0033075 1980 Red Black
    308 GTSi 33091 ZFFAA02A2A0033091 1980 X X
    308 GTSi 33093 ZFFAA02A6A0033093 1980 X X
    308 GTSi 33101 ZFFAA02A1A0033101 1980 X X
    308 GTBi 33111 ZFFAA01A2A0033111 1980 X X
    308 GTSi 33115 ZFFAA02A1A0033115 1980 X X
    308 GTSi 33141 ZFFAA02A2A0033141 1980 X X
    308 GTSi 33143 ZFFAA02A6A0033143 1980 X X
    308 GTSi 33147 ZFFAA02A3A0033147 1980 X X
    308 GTSi 33149 ZFFAA02A7A0033149 1980 Red Black
    308 GTSi 33153 ZFFAA02A9A0033153 1980 X X
    308 GTSi 33155 ZFFAA02A2A0033155 1980 X X
    308 GTSi 33157 ZFFAA02A6A0033157 1980 X X
    308 GTSi 33163 ZFFAA02A1A0033163 1980 X X
    308 GTSi 33167 ZFFAA02A9A0033167 1980 X X
    308 GTSi 33169 ZFFAA02A2A0033169 1980 X X
    308 Spider Conversion 33181 ZFFAA02A3A0033181 1980 Red Tan
    308 GTSi 33183 ZFFAA02A7A0033183 1980 Black X
    308 GTSi 33185 ZFFAA02A0A0033185 1980 X X
    308 GTBi 33189 ZFFAA01A6A0033189 1980 Red Black
    308 GTSi 33195 ZFFAA02A3A0033195 1980 Yellow Tobacco
    308 GTSi 33201 ZFFAA02A5A0033201 1980 Yellow Black
    308 GTSi 33207 ZFFAA02A6A0033207 1980 X X
    308 GTSi 33225 ZFFAA02A8A0033225 1980 X X
    308 GTSi 33227 ZFFAA02A1A0033227 1980 Red Tan
    308 GTSi 33229 ZFFAA02A5A0033229 1980 X X
    308 GTSi 33231 ZFFAA02A3A0033231 1980 X X
    308 GTSi 33235 ZFFAA02A0A0033235 1980 Red Tan
    308 GTSi 33247 ZFFAA02A7A0033247 1980 Red Tan
    308 GTSi 33255 ZFFAA02A6A0033255 1980 X X
    308 GTSi 33257 ZFFAA02AXA0033257 1980 X X
    308 GTSi 33261 ZFFAA02A1A0033261 1980 X X
    308 GTSi 33267 ZFFAA02A2A0033267 1980 X X
    308 GTSi 33299 ZFFAA02A4A0033299 1980 X X
    308 GTSi 33303 ZFFAA02A2A0033303 1980 X X
    308 GTSi 33319 ZFFAA02A6A0033319 1980 X X
    308 GTSi 33323 ZFFAA02A8A0033323 1980 X X
    308 GTBi 33335 ZFFAA01A2A0033335 1980 White Red
    308 GTBi 33339 ZFFAA01AXA0033339 1980 Red Tan
    308 GTSi 33341 ZFFAA02AXA0033341 1980 X X
    308 GTSi 33343 ZFFAA02A3A0033343 1980 Metallic Green Tan
    308 GTSi 33345 ZFFAA02A7A0033345 1980 X X
    308 GTSi 33347 ZFFAA02A0A0033347 1980 X X
    308 GTSi 33359 ZFFAA02A7A0033359 1980 X X
    308 GTSi 33361 ZFFAA02A5A0033361 1980 Red Black
    308 GTSi 33363 ZFFAA02A9A0033363 1980 X X
    308 GTSi 33365 ZFFAA02A2A0033365 1980 X X
    308 GTSi 33367 ZFFAA02A6A0033367 1980 Black Tan
    308 GTSi 33369 ZFFAA02AXA0033369 1980 Red Black
    308 GTBi 33373 ZFFAA01AXA0033373 1980 X X
    308 GTBi 33375 ZFFAA01A3A0033375 1980 X X
    308 GTSi 33391 ZFFAA02A3A0033391 1980 X X
    308 GTSi 33393 ZFFAA02A7A0033393 1980 X X
    308 GTSi 33397 ZFFAA02A4A0033397 1980 X X
    308 GTSi 33399 ZFFAA02A8A0033399 1980 X X
    308 GTSi 33407 ZFFAA02A3A0033407 1980 X X
    308 GTSi 33409 ZFFAA02A7A0033409 1980 X X
    308 GTSi 33413 ZFFAA02A9A0033413 1980 Black Black
    308 GTSi 33427 ZFFAA02A9A0033427 1980 X X
    308 GTSi 33433 ZFFAA02A4A0033433 1980 X X
    308 GTBi 33467 ZFFAA01A8A0033467 1980 Yellow Black
    308 GTSi 33471 ZFFAA02A1A0033471 1980 Silver Red
    308 GTSi 33473 ZFFAA02A5A0033473 1980 X X
    308 GTSi 33485 ZFFAA02A1A0033485 1980 X X
    308 GTSi 33505 ZFFAA02A3A0033505 1980 X X
    308 GTSi 33507 ZFFAA02A7A0033507 1980 X X
    308 GTBi 33527 ZFFAA01A0A0033527 1980 X X
    308 GTSi 33535 ZFFAA02A1A0033535 1980 X X
    308 GTSi 33537 ZFFAA02A5A0033537 1980 X X
    308 GTSi 33541 ZFFAA02A7A0033541 1980 X X
    308 GTSi 33547 ZFFAA02A8A0033547 1980 X X
    308 GTSi 33553 ZFFAA02A3A0033553 1980 X X
    308 GTBi 33557 ZFFAA01A9A0033557 1980 X X
    308 GTSi 33573 ZFFAA02A9A0033573 1980 X X
    308 GTSi 33575 ZFFAA02A2A0033575 1980 Red Black
    308 GTSi 33579 ZFFAA02AXA0033579 1980 X X
    308 GTBi 33583 ZFFAA01AXA0033583 1980 X X
    308 GTSi 33587 ZFFAA02A9A0033587 1980 X X
    308 GTSi 33591 ZFFAA02A0A0033591 1980 X X
    308 GTSi 33597 ZFFAA02A1A0033597 1980 Red Black
    308 GTSi 33599 ZFFAA02A5A0033599 1980 X X
    308 GTSi 33603 ZFFAA02A3A0033603 1980 Red Tan
    308 GTSi 33605 ZFFAA02A7A0033605 1980 X X
    308 GTSi 33607 ZFFAA02A0A0033607 1980 Red Tan
    308 GTSi 33615 ZFFAA02AXA0033615 1980 X X
    308 GTSi 33639 ZFFAA02A2A0033639 1980 Red Tan
    308 GTSi 33657 ZFFAA02A4A0033657 1980 X X
    308 GTSi 33661 ZFFAA02A6A0033661 1980 Red Black
    308 GTSi 33667 ZFFAA02A7A0033667 1980 X X
    308 GTSi 33675 ZFFAA02A6A0033675 1980 X X
    308 GTSi 33677 ZFFAA02AXA0033677 1980 Black Red
    308 GTSi 33679 ZFFAA02A3A0033679 1980 X X
    308 GTSi 33683 ZFFAA02A5A0033683 1980 Yellow Brown
    308 GTSi 33685 ZFFAA02A9A0033685 1980 X X
    308 GTSi 33695 ZFFAA02A1A0033695 1980 X X
    308 GTSi 33705 ZFFAA02A0A0033705 1980 Red Black
    308 GTSi 33709 ZFFAA02A8A0033709 1980 Red Black
    308 GTSi 33733 ZFFAA02A5A0033733 1980 X X
    308 GTSi 33739 ZFFAA02A6A0033739 1980 X X
    308 GTSi 33743 ZFFAA02A8A0033743 1980 X X
    308 GTSi 33769 ZFFAA02A4A0033769 1980 X X
    308 GTSi 33779 ZFFAA02A7A0033779 1980 X X
    308 GTSi 33781 ZFFAA02A5A0033781 1980 X X
    308 GTSi 33785 ZFFAA02A2A0033785 1980 Red Black
    308 GTSi 33787 ZFFAA02A6A0033787 1980 X X
    308 GTSi 33815 ZFFAA02A7A0033815 1980 X X
    308 GTSi 33817 ZFFAA02A0A0033817 1980 X X
    308 GTSi 33823 ZFFAA02A6A0033823 1980 X X
    308 GTSi 33827 ZFFAA02A3A0033827 1980 Black X
    308 GTSi 33861 ZFFAA02A3A0033861 1980 X X
    308 GTSi 33863 ZFFAA02A7A0033863 1980 Red Black
    308 GTSi 33883 ZFFAA02A2A0033883 1980 X X
    308 GTSi 33885 ZFFAA02A6A0033885 1980 X X
    308 GTSi 33899 ZFFAA02A6A0033899 1980 X X
    308 GTSi 33901 ZFFAA02A0A0033901 1980 Red Tan
    308 GTSi 33903 ZFFAA02A4A0033903 1980 X X
    308 GTSi 33907 ZFFAA02A1A0033907 1980 X X
    308 GTSi 33919 ZFFAA02A8A0033919 1980 X X
    308 GTSi 33921 ZFFAA02A6A0033921 1980 X X
    308 GTSi 33933 ZFFAA02A2A0033933 1980 X X
    308 GTSi 33935 ZFFAA02A6A0033935 1980 X X
    308 GTSi 33937 ZFFAA02AXA0033937 1980 X X
    308 GTSi 33951 ZFFAA02A4A0033951 1980 X X
    308 GTBi 33961 ZFFAA01A5A0033961 1980 X X
    308 GTBi 33963 ZFFAA01A9A0033963 1980 Red Tan
    308 GTBi 33975 ZFFAA01A5A0033975 1980 Red Tan
    308 GTSi 33981 ZFFAA02A2A0033981 1980 X X
    308 GTSi 33993 ZFFAA02A9A0033993 1980 X X
    308 GTSi 33997 ZFFAA02A6A0033997 1980 X X
    308 GTSi 34001 ZFFAA02A2A0034001 1980 X X
    308 GTSi 34009 ZFFAA02A7A0034009 1980 X X
    308 GTSi 34013 ZFFAA02A9A0034013 1980 X X
    308 GTSi 34031 ZFFAA02A0A0034031 1980 Silver Black
    308 GTSi 34033 ZFFAA02A4A0034033 1980 X X
    308 GTSi 34035 ZFFAA02A8A0034035 1980 X X
    308 GTSi 34039 ZFFAA02A5A0034039 1980 X X
    308 GTSi 34051 ZFFAA02A6A0034051 1980 Red Tan
    308 GTBi 34053 ZFFAA01A8A0034053 1980 Red Black
    308 GTBi 34055 ZFFAA01A1A0034055 1980 X X
    308 GTSi 34067 ZFFAA02AXA0034067 1980 X X
    308 GTSi 34069 ZFFAA02A3A0034069 1980 X X
    308 GTSi 34089 ZFFAA02A9A0034089 1980 Burgundy Black
    308 GTSi 34091 ZFFAA02A7A0034091 1980 X X
    308 GTBi 34095 ZFFAA01A2A0034095 1980 Red Black
    308 GTSi 34105 ZFFAA02A3A0034105 1980 Red Tan
    308 GTSi 34107 ZFFAA02A7A0034107 1980 X X
    308 GTSi 34109 ZFFAA02A0A0034109 1980 X X
    308 GTSi 34143 ZFFAA02A0A0034143 1980 X X
    308 GTSi 34145 ZFFAA02A4A0034145 1980 X X
    308 GTSi 34167 ZFFAA02A3A0034167 1980 X X
    308 GTSi 34169 ZFFAA02A7A0034169 1980 Grigio Ferro Metallic Bordeaux
    308 GTSi 34187 ZFFAA02A9A0034187 1980 Red Cream
    308 GTBi 34191 ZFFAA01A9A0034191 1980 X X
    308 GTSi 34207 ZFFAA02A0A0034207 1980 Red Tan
    308 GTSi 34209 ZFFAA02A4A0034209 1980 Red X
    308 GTSi 34211 ZFFAA02A2A0034211 1980 X X
    308 GTSi 34213 ZFFAA02A6A0034213 1980 X X
    308 GTSi 34215 ZFFAA02AXA0034215 1980 X X
    308 GTSi 34217 ZFFAA02A3A0034217 1980 Red Tan
    308 GTSi 34237 ZFFAA02A9A0034237 1980 Red X
    308 GTSi 34257 ZFFAA02A4A0034257 1980 X X
    308 GTSi 34259 ZFFAA02A8A0034259 1980 Red Tan
    308 GTBi 34261 ZFFAA01A4A0034261 1980 X X
    308 GTSi 34285 ZFFAA02A9A0034285 1980 X X
    308 GTSi 34287 ZFFAA02A2A0034287 1980 X X
    308 GTSi 34303 ZFFAA02A7A0034303 1980 Red Black
    308 GTSi 34311 ZFFAA02A6A0034311 1980 Red Black
    308 GTSi 34325 ZFFAA02A6A0034325 1980 X X
    308 GTSi 34327 ZFFAA02AXA0034327 1980 X X
    308 GTSi 34335 ZFFAA02A9A0034335 1980 X X
    308 GTSi 34337 ZFFAA02A2A0034337 1980 Red Black
    308 GTSi 34341 ZFFAA02A4A0034341 1980 X X
    308 GTSi 34365 ZFFAA02A7A0034365 1980 X X
    308 GTSi 34367 ZFFAA02A0A0034367 1980 X X
    308 GTSi 34369 ZFFAA02A4A0034369 1980 X X
    308 GTSi 34373 ZFFAA02A6A0034373 1980 X X
    308 GTSi 34375 ZFFAA02AXA0034375 1980 X X
    308 GTSi 34393 ZFFAA02A1A0034393 1980 X X
    308 GTSi 34423 ZFFAA02A6A0034423 1980 X X
    308 GTSi 34435 ZFFAA02A2A0034435 1980 Red Black
    308 GTSi 34481 ZFFAA02A9A0034481 1980 Red Black
    308 GTSi 34495 ZFFAA02A9A0034495 1980 Red Red
  17. Rifledriver
    37,101
    81 FNA cars
    308 GTBi 34531 ZFFAA01A5B0034531 1981 X X
    308 GTSi 34533 ZFFAA02A0B0034533 1981 X X
    308 GTSi 34535 ZFFAA02A4B0034535 1981 X X
    308 GTBi 34537 ZFFAA01A6B0034537 1981 X X
    308 GTSi 34541 ZFFAA02AXB0034541 1981 X X
    308 GTSi 34549 ZFFAA02A4B0034549 1981 X X
    308 GTSi 34553 ZFFAA02A6B0034553 1981 X X
    288 GTO Rebody 34555 ZFFAA01A8B0034555 1981 Black Black
    308 GTSi 34559 ZFFAA02A7B0034559 1981 X X
    308 GTSi 34561 ZFFAA02A5B0034561 1981 X X
    308 GTSi 34563 ZFFAA02A9B0034563 1981 X X
    308 GTSi 34565 ZFFAA02A2B0034565 1981 X X
    308 GTSi 34567 ZFFAA02A6B0034567 1981 X X
    308 GTSi 34571 ZFFAA02A8B0034571 1981 X X
    308 GTSi 34573 ZFFAA02A1B0034573 1981 X X
    308 GTSi 34575 ZFFAA02A5B0034575 1981 X X
    308 GTBi 34577 ZFFAA01A7B0034577 1981 X X
    308 GTBi 34579 ZFFAA01A0B0034579 1981 X X
    308 GTSi 34581 ZFFAA02A0B0034581 1981 Red Tan
    308 GTSi 34583 ZFFAA02A4B0034583 1981 X X
    308 GTSi 34585 ZFFAA02A8B0034585 1981 X X
    308 GTSi 34603 ZFFAA02A6B0034603 1981 Red Tan
    308 GTSi 34605 ZFFAA02AXB0034605 1981 X X
    308 GTSi 34607 ZFFAA02A3B0034607 1981 X X
    308 GTSi 34609 ZFFAA02A7B0034609 1981 X X
    308 GTSi 34627 ZFFAA02A9B0034627 1981 X X
    308 GTSi 34629 ZFFAA02A2B0034629 1981 X X
    308 GTSi 34631 ZFFAA02A0B0034631 1981 Yellow Brown
    308 GTSi 34633 ZFFAA02A4B0034633 1981 X X
    308 GTSi 34637 ZFFAA02A1B0034637 1981 X X
    308 GTSi 34639 ZFFAA02A5B0034639 1981 X X
    308 GTSi 34641 ZFFAA02A3B0034641 1981 Bronze Cream
    308 GTSi 34647 ZFFAA02A4B0034647 1981 Metallic Green X
    308 GTSi 34649 ZFFAA02A8B0034649 1981 Yellow Black
    308 GTSi 34653 ZFFAA02AXB0034653 1981 X X
    308 GTSi 34675 ZFFAA02A9B0034675 1981 X X
    308 GTSi 34677 ZFFAA02A2B0034677 1981 X X
    308 GTSi 34679 ZFFAA02A6B0034679 1981 X X
    308 GTBi 34681 ZFFAA01A2B0034681 1981 Red Tan
    308 GTSi 34697 ZFFAA02A8B0034697 1981 X X
    308 GTBi 34703 ZFFAA01A8B0034703 1981 Silver Black
    308 GTSi 34723 ZFFAA02A5B0034723 1981 X X
    308 GTSi 34725 ZFFAA02A9B0034725 1981 X X
    308 GTSi 34727 ZFFAA02A2B0034727 1981 X X
    308 GTBi 34729 ZFFAA01A4B0034729 1981 X X
    308 GTBi 34731 ZFFAA01A2B0034731 1981 Black Red
    308 GTSi 34747 ZFFAA02A8B0034747 1981 X X
    308 GTSi 34769 ZFFAA02A7B0034769 1981 X X
    308 GTSi 34771 ZFFAA02A5B0034771 1981 X X
    308 GTBi 34773 ZFFAA01A7B0034773 1981 X X
    308 GTSi 34791 ZFFAA02A0B0034791 1981 Red Black
    308 GTSi 34793 ZFFAA02A4B0034793 1981 Black Black
    308 GTSi 34811 ZFFAA02A2B0034811 1981 X X
    308 GTSi 34813 ZFFAA02A6B0034813 1981 Red Black
    308 GTSi 34827 ZFFAA02A6B0034827 1981 X X
    308 GTSi 34829 ZFFAA02AXB0034829 1981 X X
    308 GTSi 34831 ZFFAA02A8B0034831 1981 X X
    308 GTSi 34835 ZFFAA02A5B0034835 1981 Red Tan
    308 GTBi 34839 ZFFAA01A0B0034839 1981 X X
    308 GTSi 34851 ZFFAA02A3B0034851 1981 X X
    308 GTSi 34853 ZFFAA02A7B0034853 1981 Red Black
    308 GTSi 34855 ZFFAA02A0B0034855 1981 X X
    308 GTSi 34857 ZFFAA02A4B0034857 1981 X X
    308 GTSi 34859 ZFFAA02A8B0034859 1981 X X
    308 GTSi 34861 ZFFAA02A6B0034861 1981 X X
    308 GTSi 34863 ZFFAA02AXB0034863 1981 X X
    308 GTSi 34875 ZFFAA02A6B0034875 1981 X X
    308 GTSi 34877 ZFFAA02AXB0034877 1981 White Black
    308 GTSi 34879 ZFFAA02A3B0034879 1981 X X
    308 GTBi 34881 ZFFAA01AXB0034881 1981 X X
    308 GTBi 34883 ZFFAA01A3B0034883 1981 Red Black
    308 GTSi 34907 ZFFAA02A4B0034907 1981 X X
    308 GTSi 34909 ZFFAA02A8B0034909 1981 X X
    308 GTSi 34911 ZFFAA02A6B0034911 1981 X X
    308 GTSi 34913 ZFFAA02AXB0034913 1981 X X
    308 GTSi 34915 ZFFAA02A3B0034915 1981 X X
    308 GTSi 34927 ZFFAA02AXB0034927 1981 X X
    308 GTSi 34929 ZFFAA02A3B0034929 1981 X X
    308 GTSi 34931 ZFFAA02A1B0034931 1981 X X
    308 GTSi 34933 ZFFAA02A5B0034933 1981 X X
    308 GTSi 34955 ZFFAA02A4B0034955 1981 X X
    308 GTBi 34959 ZFFAA01AXB0034959 1981 X X
    308 GTSi 34969 ZFFAA02A4B0034969 1981 Red Black
    308 GTSi 34973 ZFFAA02A6B0034973 1981 Red Tan
    308 GTSi 34975 ZFFAA02AXB0034975 1981 X X
    308 GTSi 34977 ZFFAA02A3B0034977 1981 X X
    308 GTSi 34979 ZFFAA02A7B0034979 1981 X X
    308 GTSi 34999 ZFFAA02A2B0034999 1981 X X
    308 GTSi 35001 ZFFAA02A5B0035001 1981 X X
    308 GTBi 35003 ZFFAA01A7B0035003 1981 X X
    308 GTSi 35013 ZFFAA02A1B0035013 1981 X X
    308 GTSi 35015 ZFFAA02A5B0035015 1981 X X
    308 GTSi 35017 ZFFAA02A9B0035017 1981 X X
    308 GTSi 35019 ZFFAA02A2B0035019 1981 Blue Tan
    308 GTSi 35021 ZFFAA02A0B0035021 1981 X X
    308 GTSi 35023 ZFFAA02A4B0035023 1981 X X
    308 GTSi 35025 ZFFAA02A8B0035025 1981 X X
    308 GTSi 35027 ZFFAA02A1B0035027 1981 Yellow Black
    308 GTSi 35041 ZFFAA02A6B0035041 1981 X X
    308 GTSi 35045 ZFFAA02A3B0035045 1981 X X
    308 GTSi 35047 ZFFAA02A7B0035047 1981 X X
    308 GTBi 35051 ZFFAA01A7B0035051 1981 X X
    308 GTSi 35061 ZFFAA02A1B0035061 1981 X X
    308 GTSi 35065 ZFFAA02A9B0035065 1981 X X
    308 GTSi 35067 ZFFAA02A2B0035067 1981 X X
    308 GTSi 35069 ZFFAA02A6B0035069 1981 X X
    308 GTBi 35071 ZFFAA01A2B0035071 1981 X X
    308 GTSi 35079 ZFFAA02A9B0035079 1981 X X
    308 GTSi 35081 ZFFAA02A7B0035081 1981 X X
    308 GTSi 35083 ZFFAA02A0B0035083 1981 Silver Black
    308 GTSi 35085 ZFFAA02A4B0035085 1981 Red Black
    308 GTSi 35087 ZFFAA02A8B0035087 1981 X X
    308 GTBi 35091 ZFFAA01A8B0035091 1981 X X
    308 GTSi 35117 ZFFAA02A2B0035117 1981 Yellow Black
    308 GTSi 35119 ZFFAA02A6B0035119 1981 Red Tan
    308 GTSi 35121 ZFFAA02A4B0035121 1981 X X
    308 GTBi 35125 ZFFAA01AXB0035125 1981 X X
    308 GTSi 35137 ZFFAA02A8B0035137 1981 X X
    308 GTSi 35139 ZFFAA02A1B0035139 1981 X X
    308 GTSi 35141 ZFFAA02AXB0035141 1981 X X
    308 GTSi 35143 ZFFAA02A3B0035143 1981 Red Tan
    308 GTBi 35145 ZFFAA01A5B0035145 1981 Rosso Rubino Tan
    308 GTSi 35159 ZFFAA02A7B0035159 1981 X X
    308 GTBi 35163 ZFFAA01A7B0035163 1981 Red Black
    308 GTSi 35189 ZFFAA02A5B0035189 1981 X X
    308 GTSi 35191 ZFFAA02A3B0035191 1981 X X
    308 GTSi 35193 ZFFAA02A7B0035193 1981 X X
    308 GTSi 35195 ZFFAA02A0B0035195 1981 X X
    308 GTSi 35211 ZFFAA02A5B0035211 1981 X X
    308 GTSi 35213 ZFFAA02A9B0035213 1981 Red Black
    308 GTSi 35215 ZFFAA02A2B0035215 1981 X X
    308 GTSi 35225 ZFFAA02A5B0035225 1981 X X
    308 GTSi 35227 ZFFAA02A9B0035227 1981 X X
    308 GTSi 35229 ZFFAA02A2B0035229 1981 Red Tan
    308 GTSi 35231 ZFFAA02A0B0035231 1981 Red Tan
    308 GTSi 35247 ZFFAA02A4B0035247 1981 X X
    308 GTSi 35249 ZFFAA02A8B0035249 1981 X X
    308 GTSi 35251 ZFFAA02A6B0035251 1981 X X
    308 GTSi 35253 ZFFAA02AXB0035253 1981 X X
    308 GTSi 35255 ZFFAA02A3B0035255 1981 Red Black
    308 GTSi 35281 ZFFAA02A4B0035281 1981 X X
    308 GTSi 35313 ZFFAA02A2B0035313 1981 X X
    308 GTSi 35315 ZFFAA02A6B0035315 1981 X X
    308 GTSi 35317 ZFFAA02AXB0035317 1981 X X
    308 GTSi 35319 ZFFAA02A3B0035319 1981 X X
    308 GTSi 35333 ZFFAA02A8B0035333 1981 X X
    308 GTSi 35335 ZFFAA02A1B0035335 1981 X X
    308 GTSi 35337 ZFFAA02A5B0035337 1981 X X
    308 GTBi 35345 ZFFAA01A2B0035345 1981 X X
    308 GTBi 35347 ZFFAA01A6B0035347 1981 X X
    308 GTSi 35355 ZFFAA02A7B0035355 1981 X X
    308 GTSi 35359 ZFFAA02A4B0035359 1981 X X
    308 GTSi 35377 ZFFAA02A6B0035377 1981 X X
    308 GTSi 35399 ZFFAA02A5B0035399 1981 X X
    308 GTSi 35401 ZFFAA02AXB0035401 1981 X X
    308 GTSi 35403 ZFFAA02A3B0035403 1981 X X
    308 GTSi 35421 ZFFAA02A5B0035421 1981 X X
    308 GTSi 35425 ZFFAA02A2B0035425 1981 X X
    308 GTSi 35427 ZFFAA02A6B0035427 1981 X X
    288 GTO Rebody 35429 ZFFAA02AXB0035429 1981 Red Black
    308 GTSi 35449 ZFFAA02A5B0035449 1981 X X
    308 GTSi 35453 ZFFAA02A7B0035453 1981 Red Black
    308 GTSi 35455 ZFFAA02A0B0035455 1981 X X
    308 GTSi 35465 ZFFAA02A3B0035465 1981 Red Black
    308 GTSi 35469 ZFFAA02A0B0035469 1981 X X
    308 GTSi 35473 ZFFAA02A2B0035473 1981 X X
    308 GTSi 35487 ZFFAA02A2B0035487 1981 X X
    308 GTSi 35489 ZFFAA02A6B0035489 1981 X X
    308 GTSi 35491 ZFFAA02A4B0035491 1981 X X
    308 GTSi 35493 ZFFAA02A8B0035493 1981 X X
    308 GTSi 35513 ZFFAA02AXB0035513 1981 X X
    308 GTSi 35515 ZFFAA02A3B0035515 1981 X X
    308 GTSi 35547 ZFFAA02A5B0035547 1981 X X
    308 GTSi 35549 ZFFAA02A9B0035549 1981 X X
    308 GTSi 35551 ZFFAA02A7B0035551 1981 Yellow Black
    308 GTSi 35553 ZFFAA02A0B0035553 1981 X X
    308 GTSi 35555 ZFFAA02A4B0035555 1981 Red Tan
    308 GTSi 35557 ZFFAA02A8B0035557 1981 X X
    308 GTBi 35559 ZFFAA01AXB0035559 1981 Red Tan
    308 GTSi 35575 ZFFAA02AXB0035575 1981 X X
    308 GTSi 35577 ZFFAA02A3B0035577 1981 X X
    308 GTSi 35579 ZFFAA02A7B0035579 1981 Black Red
    308 GTSi 35583 ZFFAA02A9B0035583 1981 Red Black
    308 GTSi 35585 ZFFAA02A2B0035585 1981 X X
    308 GTSi 35591 ZFFAA02A8B0035591 1981 X X
    308 GTSi 35593 ZFFAA02A1B0035593 1981 Red Black
    308 GTSi 35599 ZFFAA02A2B0035599 1981 X X
    308 GTSi 35621 ZFFAA02A2B0035621 1981 X X
    308 GTSi 35623 ZFFAA02A6B0035623 1981 X X
    308 GTSi 35625 ZFFAA02AXB0035625 1981 X X
    308 GTSi 35637 ZFFAA02A6B0035637 1981 X X
    308 GTSi 35639 ZFFAA02AXB0035639 1981 Red Black
    308 GTSi 35641 ZFFAA02A8B0035641 1981 X X
    308 GTSi 35669 ZFFAA02A8B0035669 1981 X X
    308 GTSi 35671 ZFFAA02A6B0035671 1981 X X
    308 GTSi 35673 ZFFAA02AXB0035673 1981 X X
    308 GTSi 35689 ZFFAA02A3B0035689 1981 X X
    308 GTSi 35691 ZFFAA02A1B0035691 1981 White Red
    308 GTSi 35693 ZFFAA02A5B0035693 1981 X X
    308 GTBi 35699 ZFFAA01A4B0035699 1981 X X
    308 GTSi 35709 ZFFAA02A5B0035709 1981 X X
    308 GTSi 35711 ZFFAA02A3B0035711 1981 X X
    308 GTSi 35715 ZFFAA02A0B0035715 1981 X X
    308 GTSi 35737 ZFFAA02AXB0035737 1981 X X
    308 GTSi 35741 ZFFAA02A1B0035741 1981 Red Tan
    308 GTSi 35755 ZFFAA02A1B0035755 1981 Red Black
    308 GTBi 35759 ZFFAA01A7B0035759 1981 X X
    308 GTSi 35773 ZFFAA02A3B0035773 1981 X X
    308 GTSi 35775 ZFFAA02A7B0035775 1981 X X
    308 GTSi 35777 ZFFAA02A0B0035777 1981 White Black
    308 GTSi 35779 ZFFAA02A4B0035779 1981 X X
    308 GTSi 35783 ZFFAA02A6B0035783 1981 X X
    308 GTSi 35785 ZFFAA02AXB0035785 1981 X X
    308 GTSi 35801 ZFFAA02A4B0035801 1981 X X
    308 GTSi 35805 ZFFAA02A1B0035805 1981 Red Tan
    308 GTSi 35819 ZFFAA02A1B0035819 1981 Silver Red
    308 GTSi 35821 ZFFAA02AXB0035821 1981 X X
    308 GTSi 35823 ZFFAA02A3B0035823 1981 X X
    308 GTSi 35825 ZFFAA02A7B0035825 1981 X X
    308 GTSi 35849 ZFFAA02AXB0035849 1981 X X
    308 GTSi 35859 ZFFAA02A2B0035859 1981 X X
    308 GTSi 35861 ZFFAA02A0B0035861 1981 X X
    308 GTSi 35863 ZFFAA02A4B0035863 1981 X X
    308 GTSi 35865 ZFFAA02A8B0035865 1981 X X
    308 GTSi 35893 ZFFAA02A2B0035893 1981 X X
    308 GTSi 35895 ZFFAA02A6B0035895 1981 X X
    308 GTSi 35913 ZFFAA02A4B0035913 1981 X X
    308 GTSi 35915 ZFFAA02A8B0035915 1981 X X
    308 GTSi 35917 ZFFAA02A1B0035917 1981 X X
    308 GTSi 35919 ZFFAA02A5B0035919 1981 X X
    308 GTSi 35921 ZFFAA02A3B0035921 1981 X X
    308 GTSi 35923 ZFFAA02A7B0035923 1981 X X
    308 GTSi 35929 ZFFAA02A8B0035929 1981 Red Tan
    308 GTSi 35933 ZFFAA02AXB0035933 1981 Black Red
    308 GTSi 35949 ZFFAA02A3B0035949 1981 X X
    308 GTSi 35951 ZFFAA02A1B0035951 1981 X X
    308 GTSi 35953 ZFFAA02A5B0035953 1981 White Black
    308 GTSi 35955 ZFFAA02A9B0035955 1981 X X
    308 GTSi 35959 ZFFAA02A6B0035959 1981 X X
    308 GTSi 35975 ZFFAA02A4B0035975 1981 X X
    308 GTSi 35989 ZFFAA02A4B0035989 1981 X X
    308 GTSi 36017 ZFFAA02A3B0036017 1981 X X
    308 GTSi 36019 ZFFAA02A7B0036019 1981 X X
    308 GTSi 36021 ZFFAA02A5B0036021 1981 Black Black
    308 GTSi 36025 ZFFAA02A2B0036025 1981 X X
    308 GTSi 36047 ZFFAA02A1B0036047 1981 X X
    308 GTSi 36063 ZFFAA02AXB0036063 1981 Burgundy Black
    308 GTSi 36065 ZFFAA02A3B0036065 1981 X X
    308 GTSi 36067 ZFFAA02A7B0036067 1981 Red Red
    308 GTSi 36069 ZFFAA02A0B0036069 1981 Black Black
    308 GTSi 36077 ZFFAA02AXB0036077 1981 Silver Black
    308 GTSi 36101 ZFFAA02A3B0036101 1981 X X
    308 GTSi 36103 ZFFAA02A7B0036103 1981 X X
    308 GTSi 36115 ZFFAA02A3B0036115 1981 X X
    308 GTSi 36119 ZFFAA02A0B0036119 1981 X X
    308 GTSi 36131 ZFFAA02A1B0036131 1981 Black Red
    308 GTSi 36133 ZFFAA02A5B0036133 1981 X X
    308 GTSi 36135 ZFFAA02A9B0036135 1981 X X
    308 GTBi 36139 ZFFAA01A4B0036139 1981 X X
    308 GTSi 36159 ZFFAA02A1B0036159 1981 X X
    308 GTSi 36181 ZFFAA02A5B0036181 1981 X X
    308 GTSi 36183 ZFFAA02A9B0036183 1981 Grey Black
    308 GTSi 36205 ZFFAA02A4B0036205 1981 Red Black
    308 GTSi 36221 ZFFAA02A2B0036221 1981 X X
    308 GTSi 36223 ZFFAA02A6B0036223 1981 X X
    308 GTSi 36225 ZFFAA02AXB0036225 1981 X X
    308 GTSi 36229 ZFFAA02A7B0036229 1981 X X
    308 GTSi 36239 ZFFAA02AXB0036239 1981 X X
    308 GTSi 36241 ZFFAA02A8B0036241 1981 X X
    308 GTSi 36277 ZFFAA02A7B0036277 1981 X X
    308 GTBi 36281 ZFFAA01A7B0036281 1981 X X
    308 GTSi 36293 ZFFAA02A5B0036293 1981 Black Tan
    308 GTSi 36295 ZFFAA02A9B0036295 1981 X X
    308 GTSi 36297 ZFFAA02A2B0036297 1981 X X
    308 GTSi 36315 ZFFAA02A0B0036315 1981 Red Tan
    308 GTSi 36333 ZFFAA02A2B0036333 1981 Red Tan
    308 GTSi 36335 ZFFAA02A6B0036335 1981 X X
    308 GTSi 36337 ZFFAA02AXB0036337 1981 X X
    308 GTSi 36339 ZFFAA02A3B0036339 1981 X X
    308 GTSi 36355 ZFFAA02A1B0036355 1981 X X
    308 GTSi 36357 ZFFAA02A5B0036357 1981 X X
    308 GTSi 36359 ZFFAA02A9B0036359 1981 X X
    308 GTSi 36361 ZFFAA02A7B0036361 1981 Red Tan
    308 GTSi 36381 ZFFAA02A2B0036381 1981 X X
    308 GTSi 36383 ZFFAA02A6B0036383 1981 X X
    308 GTSi 36385 ZFFAA02AXB0036385 1981 X X
    308 GTSi 36387 ZFFAA02A3B0036387 1981 X X
    308 GTSi 36401 ZFFAA02A4B0036401 1981 X X
    308 GTSi 36421 ZFFAA02AXB0036421 1981 X X
    308 GTSi 36423 ZFFAA02A3B0036423 1981 X X
    308 GTSi 36425 ZFFAA02A7B0036425 1981 Red Black
    308 GTSi 36437 ZFFAA02A3B0036437 1981 Red Tan
    308 GTSi 36467 ZFFAA02A1B0036467 1981 Red Tan
    308 GTSi 36471 ZFFAA02A3B0036471 1981 Red Tan
    308 GTSi 36473 ZFFAA02A7B0036473 1981 X X
    308 GTSi 36485 ZFFAA02A3B0036485 1981 X X
    308 GTSi 36487 ZFFAA02A7B0036487 1981 X X
    308 GTBi 36491 ZFFAA01A7B0036491 1981 X X
    308 GTSi 36503 ZFFAA02A1B0036503 1981 X X
    308 GTSi 36505 ZFFAA02A5B0036505 1981 Red Tan
    308 GTSi 36507 ZFFAA02A9B0036507 1981 X X
    308 GTBi 36509 ZFFAA01A0B0036509 1981 Red Black
    308 GTSi 36525 ZFFAA02A0B0036525 1981 Red Beige
    308 GTSi 36527 ZFFAA02A4B0036527 1981 X X
    308 GTSi 36545 ZFFAA02A6B0036545 1981 X X
    308 GTSi 36551 ZFFAA02A1B0036551 1981 X X
    308 GTSi 36577 ZFFAA02A8B0036577 1981 X X
    308 GTSi 36579 ZFFAA02A1B0036579 1981 X X
    308 GTSi 36597 ZFFAA02A3B0036597 1981 X X
    308 GTSi 36613 ZFFAA02A8B0036613 1981 Black Tan
    308 GTSi 36615 ZFFAA02A1B0036615 1981 X X
    308 GTSi 36619 ZFFAA02A9B0036619 1981 X X
    308 GTSi 36631 ZFFAA02AXB0036631 1981 X X
    308 GTSi 36635 ZFFAA02A7B0036635 1981 X X
    308 GTSi 36649 ZFFAA02A7B0036649 1981 Red Black
    308 GTSi 36653 ZFFAA02A9B0036653 1981 X X
    308 GTSi 36655 ZFFAA02A2B0036655 1981 X X
    308 GTSi 36683 ZFFAA02A7B0036683 1981 X X
    308 GTBi 36685 ZFFAA01A9B0036685 1981 X X
    308 GTBi 36687 ZFFAA01A2B0036687 1981 X X
    308 GTSi 36701 ZFFAA02A5B0036701 1981 X X
    308 GTSi 36703 ZFFAA02A9B0036703 1981 X X
    308 GTSi 36707 ZFFAA02A6B0036707 1981 Yellow Black
    308 GTSi 36723 ZFFAA02A4B0036723 1981 Black Beige
    308 GTSi 36725 ZFFAA02A8B0036725 1981 X X
    308 GTSi 36727 ZFFAA02A1B0036727 1981 X X
    308 GTSi 36743 ZFFAA02AXB0036743 1981 X X
    308 GTSi 36745 ZFFAA02A3B0036745 1981 X X
    308 GTSi 36747 ZFFAA02A7B0036747 1981 Red Black
    308 GTSi 36767 ZFFAA02A2B0036767 1981 X X
    308 GTSi 36769 ZFFAA02A6B0036769 1981 X X
    308 GTSi 36771 ZFFAA02A4B0036771 1981 Red Tan
    308 GTSi 36791 ZFFAA02AXB0036791 1981 X X
    308 GTSi 36793 ZFFAA02A3B0036793 1981 X X
    308 GTSi 36795 ZFFAA02A7B0036795 1981 X X
    308 GTSi 36817 ZFFAA02A2B0036817 1981 X X
    308 GTSi 36821 ZFFAA02A4B0036821 1981 X X
    308 GTSi 36835 ZFFAA02A4B0036835 1981 X X
    308 GTSi 36837 ZFFAA02A8B0036837 1981 X X
    308 GTSi 36839 ZFFAA02A1B0036839 1981 X X
    308 GTSi 36841 ZFFAA02AXB0036841 1981 X X
    308 GTSi 36857 ZFFAA02A3B0036857 1981 X X
    308 GTSi 36859 ZFFAA02A7B0036859 1981 X X
    308 GTSi 36861 ZFFAA02A5B0036861 1981 Red Black
    308 GTSi 36893 ZFFAA02A7B0036893 1981 X X
    308 GTSi 36895 ZFFAA02A0B0036895 1981 X X
    308 GTSi 36897 ZFFAA02A4B0036897 1981 White Black
    308 GTSi 36907 ZFFAA02A3B0036907 1981 X X
    308 GTSi 36909 ZFFAA02A7B0036909 1981 X X
    308 GTBi 36913 ZFFAA01A7B0036913 1981 X X
    308 GTSi 36931 ZFFAA02A0B0036931 1981 X X
    308 GTBi 36937 ZFFAA01AXB0036937 1981 X X
    308 GTSi 36947 ZFFAA02A4B0036947 1981 Black Red
    308 GTSi 36949 ZFFAA02A8B0036949 1981 X X
    308 GTSi 36953 ZFFAA02AXB0036953 1981 X X
    308 GTSi 36977 ZFFAA02A2B0036977 1981 X X
    308 GTSi 36979 ZFFAA02A6B0036979 1981 X X
    308 GTSi 36991 ZFFAA02A7B0036991 1981 X X
    308 GTSi 36993 ZFFAA02A0B0036993 1981 X X
    308 GTSi 36995 ZFFAA02A4B0036995 1981 X X
    308 GTSi 36997 ZFFAA02A8B0036997 1981 X X
    308 GTSi 37009 ZFFAA02A9B0037009 1981 X X
    308 GTSi 37011 ZFFAA02A7B0037011 1981 X X
    308 GTSi 37013 ZFFAA02A0B0037013 1981 X X
    308 GTSi 37015 ZFFAA02A4B0037015 1981 X X
    308 GTSi 37029 ZFFAA02A4B0037029 1981 X X
    308 GTSi 37031 ZFFAA02A2B0037031 1981 X X
    308 GTSi 37033 ZFFAA02A6B0037033 1981 X X
    308 GTSi 37035 ZFFAA02AXB0037035 1981 X X
    308 GTSi 37045 ZFFAA02A2B0037045 1981 X X
    308 GTSi 37047 ZFFAA02A6B0037047 1981 X X
    308 GTSi 37049 ZFFAA02AXB0037049 1981 Black Red
    308 GTSi 37077 ZFFAA02A4B0037077 1981 X X
    308 GTSi 37081 ZFFAA02A6B0037081 1981 X X
    308 GTSi 37093 ZFFAA02A2B0037093 1981 X X
    308 GTSi 37095 ZFFAA02A6B0037095 1981 X X
    308 GTSi 37097 ZFFAA02AXB0037097 1981 Red Black
    308 GTSi 37099 ZFFAA02A3B0037099 1981 Red Grey
    308 GTSi 37115 ZFFAA02A8B0037115 1981 X X
    308 GTSi 37117 ZFFAA02A1B0037117 1981 Red Tan
    308 GTBi 37121 ZFFAA01A1B0037121 1981 X X
    308 GTSi 37143 ZFFAA02A2B0037143 1981 X X
    308 GTSi 37145 ZFFAA02A6B0037145 1981 Silver Black
    308 GTSi 37147 ZFFAA02AXB0037147 1981 X X
    308 GTSi 37149 ZFFAA02A3B0037149 1981 X X
    308 GTSi 37161 ZFFAA02A4B0037161 1981 X X
    308 GTSi 37163 ZFFAA02A8B0037163 1981 X X
    308 GTSi 37165 ZFFAA02A1B0037165 1981 X X
    308 GTSi 37183 ZFFAA02A3B0037183 1981 X X
    308 GTSi 37185 ZFFAA02A7B0037185 1981 X X
    308 GTBi 37187 ZFFAA01A9B0037187 1981 Red Black
    308 GTSi 37195 ZFFAA02AXB0037195 1981 X X
    308 GTSi 37197 ZFFAA02A3B0037197 1981 X X
    308 GTBi 37203 ZFFAA01A3B0037203 1981 X X
    308 GTSi 37217 ZFFAA02A5B0037217 1981 X X
    308 GTSi 37219 ZFFAA02A9B0037219 1981 X X
    308 GTSi 37223 ZFFAA02A0B0037223 1981 X X
    308 GTSi 37251 ZFFAA02A5B0037251 1981 X X
    308 GTSi 37253 ZFFAA02A9B0037253 1981 X X
    308 GTSi 37255 ZFFAA02A2B0037255 1981 X X
    308 GTSi 37257 ZFFAA02A6B0037257 1981 X X
    308 GTSi 37265 ZFFAA02A5B0037265 1981 X X
    308 GTSi 37267 ZFFAA02A9B0037267 1981 X X
    308 GTSi 37269 ZFFAA02A2B0037269 1981 X X
    308 GTSi 37283 ZFFAA02A7B0037283 1981 Red Tan
    308 GTSi 37285 ZFFAA02A0B0037285 1981 X X
    308 GTSi 37287 ZFFAA02A4B0037287 1981 X X
    308 GTSi 37289 ZFFAA02A8B0037289 1981 X X
    308 GTBi 37313 ZFFAA01AXB0037313 1981 Black Tan
    308 GTBi 37315 ZFFAA01A3B0037315 1981 X X
    308 GTSi 37327 ZFFAA02A1B0037327 1981 Rosso Rubino Tan
    308 GTSi 37329 ZFFAA02A5B0037329 1981 X X
    308 GTSi 37331 ZFFAA02A3B0037331 1981 X X
    308 GTSi 37333 ZFFAA02A7B0037333 1981 X X
    308 GTSi 37365 ZFFAA02A9B0037365 1981 Red Black
    308 GTSi 37381 ZFFAA02A7B0037381 1981 X X
    308 GTSi 37383 ZFFAA02A0B0037383 1981 X X
    308 GTSi 37385 ZFFAA02A4B0037385 1981 X X
    308 GTSi 37387 ZFFAA02A8B0037387 1981 X X
    308 GTSi 37403 ZFFAA02A2B0037403 1981 Red Tan
    308 GTSi 37405 ZFFAA02A6B0037405 1981 X X
    308 GTSi 37407 ZFFAA02AXB0037407 1981 X X
    308 GTSi 37421 ZFFAA02A4B0037421 1981 Yellow Tan
    308 GTSi 37423 ZFFAA02A8B0037423 1981 X X
    Mondial 8 37431 ZFFAD08A9B0037431 1981 X X
    Mondial 8 37433 ZFFAD08A2B0037433 1981 X X
    Mondial 8 37435 ZFFAD08A6B0037435 1981 Red Black
    Mondial 8 37437 ZFFAD08AXB0037437 1981 White Tan
    Mondial 8 37439 ZFFAD08A3B0037439 1981 X X
    Mondial 8 37441 ZFFAD08A1B0037441 1981 X X
    Mondial 8 37443 ZFFAD08A5B0037443 1981 Grigio Tan
    Mondial 8 37445 ZFFAD08A9B0037445 1981 X X
    Mondial 8 37447 ZFFAD08A2B0037447 1981 Black Black
    Mondial 8 37451 ZFFAD08A4B0037451 1981 X X
    Mondial 8 37453 ZFFAD08A8B0037453 1981 Red Tan
    308 GTSi 37463 ZFFAA02A9B0037463 1981 Black Red
    308 GTSi 37469 ZFFAA02AXB0037469 1981 Red Black
    308 GTSi 37487 ZFFAA02A1B0037487 1981 X X
    308 GTSi 37489 ZFFAA02A5B0037489 1981 X X
    308 GTBi 37495 ZFFAA01A9B0037495 1981 X X
    308 GTSi 37511 ZFFAA02A5B0037511 1981 White Black
    308 GTSi 37513 ZFFAA02A9B0037513 1981 X X
    308 GTSi 37515 ZFFAA02A2B0037515 1981 X X
    308 GTSi 37517 ZFFAA02A6B0037517 1981 X X
    308 GTSi 37543 ZFFAA02A7B0037543 1981 X X
    308 GTSi 37545 ZFFAA02A0B0037545 1981 X X
    308 GTBi 37547 ZFFAA01A2B0037547 1981 X X
    308 GTSi 37557 ZFFAA02A5C0037557 1982 X X
    308 GTSi 37559 ZFFAA02A0B0037559 1981 X X
    308 GTB racing 37565 ZFFAA01A4B0037565 1981 X X
    308 GTSi 37575 ZFFAA02A9B0037575 1981 Red Tan
  18. Rifledriver
    37,101
    82 FNA cars
    308 GTSi 37579 ZFFAA02A4C0037579 1982 X X
    308 GTSi 37599 ZFFAA02AXC0037599 1982 X X
    308 GTSi 37601 ZFFAA02A4C0037601 1982 Yellow Black
    308 GTBi 37603 ZFFAA01A8B0037603 1981 Yellow Tan
    308 GTSi 37621 ZFFAA02A1B0037621 1981 X X
    308 GTSi 37623 ZFFAA02A3C0037623 1982 X X
    308 GTSi 37625 ZFFAA02A7C0037625 1982 X X
    308 GTSi 37641 ZFFAA02A5C0037641 1982 X X
    308 GTSi 37643 ZFFAA02A9C0037643 1982 X X
    308 GTSi 37707 ZFFAA02A9C0037707 1982 X X
    308 GTSi 37709 ZFFAA02A2C0037709 1982 X X
    308 GTSi 37757 ZFFAA02A2C0037757 1982 X X
    308 GTSi 37761 ZFFAA02A4C0037761 1982 Yellow Black
    308 GTSi 37763 ZFFAA02A8C0037763 1982 X X
    308 GTBi 37765 ZFFAA01AXC0037765 1982 X X
    308 GTSi 37781 ZFFAA02AXC0037781 1982 Black Tan
    308 GTBi 37787 ZFFAA01A9C0037787 1982 X X
    308 GTBi 37789 ZFFAA01A2C0037789 1982 X X
    308 GTSi 37807 ZFFAA02A2C0037807 1982 X X
    308 GTSi 37809 ZFFAA02A6C0037809 1982 X X
    308 GTSi 37811 ZFFAA02A4C0037811 1982 X X
    308 GTSi 37831 ZFFAA02AXC0037831 1982 X X
    308 GTSi 37833 ZFFAA02A3C0037833 1982 X X
    308 GTSi 37835 ZFFAA02A7C0037835 1982 X X
    308 GTSi 37837 ZFFAA02A0C0037837 1982 X X
    308 GTSi 37839 ZFFAA02A4C0037839 1982 X X
    308 GTSi 37853 ZFFAA02A9C0037853 1982 Red Black
    308 GTSi 37855 ZFFAA02A2C0037855 1982 X X
    308 GTSi 37879 ZFFAA02A5C0037879 1982 X X
    308 GTSi 37881 ZFFAA02A3C0037881 1982 X X
    308 GTSi 37897 ZFFAA02A7C0037897 1982 X X
    308 GTSi 37899 ZFFAA02A0C0037899 1982 Black Red
    308 GTSi 37901 ZFFAA02A5C0037901 1982 X X
    308 GTSi 37919 ZFFAA02A2C0037919 1982 Red Black
    308 GTSi 37921 ZFFAA02A0C0037921 1982 Red Tan
    308 GTSi 37929 ZFFAA02A5C0037929 1982 X X
    308 GTSi 37931 ZFFAA02A3C0037931 1982 Red X
    308 GTSi 37933 ZFFAA02A7C0037933 1982 X X
    308 GTSi 37935 ZFFAA02A0C0037935 1982 X X
    308 GTSi 37937 ZFFAA02A4C0037937 1982 X X
    308 GTSi 37951 ZFFAA02A9C0037951 1982 X X
    308 GTSi 37953 ZFFAA02A2C0037953 1982 X X
    308 GTSi 37955 ZFFAA02A6C0037955 1982 X X
    308 GTSi 37957 ZFFAA02AXC0037957 1982 X X
    308 GTSi 37961 ZFFAA02A1C0037961 1982 X X
    308 GTSi 37965 ZFFAA02A9C0037965 1982 X X
    308 GTSi 37975 ZFFAA02A1C0037975 1982 X X
    308 GTSi 37977 ZFFAA02A5C0037977 1982 X X
    308 GTSi 37981 ZFFAA02A7C0037981 1982 X X
    308 GTSi 37983 ZFFAA02A0C0037983 1982 X X
    308 GTSi 37985 ZFFAA02A4C0037985 1982 Black Black
    308 GTSi 37987 ZFFAA02A8C0037987 1982 X X
    308 GTBi 37989 ZFFAA01AXC0037989 1982 X X
    Mondial 8 38049 ZFFAD08A4C0038049 1982 X X
    Mondial 8 38067 ZFFAD08A6C0038067 1982 X X
    308 GTSi 38069 ZFFAA02A8C0038069 1982 Red Black
    308 GTSi 38081 ZFFAA02A9C0038081 1982 X X
    308 GTSi 38083 ZFFAA02A2C0038083 1982 X X
    Mondial 8 38099 ZFFAD08A8C0038099 1982 X X
    308 GTSi 38101 ZFFAA02A0C0038101 1982 X X
    308 GTSi 38103 ZFFAA02A4C0038103 1982 X X
    Mondial 8 38125 ZFFAD08A5C0038125 1982 X X
    308 GTSi 38127 ZFFAA02A7C0038127 1982 X X
    308 GTBi 38133 ZFFAA01A0C0038133 1982 X X
    Mondial 8 38139 ZFFAD08A5C0038139 1982 Red Tan
    308 GTSi 38149 ZFFAA02A6C0038149 1982 X X
    Mondial 8 38159 ZFFAD08A0C0038159 1982 X X
    Mondial 8 38161 ZFFAD08A9C0038161 1982 Red Tan
    Mondial 8 38163 ZFFAD08A2C0038163 1982 X X
    308 GTSi 38169 ZFFAA02A1C0038169 1982 X X
    308 GTSi 38171 ZFFAA02AXC0038171 1982 Red Tan
    Mondial 8 38185 ZFFAD08A1C0038185 1982 X X
    308 GTSi 38195 ZFFAA02A2C0038195 1982 X X
    308 GTSi 38197 ZFFAA02A6C0038197 1982 Red Black
    Mondial 8 38223 ZFFAD08A5C0038223 1982 X X
    308 GTSi 38227 ZFFAA02A0C0038227 1982 Red Brown
    308 GTSi 38229 ZFFAA02A4C0038229 1982 X X
    Mondial 8 38237 ZFFAD08A5C0038237 1982 X X
    Mondial 8 38239 ZFFAD08A9C0038239 1982 X X
    308 GTSi 38243 ZFFAA02A9C0038243 1982 X X
    308 GTSi 38245 ZFFAA02A2C0038245 1982 X X
    308 GTSi 38247 ZFFAA02A6C0038247 1982 X X
    308 GTSi 38255 ZFFAA02A5C0038255 1982 X X
    308 GTSi 38279 ZFFAA02A8C0038279 1982 X X
    308 GTSi 38281 ZFFAA02A6C0038281 1982 X X
    308 GTSi 38285 ZFFAA02A3C0038285 1982 Red Tan
    Mondial 8 38325 ZFFAD08A2C0038325 1982 Red Tan
    308 GTSi 38327 ZFFAA02A4C0038327 1982 X X
    Mondial 8 38343 ZFFAD08A4C0038343 1982 Red Tan
    308 GTSi 38363 ZFFAA02A8C0038363 1982 X X
    Mondial 8 38391 ZFFAD08A4C0038391 1982 X X
    Mondial 8 38393 ZFFAD08A8C0038393 1982 X X
    308 GTSi 38401 ZFFAA02A1C0038401 1982 Silver Black
    308 GTSi 38403 ZFFAA02A5C0038403 1982 X X
    Mondial 8 38435 ZFFAD08A9C0038435 1982 Yellow Tan
    308 GTSi 38437 ZFFAA02A0C0038437 1982 X X
    308 GTSi 38439 ZFFAA02A4C0038439 1982 X X
    308 GTSi 38441 ZFFAA02A2C0038441 1982 X X
    308 GTSi 38457 ZFFAA02A6C0038457 1982 X X
    308 GTSi 38459 ZFFAA02AXC0038459 1982 X X
    308 GTBi 38467 ZFFAA01A7C0038467 1982 X X
    308 GTSi 38475 ZFFAA02A8C0038475 1982 Red Black
    308 GTSi 38477 ZFFAA02A1C0038477 1982 X X
    308 GTSi 38479 ZFFAA02A5C0038479 1982 Red Tan
    308 GTSi 38481 ZFFAA02A3C0038481 1982 X X
    308 GTSi 38503 ZFFAA02A9C0038503 1982 Black Red
    308 GTSi 38507 ZFFAA02A6C0038507 1982 X X
    308 GTSi 38523 ZFFAA02A4C0038523 1982 X X
    308 GTSi 38525 ZFFAA02A8C0038525 1982 X X
    308 GTSi 38527 ZFFAA02A1C0038527 1982 X X
    308 GTSi 38547 ZFFAA02A7C0038547 1982 Red Black
    308 GTSi 38549 ZFFAA02A0C0038549 1982 Red Tan
    308 GTSi 38567 ZFFAA02A2C0038567 1982 Red Tan
    308 GTBi 38577 ZFFAA01A3C0038577 1982 X X
    Mondial 8 38583 ZFFAD08A2C0038583 1982 X X
    308 GTSi 38587 ZFFAA02A8C0038587 1982 White Black
    308 GTSi 38589 ZFFAA02A1C0038589 1982 Red Black
    308 GTBi 38595 ZFFAA01A5C0038595 1982 X X
    Mondial 8 38599 ZFFAD08A6C0038599 1982 Black Red
    308 GTSi 38605 ZFFAA02A6C0038605 1982 X X
    308 GTSi 38607 ZFFAA02AXC0038607 1982 X X
    Mondial 8 38635 ZFFAD08A6C0038635 1982 X X
    308 GTSi 38637 ZFFAA02A8C0038637 1982 X X
    308 GTSi 38639 ZFFAA02A1C0038639 1982 Red Tan
    308 GTSi 38641 ZFFAA02AXC0038641 1982 X X
    308 GTSi 38643 ZFFAA02A3C0038643 1982 Red Tan
    Mondial 8 38653 ZFFAD08A8C0038653 1982 X X
    308 GTSi 38659 ZFFAA02A7C0038659 1982 X X
    308 GTSi 38661 ZFFAA02A5C0038661 1982 X X
    Mondial 8 38677 ZFFAD08A0C0038677 1982 X X
    Mondial 8 38679 ZFFAD08A4C0038679 1982 Black Black
    308 GTSi 38683 ZFFAA02A4C0038683 1982 X X
    308 GTSi 38685 ZFFAA02A8C0038685 1982 Red X
    Mondial 8 38695 ZFFAD08A2C0038695 1982 Red Black
    Mondial 8 38697 ZFFAD08A6C0038697 1982 X X
    308 GTSi 38699 ZFFAA02A8C0038699 1982 X X
    308 GTSi 38703 ZFFAA02A6C0038703 1982 Red Black
    308 GTSi 38705 ZFFAA02AXC0038705 1982 Red Black
    Mondial 8 38723 ZFFAD08A3C0038723 1982 Black Red
    308 GTSi 38727 ZFFAA02A9C0038727 1982 X X
    308 GTSi 38729 ZFFAA02A2C0038729 1982 X X
    Mondial 8 38745 ZFFAD08A2C0038745 1982 X X
    308 GTSi 38749 ZFFAA02A8C0038749 1982 X X
    308 GTSi 38751 ZFFAA02A6C0038751 1982 X X
    Mondial 8 38763 ZFFAD08A4C0038763 1982 X X
    Mondial 8 38765 ZFFAD08A8C0038765 1982 Red Tan
    308 GTSi 38767 ZFFAA02AXC0038767 1982 X X
    308 GTSi 38769 ZFFAA02A3C0038769 1982 X X
    308 GTSi 38773 ZFFAA02A5C0038773 1982 Red Tan
    308 GTSi 38775 ZFFAA02A9C0038775 1982 X X
    Mondial 8 38785 ZFFAD08A3C0038785 1982 White Red
    Mondial 8 38787 ZFFAD08A7C0038787 1982 X X
    308 GTSi 38793 ZFFAA02A0C0038793 1982 Red Tan
    308 GTSi 38795 ZFFAA02A4C0038795 1982 X X
    308 GTSi 38809 ZFFAA02A0C0038809 1982 Red Black
    308 GTSi 38811 ZFFAA02A9C0038811 1982 X X
    308 GTSi 38813 ZFFAA02A2C0038813 1982 X X
    Mondial 8 38827 ZFFAD08A4C0038827 1982 X X
    Mondial 8 38829 ZFFAD08A8C0038829 1982 Red Black
    308 GTSi 38841 ZFFAA02A7C0038841 1982 Black Black
    308 GTSi 38843 ZFFAA02A0C0038843 1982 X X
    Mondial 8 38855 ZFFAD08A9C0038855 1982 Red Beige
    Mondial 8 38857 ZFFAD08A2C0038857 1982 Red Tan
    308 GTSi 38861 ZFFAA02A2C0038861 1982 X X
    308 GTSi 38863 ZFFAA02A6C0038863 1982 Red Black
    308 GTSi 38865 ZFFAA02AXC0038865 1982 X X
    308 GTSi 38867 ZFFAA02A3C0038867 1982 X X
    Mondial 8 38879 ZFFAD08A1C0038879 1982 Red Tan
    Mondial 8 38881 ZFFAD08AXC0038881 1982 X X
    308 GTSi 38885 ZFFAA02A5C0038885 1982 X X
    308 GTSi 38887 ZFFAA02A9C0038887 1982 White Magnolia
    308 GTSi 38889 ZFFAA02A2C0038889 1982 Red Dark Grey
    Mondial 8 38899 ZFFAD08A7C0038899 1982 X X
    308 GTSi 38909 ZFFAA02A4C0038909 1982 X X
    Mondial 8 38921 ZFFAD08A7C0038921 1982 X X
    Mondial 8 38923 ZFFAD08A0C0038923 1982 X X
    Mondial 8 38941 ZFFAD08A2C0038941 1982 X X
    Mondial 8 38943 ZFFAD08A6C0038943 1982 X X
    308 GTSi 38951 ZFFAA02A3C0038951 1982 Black Black
    308 GTBi 38953 ZFFAA01A5C0038953 1982 X X
    Mondial 8 38967 ZFFAD08A9C0038967 1982 Black Red
    Mondial 8 38969 ZFFAD08A2C0038969 1982 X X
    308 GTSi 38971 ZFFAA02A9C0038971 1982 Black Red
    308 GTSi 38973 ZFFAA02A2C0038973 1982 X X
    308 GTSi 38975 ZFFAA02A6C0038975 1982 X X
    308 GTSi 38977 ZFFAA02AXC0038977 1982 X X
    308 GTSi 38979 ZFFAA02A3C0038979 1982 Red Black
    308 GTBi 38981 ZFFAA01AXC0038981 1982 X X
    Mondial 8 38993 ZFFAD08AXC0038993 1982 Blue Black
    308 GTSi 38999 ZFFAA02A9C0038999 1982 Red Tan
    308 GTSi 39001 ZFFAA02A1C0039001 1982 X X
    308 GTBi 39003 ZFFAA01A3C0039003 1982 X X
    Mondial 8 39005 ZFFAD08A0C0039005 1982 Red Black
    Mondial 8 39007 ZFFAD08A4C0039007 1982 Black Red
    308 GTSi 39011 ZFFAA02A4C0039011 1982 Red Black
    308 GTSi 39013 ZFFAA02A8C0039013 1982 X X
    308 GTSi 39015 ZFFAA02A1C0039015 1982 X X
    Mondial 8 39029 ZFFAD08A3C0039029 1982 Red Black
    308 GTSi 39033 ZFFAA02A3C0039033 1982 X X
    308 GTSi 39035 ZFFAA02A7C0039035 1982 X X
    308 GTSi 39037 ZFFAA02A0C0039037 1982 X X
    308 GTSi 39039 ZFFAA02A4C0039039 1982 X X
    Mondial 8 39045 ZFFAD08A1C0039045 1982 X X
    Mondial 8 39047 ZFFAD08A5C0039047 1982 Black Tan
    Mondial 8 39049 ZFFAD08A9C0039049 1982 X X
    308 GTSi 39051 ZFFAA02A5C0039051 1982 X X
    308 GTSi 39053 ZFFAA02A9C0039053 1982 Red Parchment
    308 GTSi 39055 ZFFAA02A2C0039055 1982 X X
    308 GTSi 39057 ZFFAA02A6C0039057 1982 X X
    308 GTSi 39059 ZFFAA02AXC0039059 1982 X X
    308 GTBi 39061 ZFFAA01A6C0039061 1982 X X
    308 GTSi 39079 ZFFAA02A5C0039079 1982 X X
    308 GTSi 39083 ZFFAA02A7C0039083 1982 Red Tan
    308 GTSi 39085 ZFFAA02A0C0039085 1982 X X
    308 GTSi 39087 ZFFAA02A4C0039087 1982 X X
    308 GTBi 39091 ZFFAA01A4C0039091 1982 X X
    Mondial 8 39097 ZFFAD08A9C0039097 1982 Red Black
    Mondial 8 39101 ZFFAD08A7C0039101 1982 X X
    Mondial 8 39103 ZFFAD08A0C0039103 1982 X X
    308 GTSi 39105 ZFFAA02A2C0039105 1982 X X
    308 GTSi 39107 ZFFAA02A6C0039107 1982 X X
    Mondial 8 39119 ZFFAD08A4C0039119 1982 X X
    308 GTSi 39129 ZFFAA02A5C0039129 1982 X X
    308 GTSi 39131 ZFFAA02A3C0039131 1982 X X
    308 GTSi 39133 ZFFAA02A7C0039133 1982 X X
    Mondial 8 39139 ZFFAD08AXC0039139 1982 Red Tan
    308 GTSi 39141 ZFFAA02A6C0039141 1982 X X
    308 GTSi 39143 ZFFAA02AXC0039143 1982 X X
    308 GTSi 39145 ZFFAA02A3C0039145 1982 X X
    308 GTSi 39147 ZFFAA02A7C0039147 1982 X X
    308 GTSi 39149 ZFFAA02A0C0039149 1982 X X
    Mondial 8 39165 ZFFAD08A0C0039165 1982 X X
    308 GTSi 39167 ZFFAA02A2C0039167 1982 X X
    308 GTSi 39169 ZFFAA02A6C0039169 1982 Black Tan
    308 GTSi 39171 ZFFAA02A4C0039171 1982 X X
    Mondial 8 39189 ZFFAD08A3C0039189 1982 X X
    Mondial 8 39191 ZFFAD08A1C0039191 1982 Black Black
    308 GTSi 39195 ZFFAA02A7C0039195 1982 X X
    308 GTSi 39197 ZFFAA02A0C0039197 1982 X X
    308 GTBi 39199 ZFFAA01A2C0039199 1982 X X
    308 GTSi 39215 ZFFAA02A9C0039215 1982 X X
    308 GTSi 39217 ZFFAA02A2C0039217 1982 X X
    308 GTSi 39219 ZFFAA02A6C0039219 1982 X X
    308 GTSi 39221 ZFFAA02A4C0039221 1982 X X
    308 GTBi 39223 ZFFAA01A6C0039223 1982 X X
    Mondial 8 39233 ZFFAD08A2C0039233 1982 X X
    Mondial 8 39235 ZFFAD08A6C0039235 1982 Red Tan
    308 GTSi 39239 ZFFAA02A1C0039239 1982 X X
    308 GTSi 39241 ZFFAA02AXC0039241 1982 X X
    308 GTSi 39243 ZFFAA02A3C0039243 1982 X X
    308 GTSi 39245 ZFFAA02A7C0039245 1982 X X
    Mondial 8 39253 ZFFAD08A8C0039253 1982 X X
    Mondial 8 39255 ZFFAD08A1C0039255 1982 X X
    Mondial 8 39257 ZFFAD08A5C0039257 1982 X X
    308 GTSi 39261 ZFFAA02A5C0039261 1982 X X
    308 GTSi 39265 ZFFAA02A2C0039265 1982 X X
    Mondial 8 39269 ZFFAD08A1C0039269 1982 X X
    Mondial 8 39271 ZFFAD08AXC0039271 1982 Red Tan
    308 GTSi 39275 ZFFAA02A5C0039275 1982 X X
    308 GTSi 39277 ZFFAA02A9C0039277 1982 X X
    308 GTBi 39279 ZFFAA01A0C0039279 1982 X X
    Mondial 8 39285 ZFFAD08AXC0039285 1982 Red Tan
    308 GTSi 39291 ZFFAA02A3C0039291 1982 Red Tan
    308 GTSi 39295 ZFFAA02A0C0039295 1982 X X
    308 GTSi 39297 ZFFAA02A4C0039297 1982 X X
    Mondial 8 39323 ZFFAD08A3C0039323 1982 Red Black
    Mondial 8 39325 ZFFAD08A7C0039325 1982 X X
    308 GTSi 39329 ZFFAA02A2C0039329 1982 X X
    308 GTSi 39331 ZFFAA02A0C0039331 1982 X X
    308 GTSi 39333 ZFFAA02A4C0039333 1982 X X
    Mondial 8 39341 ZFFAD08A5C0039341 1982 Black Red
    Mondial 8 39343 ZFFAD08A9C0039343 1982 Red Tan
    Mondial 8 39357 ZFFAD08A9C0039357 1982 X X
    308 GTSi 39365 ZFFAA02A6C0039365 1982 X X
    308 GTSi 39367 ZFFAA02AXC0039367 1982 X X
    308 GTSi 39369 ZFFAA02A3C0039369 1982 X X
    Mondial 8 39381 ZFFAD08A6C0039381 1982 X X
    Mondial 8 39383 ZFFAD08AXC0039383 1982 X X
    308 GTSi 39387 ZFFAA02A5C0039387 1982 X X
    308 GTSi 39389 ZFFAA02A9C0039389 1982 X X
    308 GTBi 39391 ZFFAA01A5C0039391 1982 X X
    308 GTBi 39393 ZFFAA01A9C0039393 1982 X X
    Mondial 8 39397 ZFFAD08AXC0039397 1982 X X
    Mondial 8 39399 ZFFAD08A3C0039399 1982 White Black
    308 GTSi 39405 ZFFAA02A3C0039405 1982 Red Black
    308 GTSi 39407 ZFFAA02A7C0039407 1982 X X
    308 GTSi 39409 ZFFAA02A0C0039409 1982 X X
    Mondial 8 39431 ZFFAD08A6C0039431 1982 Red Black
    Mondial 8 39433 ZFFAD08AXC0039433 1982 X X
    308 GTSi 39439 ZFFAA02A9C0039439 1982 Red Black
    308 GTSi 39441 ZFFAA02A7C0039441 1982 Yellow Black
    308 GTSi 39443 ZFFAA02A0C0039443 1982 X X
    308 GTSi 39445 ZFFAA02A4C0039445 1982 X X
    Mondial 8 39449 ZFFAD08A3C0039449 1982 Black Tan
    Mondial 8 39451 ZFFAD08A1C0039451 1982 X X
    308 GTSi 39455 ZFFAA02A7C0039455 1982 Black Tan
    308 GTSi 39457 ZFFAA02A0C0039457 1982 X X
    308 GTSi 39459 ZFFAA02A4C0039459 1982 X X
    308 GTSi 39461 ZFFAA02A2C0039461 1982 Red Tan
    308 GTSi 39463 ZFFAA02A6C0039463 1982 X X
    308 GTSi 39479 ZFFAA02AXC0039479 1982 X X
    308 GTBi 39485 ZFFAA01A3C0039485 1982 X X
    308 GTSi 39499 ZFFAA02A5C0039499 1982 X X
    308 GTSi 39501 ZFFAA02AXC0039501 1982 Red Beige
    308 GTSi 39503 ZFFAA02A3C0039503 1982 X X
    308 GTSi 39509 ZFFAA02A4C0039509 1982 X X
    308 GTSi 39511 ZFFAA02A2C0039511 1982 X X
    308 GTSi 39513 ZFFAA02A6C0039513 1982 Red Tan
    308 GTSi 39515 ZFFAA02AXC0039515 1982 X X
    308 GTSi 39551 ZFFAA02A3C0039551 1982 X X
    308 GTSi 39553 ZFFAA02A7C0039553 1982 X X
    308 GTSi 39555 ZFFAA02A0C0039555 1982 X X
    Mondial 8 39559 ZFFAD08AXC0039559 1982 X X
    Mondial 8 39561 ZFFAD08A8C0039561 1982 Red Tan
    308 GTSi 39571 ZFFAA02A9C0039571 1982 X X
    Mondial 8 39591 ZFFAD08A6C0039591 1982 X X
    308 GTSi 39599 ZFFAA02A9C0039599 1982 X X
    308 GTSi 39601 ZFFAA02A3C0039601 1982 Red Cream
    308 GTSi 39603 ZFFAA02A7C0039603 1982 X X
    Mondial 8 39615 ZFFAD08A5C0039615 1982 X X
    308 GTSi 39617 ZFFAA02A7C0039617 1982 X X
    308 GTSi 39619 ZFFAA02A0C0039619 1982 Black Tan
    308 GTSi 39621 ZFFAA02A9C0039621 1982 X X
    308 GTSi 39623 ZFFAA02A2C0039623 1982 Red Black
    308 GTSi 39625 ZFFAA02A6C0039625 1982 X X
    Mondial 8 39647 ZFFAD08A7C0039647 1982 X X
    308 GTSi 39653 ZFFAA02A0C0039653 1982 Black Black
    308 GTSi 39655 ZFFAA02A4C0039655 1982 X X
    308 GTSi 39661 ZFFAA02AXC0039661 1982 X X
    308 GTSi 39693 ZFFAA02A1C0039693 1982 X X
    308 GTBi 39715 ZFFAA01A5C0039715 1982 X X
    308 GTSi 39737 ZFFAA02A6C0039737 1982 X X
    308 GTSi 39739 ZFFAA02AXC0039739 1982 X X
    Mondial 8 39749 ZFFAD08A4C0039749 1982 X X
    308 GTSi 39757 ZFFAA02A1C0039757 1982 X X
    308 GTSi 39759 ZFFAA02A5C0039759 1982 X X
    308 GTSi 39761 ZFFAA02A3C0039761 1982 X X
    308 GTSi 39763 ZFFAA02A7C0039763 1982 X X
    308 GTSi 39787 ZFFAA02AXC0039787 1982 Red Tan
    308 GTSi 39789 ZFFAA02A3C0039789 1982 X X
    Mondial 8 39799 ZFFAD08A8C0039799 1982 Red Tan
    308 GTSi 39801 ZFFAA02A0C0039801 1982 X X
    308 GTSi 39803 ZFFAA02A4C0039803 1982 X X
    308 GTBi 39807 ZFFAA01AXC0039807 1982 X X
    308 GTSi 39821 ZFFAA02A6C0039821 1982 X X
    308 GTSi 39823 ZFFAA02AXC0039823 1982 X X
    308 GTSi 39825 ZFFAA02A3C0039825 1982 Grey Black
    308 GTBi 39833 ZFFAA01A0C0039833 1982 X X
    308 GTBi 39835 ZFFAA01A4C0039835 1982 X X
    308 GTSi 39849 ZFFAA02A6C0039849 1982 X X
    308 GTSi 39853 ZFFAA02A8C0039853 1982 X X
    308 GTSi 39855 ZFFAA02A1C0039855 1982 X X
    308 GTBi 39857 ZFFAA01A3C0039857 1982 X X
    Mondial 8 39869 ZFFAD08A3C0039869 1982 X X
    308 GTSi 39875 ZFFAA02A7C0039875 1982 X X
    308 GTSi 39879 ZFFAA02A4C0039879 1982 X X
    Mondial 8 39891 ZFFAD08A7C0039891 1982 Red Black
    308 GTSi 39895 ZFFAA02A2C0039895 1982 X X
    308 GTSi 39897 ZFFAA02A6C0039897 1982 X X
    308 GTSi 39899 ZFFAA02AXC0039899 1982 X X
    308 GTSi 39903 ZFFAA02A8C0039903 1982 X X
    308 GTBi 39905 ZFFAA01AXC0039905 1982 X X
    308 GTSi 39913 ZFFAA02A0C0039913 1982 Black Tan
    308 GTBi 39919 ZFFAA01AXC0039919 1982 X X
    308 GTSi 39949 ZFFAA02AXC0039949 1982 X X
    308 GTBi 39951 ZFFAA01A6C0039951 1982 Red Black
    308 GTBi 39953 ZFFAA01AXC0039953 1982 X X
    Mondial 8 39957 ZFFAD08A0C0039957 1982 X X
    308 GTSi 39967 ZFFAA02A1C0039967 1982 X X
    308 GTSi 39969 ZFFAA02A5C0039969 1982 X X
    Mondial 8 39977 ZFFAD08A6C0039977 1982 X X
    308 GTSi 39983 ZFFAA02AXC0039983 1982 X X
    308 GTSi 39985 ZFFAA02A3C0039985 1982 Red Black
    Mondial 8 39999 ZFFAD08A5C0039999 1982 Red Black
    308 GTSi 40005 ZFFAA02A3C0040005 1982 X X
    308 GTSi 40009 ZFFAA02A0C0040009 1982 X X
    Mondial 8 40015 ZFFAD08A8C0040015 1982 Red Black
    308 GTSi 40021 ZFFAA02A1C0040021 1982 X X
    308 GTSi 40023 ZFFAA02A5C0040023 1982 Red Black
    308 GTSi 40025 ZFFAA02A9C0040025 1982 X X
    308 GTSi 40027 ZFFAA02A2C0040027 1982 X X
    Mondial 8 40047 ZFFAD08AXC0040047 1982 Red Tan
    308 GTSi 40053 ZFFAA02A3C0040053 1982 X X
    308 GTBi 40059 ZFFAA01A2C0040059 1982 Red Black
    308 GTBi 40061 ZFFAA01A0C0040061 1982 X X
    Mondial 8 40069 ZFFAD08A9C0040069 1982 Red Red
    308 GTSi 40073 ZFFAA02A9C0040073 1982 X X
    308 GTSi 40077 ZFFAA02A6C0040077 1982 Red Tan
    308 GTSi 40079 ZFFAA02AXC0040079 1982 X X
    308 GTSi 40091 ZFFAA02A0C0040091 1982 X X
    308 GTSi 40093 ZFFAA02A4C0040093 1982 X X
    308 GTSi 40095 ZFFAA02A8C0040095 1982 X X
    Mondial 8 40109 ZFFAD08A6C0040109 1982 X X
    308 GTSi 40111 ZFFAA02A2C0040111 1982 X X
    308 GTSi 40113 ZFFAA02A6C0040113 1982 X X
    308 GTSi 40115 ZFFAA02AXC0040115 1982 X X
    308 GTSi 40117 ZFFAA02A3C0040117 1982 X X
    308 GTSi 40127 ZFFAA02A6C0040127 1982 X X
    308 GTSi 40129 ZFFAA02AXC0040129 1982 X X
    308 GTSi 40131 ZFFAA02A8C0040131 1982 X X
    308 GTSi 40133 ZFFAA02A1C0040133 1982 Black Tan
    308 GTSi 40139 ZFFAA02A2C0040139 1982 Red Tan
    308 GTSi 40173 ZFFAA02A2C0040173 1982 Chiaro Azzura Tan
    308 GTSi 40175 ZFFAA02A6C0040175 1982 X X
    308 GTSi 40177 ZFFAA02AXC0040177 1982 X X
    308 GTSi 40179 ZFFAA02A3C0040179 1982 X X
    Mondial 8 40185 ZFFAD08A0C0040185 1982 Grigio Black
    308 GTSi 40189 ZFFAA02A6C0040189 1982 X X
    308 GTSi 40191 ZFFAA02A4C0040191 1982 X X
    308 GTSi 40193 ZFFAA02A8C0040193 1982 X X
    308 GTBi 40195 ZFFAA01AXC0040195 1982 X X
    308 GTSi 40209 ZFFAA02A8C0040209 1982 Yellow Tan
    308 GTSi 40211 ZFFAA02A6C0040211 1982 Red Black
    308 GTBi 40213 ZFFAA01A8C0040213 1982 X X
    308 GTBi 40215 ZFFAA01A1C0040215 1982 X X
    308 GTSi 40223 ZFFAA02A2C0040223 1982 X X
    308 GTSi 40225 ZFFAA02A6C0040225 1982 Red Tan
    308 GTSi 40231 ZFFAA02A1C0040231 1982 X X
    308 GTSi 40233 ZFFAA02A5C0040233 1982 Red Black
    Mondial 8 40247 ZFFAD08A7C0040247 1982 X X
    308 GTSi 40251 ZFFAA02A7C0040251 1982 Red Black
    308 GTSi 40257 ZFFAA02A8C0040257 1982 X X
    308 GTSi 40259 ZFFAA02A1C0040259 1982 X X
    308 GTSi 40277 ZFFAA02A3C0040277 1982 X X
    308 GTSi 40283 ZFFAA02A9C0040283 1982 Red Black
    308 GTSi 40285 ZFFAA02A2C0040285 1982 X X
    308 GTSi 40287 ZFFAA02A6C0040287 1982 X X
    308 GTBi 40289 ZFFAA01A8C0040289 1982 X X
    308 GTSi 40299 ZFFAA02A2C0040299 1982 Red Tan
    308 GTSi 40301 ZFFAA02A7C0040301 1982 X X
    308 GTSi 40303 ZFFAA02A0C0040303 1982 X X
    308 GTSi 40305 ZFFAA02A4C0040305 1982 X X
    308 GTBi 40309 ZFFAA01AXC0040309 1982 X X
    Mondial 8 40311 ZFFAD08A1C0040311 1982 X X
    308 GTSi 40317 ZFFAA02A0C0040317 1982 X X
    308 GTSi 40319 ZFFAA02A4C0040319 1982 X X
    308 GTSi 40321 ZFFAA02A2C0040321 1982 X X
    308 GTSi 40323 ZFFAA02A6C0040323 1982 X X
    Mondial 8 40339 ZFFAD08A1C0040339 1982 X X
    308 GTSi 40345 ZFFAA02A5C0040345 1982 X X
    308 GTSi 40349 ZFFAA02A2C0040349 1982 X X
    308 GTSi 40351 ZFFAA02A0C0040351 1982 Red Black
    308 GTBi 40353 ZFFAA01A2C0040353 1982 X X
    Mondial 8 40367 ZFFAD08A6C0040367 1982 Red Red
    308 GTSi 40371 ZFFAA02A6C0040371 1982 Metallic Blue Cream
    308 GTSi 40373 ZFFAA02AXC0040373 1982 X X
    308 GTSi 40375 ZFFAA02A3C0040375 1982 X X
    308 GTSi 40377 ZFFAA02A7C0040377 1982 X X
    308 GTSi 40379 ZFFAA02A0C0040379 1982 X X
    308 GTSi 40385 ZFFAA02A6C0040385 1982 X X
    308 GTSi 40389 ZFFAA02A3C0040389 1982 Red Tan
    308 GTSi 40391 ZFFAA02A1C0040391 1982 Black Black
    308 GTSi 40393 ZFFAA02A5C0040393 1982 X X
    308 GTSi 40397 ZFFAA02A2C0040397 1982 X X
    308 GTSi 40405 ZFFAA02A8C0040405 1982 X X
    308 GTSi 40407 ZFFAA02A1C0040407 1982 X X
    308 GTSi 40409 ZFFAA02A5C0040409 1982 X X
    308 GTSi 40411 ZFFAA02A3C0040411 1982 X X
    308 GTSi 40413 ZFFAA02A7C0040413 1982 X X
    308 GTSi 40433 ZFFAA02A2C0040433 1982 X X
    308 GTSi 40435 ZFFAA02A6C0040435 1982 X X
    308 GTSi 40437 ZFFAA02AXC0040437 1982 X X
    308 GTSi 40439 ZFFAA02A3C0040439 1982 White Red
    308 GTSi 40441 ZFFAA02A1C0040441 1982 Red Tan
    308 GTSi 40445 ZFFAA02A9C0040445 1982 X X
    308 GTSi 40447 ZFFAA02A2C0040447 1982 X X
    308 GTSi 40459 ZFFAA02A9C0040459 1982 X X
    308 GTSi 40463 ZFFAA02A0C0040463 1982 X X
    308 GTSi 40475 ZFFAA02A7C0040475 1982 X X
    308 GTSi 40477 ZFFAA02A0C0040477 1982 X X
    308 GTSi 40479 ZFFAA02A4C0040479 1982 Metallic Blue Blue
    308 GTSi 40481 ZFFAA02A2C0040481 1982 X X
    308 GTSi 40483 ZFFAA02A6C0040483 1982 X X
    308 GTSi 40485 ZFFAA02AXC0040485 1982 X X
    308 GTSi 40487 ZFFAA02A3C0040487 1982 X X
    308 GTSi 40489 ZFFAA02A7C0040489 1982 X X
    308 GTSi 40491 ZFFAA02A5C0040491 1982 X X
    308 GTSi 40495 ZFFAA02A2C0040495 1982 Red Tan
    Mondial 8 40511 ZFFAD08A9C0040511 1982 Metallic Blue Grey
    308 GTSi 40515 ZFFAA02A4C0040515 1982 X X
    308 GTSi 40517 ZFFAA02A8C0040517 1982 X X
    308 GTSi 40519 ZFFAA02A1C0040519 1982 Red Tan
    308 GTSi 40521 ZFFAA02AXC0040521 1982 Red Tan
    308 GTSi 40523 ZFFAA02A3C0040523 1982 X X
    308 GTSi 40533 ZFFAA02A6C0040533 1982 X X
    308 GTSi 40535 ZFFAA02AXC0040535 1982 X X
    308 GTSi 40537 ZFFAA02A3C0040537 1982 X X
    308 GTSi 40543 ZFFAA02A9C0040543 1982 Dark Green Tan
    308 GTSi 40577 ZFFAA02A4C0040577 1982 X X
    308 GTSi 40579 ZFFAA02A8C0040579 1982 X X
    308 GTSi 40581 ZFFAA02A6C0040581 1982 X X
    308 GTSi 40583 ZFFAA02AXC0040583 1982 X X
    308 GTSi 40593 ZFFAA02A2C0040593 1982 Red Tan
    308 GTSi 40595 ZFFAA02A6C0040595 1982 Red Tan
    308 GTSi 40599 ZFFAA02A3C0040599 1982 X X
    308 GTBi 40601 ZFFAA01A6C0040601 1982 X X
    308 GTSi 40609 ZFFAA02A2C0040609 1982 X X
    Mondial 8 40627 ZFFAD08A6C0040627 1982 X X
    308 GTSi 40633 ZFFAA02AXC0040633 1982 X X
    308 GTSi 40635 ZFFAA02A3C0040635 1982 Red Tan
    308 GTSi 40639 ZFFAA02A0C0040639 1982 Black Tan
    308 GTSi 40641 ZFFAA02A9C0040641 1982 X X
    308 GTSi 40645 ZFFAA02A6C0040645 1982 Black Tan
    308 GTSi 40647 ZFFAA02AXC0040647 1982 Red Tan
    308 GTSi 40649 ZFFAA02A3C0040649 1982 Grey Metallic Dark Red
    308 GTSi 40651 ZFFAA02A1C0040651 1982 Grey Tan
    308 GTSi 40653 ZFFAA02A5C0040653 1982 X X
    308 GTSi 40655 ZFFAA02A9C0040655 1982 X X
    Mondial 8 40669 ZFFAD08A0C0040669 1982 Red Black
    308 GTSi 40673 ZFFAA02A0C0040673 1982 Black Red
    308 GTSi 40675 ZFFAA02A4C0040675 1982 Red Black
    308 GTSi 40925 ZFFAA02A1C0040925 1982 X X
    308 GTSi 40927 ZFFAA02A5C0040927 1982 X X
    308 GTSi 40931 ZFFAA02A7C0040931 1982 X X
    308 GTBi 40933 ZFFAA01A9C0040933 1982 Black Black
    308 GTBi 40935 ZFFAA01A2C0040935 1982 X X
    308 GTSi 40941 ZFFAA02AXC0040941 1982 X X
    308 GTSi 40943 ZFFAA02A3C0040943 1982 X X
    308 GTSi 40945 ZFFAA02A7C0040945 1982 X X
    308 GTSi 40949 ZFFAA02A4C0040949 1982 Red Black
    308 GTSi 40951 ZFFAA02A2C0040951 1982 X X
    308 GTBi 40955 ZFFAA01A8C0040955 1982 X X
    308 GTSi 40959 ZFFAA02A7C0040959 1982 X X
    308 GTSi 40961 ZFFAA02A5C0040961 1982 X X
    308 GTSi 40963 ZFFAA02A9C0040963 1982 X X
    308 GTSi 40965 ZFFAA02A2C0040965 1982 X X
    308 GTSi 40967 ZFFAA02A6C0040967 1982 X X
    308 GTSi 40969 ZFFAA02AXC0040969 1982 X X
    Mondial 8 40985 ZFFAD08AXC0040985 1982 Dark Grey X
    Mondial 8 40987 ZFFAD08A3C0040987 1982 Red Tan
    308 GTSi 40991 ZFFAA02A3C0040991 1982 X X
    308 GTSi 40993 ZFFAA02A7C0040993 1982 X X
    308 GTSi 40995 ZFFAA02A0C0040995 1982 X X
    308 GTSi 40997 ZFFAA02A4C0040997 1982 Red Tan
    Mondial 8 41009 ZFFAD08A7C0041009 1982 X X
    308 GTSi 41015 ZFFAA02A0C0041015 1982 X X
    308 GTSi 41017 ZFFAA02A4C0041017 1982 X X
    308 GTBi 41019 ZFFAA01A6C0041019 1982 X X
    Mondial 8 41025 ZFFAD08A5C0041025 1982 X X
    308 GTSi 41029 ZFFAA02A0C0041029 1982 X X
  19. Rifledriver
    37,101
    The rest of the 82s and a few 83s
    This will get you started.
    308 GTSi 41031 ZFFAA02A9C0041031 1982 X X
    Mondial 8 41047 ZFFAD08A4C0041047 1982 X X
    308 GTSi 41053 ZFFAA02A8C0041053 1982 X X
    308 GTSi 41055 ZFFAA02A1C0041055 1982 X X
    308 GTSi 41057 ZFFAA02A5C0041057 1982 X X
    Mondial 8 41071 ZFFAD08A1C0041071 1982 X X
    308 GTSi 41079 ZFFAA02A4C0041079 1982 X X
    308 GTSi 41081 ZFFAA02A2C0041081 1982 X X
    308 GTSi 41083 ZFFAA02A6C0041083 1982 X X
    308 GTSi 41085 ZFFAA02AXC0041085 1982 X X
    308 GTSi 41097 ZFFAA02A6C0041097 1982 X X
    308 GTSi 41099 ZFFAA02AXC0041099 1982 Red Black
    308 GTSi 41101 ZFFAA02A4C0041101 1982 X X
    Mondial 8 41109 ZFFAD08A0C0041109 1982 X X
    Mondial 8 41111 ZFFAD08A9C0041111 1982 Red Black
    308 GTSi 41117 ZFFAA02A8C0041117 1982 X X
    308 GTSi 41119 ZFFAA02A1C0041119 1982 X X
    308 GTSi 41135 ZFFAA02AXC0041135 1982 X X
    308 GTSi 41137 ZFFAA02A3C0041137 1982 X X
    308 GTSi 41155 ZFFAA02A5C0041155 1982 X X
    308 GTSi 41181 ZFFAA02A6C0041181 1982 X X
    308 GTSi 41183 ZFFAA02AXC0041183 1982 X X
    Mondial 8 41199 ZFFAD08A5C0041199 1982 Black Red
    308 GTSi 41205 ZFFAA02A5C0041205 1982 Red Tan
    308 GTSi 41207 ZFFAA02A9C0041207 1982 X X
    308 GTSi 41209 ZFFAA02A2C0041209 1982 X X
    Mondial 8 41221 ZFFAD08A5C0041221 1982 X X
    308 GTSi 41233 ZFFAA02AXC0041233 1982 Red Black
    308 GTSi 41235 ZFFAA02A3C0041235 1982 X X
    Mondial 8 41241 ZFFAD08A0C0041241 1982 Red Black
    308 GTSi 41251 ZFFAA02A1C0041251 1982 X X
    308 GTSi 41255 ZFFAA02A9C0041255 1982 X X
    Mondial 8 41269 ZFFAD08A0C0041269 1982 X X
    308 GTSi 41275 ZFFAA02A4C0041275 1982 X X
    308 GTSi 41279 ZFFAA02A1C0041279 1982 X X
    Mondial 8 41285 ZFFAD08A9C0041285 1982 X X
    308 GTSi 41289 ZFFAA02A4C0041289 1982 X X
    Mondial 8 41311 ZFFAD08A6C0041311 1982 X X
    308 GTSi 41313 ZFFAA02A8C0041313 1982 X X
    308 GTSi 41315 ZFFAA02A1C0041315 1982 Black Tan
    308 GTSi 41317 ZFFAA02A5C0041317 1982 X X
    308 GTSi 41319 ZFFAA02A9C0041319 1982 X X
    308 GTBi 41323 ZFFAA01A9C0041323 1982 Black Black
    308 GTSi 41329 ZFFAA02A1C0041329 1982 Black Red
    308 GTSi 41331 ZFFAA02AXC0041331 1982 X X
    308 GTSi 41333 ZFFAA02A3C0041333 1982 X X
    Mondial 8 41361 ZFFAD08AXC0041361 1982 X X
    308 GTSi 41363 ZFFAA02A1C0041363 1982 X X
    308 GTSi 41365 ZFFAA02A5C0041365 1982 Red Tan
    308 GTSi 41367 ZFFAA02A9C0041367 1982 Red Tan
    308 GTSi 41381 ZFFAA02A3C0041381 1982 Red Tan
    308 GTSi 41383 ZFFAA02A7C0041383 1982 X X
    308 GTSi 41385 ZFFAA02A0C0041385 1982 X X
    308 GTSi 41387 ZFFAA02A4C0041387 1982 X X
    308 GTSi 41399 ZFFAA02A0C0041399 1982 X X
    308 GTSi 41401 ZFFAA02A5C0041401 1982 Red Tan
    308 GTSi 41403 ZFFAA02A9C0041403 1982 X X
    308 GTBi 41407 ZFFAA01A4C0041407 1982 X X
    Mondial 8 41431 ZFFAD08A5C0041431 1982 Black Black
    Mondial 8 41433 ZFFAD08A9C0041433 1982 X X
    Mondial 8 41435 ZFFAD08A2C0041435 1982 X X
    Mondial 8 41437 ZFFAD08A6C0041437 1982 Blue Black
    Mondial 8 41441 ZFFAD08A8C0041441 1982 X X
    Mondial 8 41443 ZFFAD08A1C0041443 1982 X X
    Mondial 8 41445 ZFFAD08A5C0041445 1982 X X
    Mondial 8 41449 ZFFAD08A2C0041449 1982 X X
    Mondial 8 41451 ZFFAD08A0C0041451 1982 Red Tan
    308 GTSi 41461 ZFFAA02A1C0041461 1982 X X
    308 GTSi 41467 ZFFAA02A2C0041467 1982 X X
    308 GTSi 41469 ZFFAA02A6C0041469 1982 X X
    308 GTSi 41473 ZFFAA02A8C0041473 1982 X X
    308 GTSi 41475 ZFFAA02A1C0041475 1982 Red Black
    308 GTS QV 41487 ZFFMA13A4D0041487 1983 Black Black
    308 GTSi 41489 ZFFAA02A1C0041489 1982 Black Black
    308 GTSi 41493 ZFFAA02A3C0041493 1982 X X
    308 GTSi 41495 ZFFAA02A7C0041495 1982 Red Black
    308 GTSi 41497 ZFFAA02A0C0041497 1982 X X
    308 GTSi 41499 ZFFAA02A4C0041499 1982 X X
    308 GTSi 41511 ZFFAA02A1C0041511 1982 X X
    308 GTSi 41513 ZFFAA02A5C0041513 1982 X X
    308 GTBi 41521 ZFFAA01A2C0041521 1982 Black Naturale
    308 GTSi 41539 ZFFAA02A1C0041539 1982 Red Tan
    308 GTSi 41541 ZFFAA02AXC0041541 1982 X X
    308 GTSi 41543 ZFFAA02A3C0041543 1982 X X
    308 GTSi 41553 ZFFAA02A6C0041553 1982 X X
    308 GTBi 41559 ZFFAA01A5C0041559 1982 X X
    308 GTBi 41561 ZFFAA01A3C0041561 1982 X X
    308 GTSi 41575 ZFFAA02A5C0041575 1982 X X
    308 GTSi 41577 ZFFAA02A9C0041577 1982 X X
    308 GTSi 41579 ZFFAA02A2C0041579 1982 X X
    308 GTSi 41581 ZFFAA02A0C0041581 1982 X X
    308 GTSi 41591 ZFFAA02A3C0041591 1982 Red Black
    308 GTSi 41593 ZFFAA02A7C0041593 1982 X X
    308 GTSi 41595 ZFFAA02A0C0041595 1982 X X
    308 GTSi 41597 ZFFAA02A4C0041597 1982 X X
    308 GTSi 41619 ZFFAA02AXC0041619 1982 X X
    308 GTSi 41621 ZFFAA02A8C0041621 1982 X X
    308 GTSi 41623 ZFFAA02A1C0041623 1982 Red Black
    308 GTSi 41641 ZFFAA02A3C0041641 1982 Red Black
    308 GTSi 41643 ZFFAA02A7C0041643 1982 X X
    308 GTSi 41645 ZFFAA02A0C0041645 1982 X X
    308 GTBi 41661 ZFFAA01A7C0041661 1982 X X
    308 GTSi 41665 ZFFAA02A6C0041665 1982 White Cream
    308 GTSi 41697 ZFFAA02A8C0041697 1982 Red Light Grey
    308 GTSi 41699 ZFFAA02A1C0041699 1982 X X
    308 GTS QV 41701 ZFFMA13A2D0041701 1983 X X
    308 GTSi 41705 ZFFAA02A3C0041705 1982 X X
    308 GTSi 41707 ZFFAA02A7C0041707 1982 X X
    308 GTSi 41709 ZFFAA02A0C0041709 1982 X X
    308 GTSi 41711 ZFFAA02A9C0041711 1982 Red Black
    308 GTSi 41747 ZFFAA02A8C0041747 1982 X X
    308 GTS QV 41749 ZFFMA13A8D0041749 1983 X X
    308 GTSi 41751 ZFFAA02AXC0041751 1982 Red Black
    308 GTSi 41753 ZFFAA02A3C0041753 1982 X X
    308 GTS QV 41755 ZFFMA13A3D0041755 1983 X X
    308 GTSi 41757 ZFFAA02A0C0041757 1982 X X
    308 GTS QV 41771 ZFFMA13A1D0041771 1983 X X
    308 GTS QV 41773 ZFFMA13A5D0041773 1983 X X
    308 GTS QV 41775 ZFFMA13A9D0041775 1983 X X
    308 GTS QV 41789 ZFFMA13A9D0041789 1983 X X
    308 GTS QV 41791 ZFFMA13A7D0041791 1983 X X
    308 GTSi 41795 ZFFAA02A8C0041795 1982 X X
    308 GTB QV 41797 ZFFMA12A6D0041797 1983 X X
    308 GTS QV 41813 ZFFMA13A2D0041813 1983 X X
    308 GTS QV 41815 ZFFMA13A6D0041815 1983 X X
    308 GTS QV 41817 ZFFMA13AXD0041817 1983 White Red
    308 GTS QV 41835 ZFFMA13A1D0041835 1983 X X
    308 GTS QV 41837 ZFFMA13A5D0041837 1983 Red Tan
    308 GTS QV 41839 ZFFMA13A9D0041839 1983 Rosso Barchetta Tan
    308 GTS QV 41841 ZFFMA13A7D0041841 1983 Red Tan
    308 GTS QV 41853 ZFFMA13A3D0041853 1983 X X
    308 GTS QV 41857 ZFFMA13A0D0041857 1983 X X
    308 GTS QV 41891 ZFFMA13A0D0041891 1983 X X
    308 GTS QV 41893 ZFFMA13A4D0041893 1983 X X
    308 GTS QV 41895 ZFFMA13A8D0041895 1983 X X
    308 GTS QV 41899 ZFFMA13A5D0041899 1983 X X
    308 GTB QV 41901 ZFFMA12A8D0041901 1983 X X
    308 GTBi 41903 ZFFAA01A5C0041903 1982 X X
    308 GTS QV 41919 ZFFMA13A7D0041919 1983 X X
    308 GTS QV 41921 ZFFMA13A5D0041921 1983 X X
    308 GTS QV 41939 ZFFMA13A2D0041939 1983 X X
    308 GTB QV 41947 ZFFMA12AXD0041947 1983 Rosso Rubino Black
    308 GTB QV 41949 ZFFMA12A3D0041949 1983 X X
    308 GTS QV 41957 ZFFMA13A4D0041957 1983 X X
    308 GTS QV 41961 ZFFMA13A6D0041961 1983 Red Black
    308 GTS QV 42015 ZFFMA13A1D0042015 1983 X X
    308 GTS QV 42017 ZFFMA13A5D0042017 1983 X X
    308 GTS QV 42019 ZFFMA13A9D0042019 1983 Red Tan
    308 GTS QV 42053 ZFFMA13A9D0042053 1983 X X
    308 GTS QV 42055 ZFFMA13A2D0042055 1983 X X
    308 GTBi 42081 ZFFAA01A5C0042081 1982 Red Black
    308 GTS QV 42093 ZFFMA13AXD0042093 1983 X X
    308 GTS QV 42095 ZFFMA13A3D0042095 1983 X X
    308 GTS QV 42097 ZFFMA13A7D0042097 1983 X X
    308 GTS QV 42115 ZFFMA13A5D0042115 1983 X X
    308 GTS QV 42117 ZFFMA13A9D0042117 1983 X X
    308 GTS QV 42137 ZFFMA13A4D0042137 1983 Yellow Black
    308 GTS QV 42139 ZFFMA13A8D0042139 1983 Red Tan
    308 GTS QV 42141 ZFFMA13A6D0042141 1983 X X
    308 GTS QV 42143 ZFFMA13AXD0042143 1983 X X
    308 GTS QV 42145 ZFFMA13A3D0042145 1983 X X
    308 GTS QV 42173 ZFFMA13A8D0042173 1983 X X
    308 GTS QV 42201 ZFFMA13A9D0042201 1983 X X
    308 GTS QV 42203 ZFFMA13A2D0042203 1983 X X
    308 GTS QV 42205 ZFFMA13A6D0042205 1983 X X
    308 GTS QV 42223 ZFFMA13A8D0042223 1983 X X
    308 GTS QV 42231 ZFFMA13A7D0042231 1983 X X
    308 GTS QV 42241 ZFFMA13AXD0042241 1983 X X
    308 GTS QV 42245 ZFFMA13A7D0042245 1983 Red Tan
    308 GTS QV 42247 ZFFMA13A0D0042247 1983 X X
    308 GTS QV 42249 ZFFMA13A4D0042249 1983 X X
    308 GTS QV 42271 ZFFMA13A8D0042271 1983 Red Tan
    308 GTS QV 42275 ZFFMA13A5D0042275 1983 X X
    308 GTS QV 42355 ZFFMA13A3D0042355 1983 X X
    308 GTS QV 42359 ZFFMA13A0D0042359 1983 X X
    308 GTS QV 42361 ZFFMA13A9D0042361 1983 X X
    308 GTS QV 42363 ZFFMA13A2D0042363 1983 X X
    308 GTS QV 42365 ZFFMA13A6D0042365 1983 X X
    308 GTSi 42389 ZFFAA02A2C0042389 1982 X X
  20. Dr Tommy Cosgrove
    May 4, 2001
    36,431
    Birmingham, AL
    Tommy
    Brian - Thank you! I really appreciate this!
    4re308 likes this.
  21. Rifledriver
    37,101
    My pleasure.
    There are a few USA version cars that were not originally shipped to the USA, Those are not on this list. Also some USA version cars came here outside of the normal channels and those will not be here either but it should be 95% of the cars with US VINs.
  22. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
    4re308 likes this.
  23. Dr Tommy Cosgrove
    May 4, 2001
    36,431
    Birmingham, AL
    Tommy
    That appears to be a USA model based on the VIN's "A" - and you and it are in Germany now?
    4re308 likes this.
  24. ME308
    ME308 Formula 3
    Nov 5, 2003
    1,550
    Munich, Germany
    Michael
    yub, bought the car in 2003
    4re308 likes this.
  25. Rifledriver
    37,101
    I know there are cars not on the list. I guess you missed that part.
    4re308 and Rosey like this.
