Soft Top Fluid | FerrariChat
Soft Top Fluid
Discussion in 'Technical Q&A' started by LmnsBlu355, Mar 7, 2010.
  1. LmnsBlu355
    LmnsBlu355 Formula Junior
    Dec 28, 2009
    284
    NY
    Jordan S.
    I need to add fluid to my 355 soft top reservoir. I've done a search and info here is not 100% clear.
    I have a liter of Pentosin CHF 202 which is a synthetic. It says it is compatible with Pentosin CHF 11 (Both are synthetic). It is NOT compatible with Pentosin CHF 7.1 which is mineral based.
    I've seen on this forum rec's to use ordinary hydraulic jack oil (which I assume is mineral based) and rec's to use "Pentosin" but no info on exactly which formula.
    Does anyone know the correct specs for the fluid to add to original? I don't want to mix incompatible fluids.
    thanks,
    Jordan
  2. f355spider
    f355spider F1 World Champ
    18,055
    #2 f355spider, Mar 8, 2010
    It does not appear to be particularly sensitive...as you can see, people are all over the place. The FNA dealers generally recommend using the stuff available at Mercedes dealers. I did some research and if I recall correctly, it was made by Pentosin, and synthetic. I ended up using Pentosin CHF 11s. I have used that for top ups the past several years, no problems. ;) (a friend is the head tech at a lambo dealership, he said they use CHF 11s in the lambos, Bentleys, Jags, etc.)
    Correction! NOT made by Pentosin...made by Aral Vitamol: http://www.aral-lubricants.com/lubricants/com/automotive_lubricants/our_products/vitamol_zh-m.html
  3. rizzo308
    rizzo308 F1 Rookie
    BANNED Silver Subscribed
    Sep 12, 2004
    2,784
    Perth, Australia
    riggio
    +1 on the mercedes fluid.
  4. LmnsBlu355
    Dec 28, 2009
    284
    NY
    Jordan S.
    Thanks for the info. I'll be purchasing the mercedes ZH-M tomarrow.
  5. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    Have to be honest, Jordan, I'd probably feel safer flushing the system and adding all new fluid, to be safe. Just my 2cents; I don't own a 355 softop.
  6. Ferrari328GT
    Ferrari328GT Karting
    Jan 6, 2008
    232
    Phoenix, Arizona
    Steve
    I had to add fluid to a 355 a few years ago, and the Ferrari dealer said to use the Mercedes stuff. You can buy it right from the Ferrari dealer for something like $60, or from Mercedes for about $20. The container is identical. - Steve
