Solar panels/ Solar power | FerrariChat
Discussion in 'Australia' started by goober, Sep 13, 2010.
  1. goober
    goober F1 World Champ
    Nov 15, 2004
    15,895
    Adelaide & Thredbo
    Buddy Miles
    does anyone what 2.2 kw in solar power represents in laymans english. Meaning how many light bulbs/ fridges/ dish washers etc does 2.2 kw power.
    Reasoning behind this is an ad for solar power just come for 8 panels and inverter for 2.2 kw at $2596.00.
    Not that I'm turning green but if it saves on giving AGL any more money. And whats the cost of replacement panels?
  2. SPEEDCORE
    SPEEDCORE Four Time F1 World Champ
    Jul 11, 2005
    46,182
    Toe Knee
    #2 SPEEDCORE, Sep 13, 2010
  3. goober
    Nov 15, 2004
    15,895
    Adelaide & Thredbo
    Buddy Miles
    i can do that without a delorean............a lola has the same effect
  4. SPEEDCORE
    Jul 11, 2005
    46,182
    Toe Knee
  5. goober
    Nov 15, 2004
    15,895
    Adelaide & Thredbo
    Buddy Miles
  6. Aedo
    Aedo F1 Rookie
    Feb 22, 2006
    3,616
    Perth
    Steve
    The maximum power you can draw from a power point is 2.4kW (10A at 240V). There are several household appliances that draw close to that maximum (tumble drier/dishwasher/hair dryer/kettle/oven/AC). The worst of these is the tumble dryer because it runs at full power for an hour or so, the others run at full power for minutes typically (AC usually runs at full power for a few minutes every so often).
    All other appliances in the house are pretty much noise compared to these big loads (40 downlights = 2kW).
    In terms of how useful that 2.2kW is - well its useless for light globes for starters :)
  7. goober
    Nov 15, 2004
    15,895
    Adelaide & Thredbo
    Buddy Miles
    thus going solar is a fallacy.............i would have thought that costs would entice people to go solar but thats not the case.
    Might have to settle for a genset generator.....petrol is still cheap
  8. powderbomber
    powderbomber Rookie
    Sep 5, 2009
    23
    theres a difference between going totally solar powered, ie "off grid" and using a grid connect offset system.
    to go off grid is doable but difficult, requiring battery banks, low voltage appliances, rewiring the house for 12v etc etc
    the vast majority of residential systems are grid connect, meaning power generated in daylight hours is fed to the grid, effectively running the meter backwards to offset power usage over the 24 hour period.
    the thing that makes it all work is the government mandated feed in tarriff which is around 50c a kwh in SA. (arguably an inefficient and wasteful use of resources vs investment in nuclear power but thats another debate!)
    the average house uses 20kwh per day.
    the rule of thumb is that you will generate 4.5 kwh per day, per kw of installed solar capacity - so a 2.2kw system will on average generate 9.9kwh per day.
    it is possible to live off this, my parents have been running on a 2kw system for 5 years and have never paid a power bill, in fact their account is currently around $1500 in credit. this involved significant lifestyle adjustment though, and incorporated super efficient appliances, no air conditioning - wood heating, and a specially designed house.
  9. Aedo
    Aedo F1 Rookie
    Feb 22, 2006
    3,616
    Perth
    Steve
    Yes petrol is cheap... but not as cheap as coal :)
    Petrol = 34 MJ/l = 3.5c/MJ or 28MJ/$ (at $1.20/l)
    Coal = 24 MJ/kg = 0.3c/MJ or 300MJ/$ (at $80/tonne for Newcastle thermal coal).
    This is why we use coal to generate electricity :)
    Even I could make my house revenue neutral with that feed in tarriff!
  10. XTREMEIND
    XTREMEIND Formula 3
    Mar 8, 2010
    1,270
    Melbourne, Australia
    Showbag
    Put a young boy on an exercise bike in the back yard, have'nt you seen the XXXX ad.
  11. Looney
    Looney F1 Rookie
    Jul 1, 2004
    2,767
    Gold Coast
    BB
    Mate i wish, my house uses 32kwh per day and im never even home. thats just the pool, hot water, and TV when i actually am home.
    i looked into it and i need a 4+kw system to make it neutral for me ($ wise) and thats a $16k install. vs the 8 years of electricity it buys me.
  12. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Thats ok. Especially if you are going to live there for the rest of your life. :D:D
    $16K is **** all. :):)
  13. Aedo
    Aedo F1 Rookie
    Feb 22, 2006
    3,616
    Perth
    Steve
    You do have an average Australian house :) - the Australian average is ~1.5kW average which is 30kWhr/day. 20kWhr per day is 0.83kW average which is more like Europe. The US is 2.5kW and Japan is ~0.75kW average consumption.
    An 8yr payback is pretty good - but if reliant on Government incentives that is a bit of a worry!
  14. Looney
    Looney F1 Rookie
    Jul 1, 2004
    2,767
    Gold Coast
    BB
    yeah, but that 8 years isnt accounting for the ROI on that $16k should i put it elsewhere, its also dependant on the buyback price being 2.5 times the actual tarrif rate (not likely to stay that high much longer).
    and what happens if the panels get destroyed in one of our famous hail storms. i know insurance covers them currently, but i bet once a few claims get made for solar panels damaged in storms, the insurance companies will not cover them, or impose additional insurance on them.
    and then the other thing in my mind (and this is purely speculting based on things ive heard, im sure you can provide more input as you work in this field), dont Solar panels reduce efficiency over time? and most only seemed to have a 5 or 10 year guarantee efficiency. so is it likely that they will not be producing much energy at all after that time? is it an exponential decay curve?
  15. PAP 348
    Dec 10, 2005
    100,220
    Pap
    I just heard on the radio here before that the Gov is buying it back at 5 times the rate till 2012. :D:D
    I dont know if the radio here is right or you are? :D:D
    Ive never heard of solar panels losing their effienciency before. :):)
    I know they are not *that* efficient in the first place. :D:D
  16. Looney
    Looney F1 Rookie
    Jul 1, 2004
    2,767
    Gold Coast
    BB
    current tarrif is about $0.19 per kwh, but the buy back rate is $0.50 per kwh. so 2.5 times, but i bet they're probably quoting some lower tarrif (like an off peak tarrif etc) of $0.11 per kwh or so.
    i dont know if they actually do loose efficiency or not, but i did notice while looking into it in real depth last year, they only warranted the panels for a % efficiency over time. which to me implies that they loose efficiency over time. I am not sure of the ins & outs, which is why i posed it as a question.
    but even then $16k invested, at even a conservative ROI of $6% is $1000 per year it needs to recover for you to be worthwhile,
    in turn even on a very basic NPV calculation it will then realistically be 11 years to repay itself (assuming CPI for buyback & tarrifs).
    all quite basic calculations, and the reality is electricity is going to increase far more than CPI. but still 11 years to recover the investment is not really worthwhile IMO.
  17. wax
    wax Five Time F1 World Champ
    Jul 20, 2003
    52,417
    SFPD
    Dirty Harry
    9% per annum is excellent. ROI thereafter is gravy.
  18. Aedo
    Aedo F1 Rookie
    Feb 22, 2006
    3,616
    Perth
    Steve
    I think they do reduce over time - but they should still exceed 80% or so of rated capacity after 30 years of cost free running and still be going.
  19. moretti
    moretti Five Time F1 World Champ
    Nov 1, 2003
    59,757
    Australia
    Gordon Gecko is after robber baron profits
  20. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Cool man. :D:D
    IF I was going to live in this house for the rest of my life, id invest the $16K or whatever it took to do it. :D:D
    But im not, so I will happily pay $2500 or so a year (today's rates) for electricity. :D:D
    Only going to get more expensive with kids running around and the Gov jacking the rates up, but whadda ya do. :rolleyes::rolleyes:
  21. Frari
    Frari Formula 3
    Nov 5, 2003
    1,194
    brisbane australia
    tony
    did you see the new inventors last night, a professor and his group of students are developing a polymer solar cell that can be produced very cheaply and can be applied to the whole of your roof. It is 1/2 as efficient as a solar panel but you can cover your whole roof so it makes about 4 times the usual kw. They say that it will be perfected in about 2 years and will mean that you will be able to produce enough power for a normal household for the cost of about $3000. They are also working on a conductive paint so you can place it on a special coating on your house and produce electricity.
    The day it comes down to $5000 and you can store and equate to your normal use is the day I change and goodbuy energex,agl etc. then all we need to do is produce our own water, do our own sewage processing and stuff the city council robbers.
  22. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Didnt watch that show, but that does sound impressive! :D:D
  23. riccajus
    riccajus Rookie
    Mar 3, 2004
    48
    Australia
    Justin Riccardi
    solar is the way to go, my brother in law is a sparky and raves on about it. dont understand everything he says as i am a fruiterer not a engineer, but he buys his panels from www.rockby.com.au have a look, he says they are very reasonably priced
  24. goober
    Nov 15, 2004
    15,895
    Adelaide & Thredbo
    Buddy Miles
    septic tanks do away with sewerage
  25. Aedo
    Aedo F1 Rookie
    Feb 22, 2006
    3,616
    Perth
    Steve
    A friend has just had a 2kW array installed which cost $4k (after rebates etc) - seems a pretty reasonable deal in WA where power bills are ~$400/m.
