Socket for diagnosis | FerrariChat
Discussion in '308/328' started by Gino328, Dec 12, 2020.
  1. Gino328
    Gino328 Rookie
    Jun 21, 2020
    17
    Joe Watson
    The 328 owners manual says "a socket connectied to the ignition system ... is available for connection of the diagnostic unit..." Is this diagnostic unit available? What does it help adjust?
  2. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,241
    CT
    John Kreskovsky
    It doesn't allow adjustment of anything. It just lets you see various ignition signals. Here is the 308 QB version. I imagine the 328 is similar. Should be a description in the manual.
  3. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,150
    SanFrancisco BayArea
    1983 US 308 GTS QV
    Interesting.
    Any idea what the 12v pin is for? Presumably it is switched with the ignition key.
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    From what I've heard, the Ferrari Tester that plugged into that was nearly useless.
  5. johnk...
    Jun 11, 2004
    11,241
    CT
    John Kreskovsky
    The 12 V pin shows that 12V is supplied to the coils. The crank sensor pins show the sensor signal. The coil trigger signal show that the ECU is firing the coils and from the shape of the pulse you tell a lot if you understand the relationship of the shape to different problems. For example\ this figure shows the difference between bank 1 and bank 2 on my car when I lost bank 1 due to a bad rotor.
    BrockBenson likes this.
  6. Steve Magnusson
    26,840
    It's more for verifying that things are working correctly or not -- if you search on "Jofatron" (the name of the unit), you'll get some prior threads.
  7. johnk...
    Jun 11, 2004
    11,241
    CT
    John Kreskovsky
    Here is a PDF about ignition waveforms.
    thorn likes this.
