soft top frustrations | FerrariChat
Discussion in '348/355' started by coledoggy, Nov 12, 2007.
  1. coledoggy
    coledoggy Formula 3
    Apr 8, 2007
    2,185
    ole miss
    todd
    my 97 355 top doesnt want to go down today, it wanted to go down on saturday, but not today. it will start to go down for about a second or two and then just get stuck. same procedures used as always, nothing done different today that wasnt done on saturday, just different results. my frustration from a reliable daily driver turbo to this 355 is starting to grow, i need help! any suggestions or am i screwed with another monsterous bill. thanks.
  2. Shumdit
    Shumdit Formula Junior
    May 9, 2006
    335
    Greenville, SC
    Matthew B.
    The 355 top will sometimes not work if the seat switches/motors do not work properly. In that way it could be completely unrelated to the top itself, although a pump issue or fluid level could also be a possibilty. I think the seat thing is the most common reason on a 355 though.
    PS- I am only relaying info my brain has collected over the years. I am not a Ferrari tech and I did NOT stay at a Holiday Inn Express last night!
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    If it's a seat potentiometer issue, then the emergency override button will put the top down for you.
    If it's a low hydraulic fluid issue, then adding fluid behind your seats will fix the problem.
    If the upper middle cross-bar on the soft-top is stuck down, then you'll have to push that horizontal bar up by hand when the soft top is opening right above your head.
  4. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Make sure it is folding up correctly.
    Does the motor sound stop too or does it struggle?
    Check the fluid level and any physical obstructions like the seats in the way.....etc.
  5. coledoggy
    coledoggy Formula 3
    Apr 8, 2007
    2,185
    ole miss
    todd
    motor sound doesnt stop, and the car is 1 month out of a major service, supposedly all that was checked.
  6. Dr_ferrari
    Dr_ferrari Formula 3
    Nov 2, 2003
    1,071
    Pocono Sportscar
    Jim McGee
    Check to make sure when you push back the top the center rail (above your head) folds upward when it is pushed back. most of the time the rubber straps become loose and will not allow the top to fold up and the center rail gets stuck into the front header.
    best regards, Jim
  7. mwhitesell
    mwhitesell Formula 3
    Sep 17, 2006
    1,083
    Atlanta
    Mark
    That sounds like fluid for sure. I just went through the process of adding fluid. It's not that involved to add the fluid but bleeding it takes a little effort. It's easy to check the fluid, just take the center part off between the seats. If you have never seen it, then you should learn about it.
  8. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    +1 ....
  9. coledoggy
    coledoggy Formula 3
    Apr 8, 2007
    2,185
    ole miss
    todd
    i finally got to the resevoir for the soft top fluid. the fluid level is at the minimum mark. how do i get into the canister to add fluid, and what is it i need to put in there? also where do i get this fluid from. thanks.
  10. veryfast355
    veryfast355 Karting
    Sep 24, 2007
    120
    gt neck long island
    michael c
    you can use standars hydraulic jack oil
  11. veryfast355
    veryfast355 Karting
    Sep 24, 2007
    120
    gt neck long island
    michael c
    and the fluid goes through the hole that has the 13mm filler nut
  12. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
  13. coledoggy
    coledoggy Formula 3
    Apr 8, 2007
    2,185
    ole miss
    todd
    ok, ive added the fluid from the min line to the max line, can i work my top like normal, or do i need to "bleed" it first?
    the top worked as recently as last saturday, and the car just had its 30k service done. thanks for the help, yall have certainly saved me a trip so far.
  14. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Jim's advise was spot on. Topping the fluid from the min to the max will have no effect and will not require bleeding.
    The elastic straps on both sides that pulls the second bow back when the header comes back have stretched and no longer pull the second bow back far enough.
    Locate the elastic straps and as the header lifts up off the windshield frame, manually assist the second bow up and backwards a little. If the elastic is weak the second bow will stop short of where it needs to be and will bind the whole top assy. If you held the button too long with it in bind up it can draw air in and mis-time the main rams. If that is the case operate the top a number of times using the emergency switch and see if it comes back into time.
    We make new straps for all of the Spiders when they are in for a major, its not just about T-belts. Very common problem.
    Dave
  15. tchaic
    tchaic Formula Junior
    Jul 11, 2004
    601
    Florida
    Chris M.....
    As usual Goth and No Doubt nailed it... you guys are 355 wizards!
