Solex/Mukuni carburetor overhaul (Side Draft) | FerrariChat
Discussion in 'Technical Q&A' started by Racer98, Apr 1, 2006.
  1. Racer98
    Racer98 F1 Rookie
    4,766
    Encino.
    K-Fence.
    Hey guys I know most of you on your classic cars run Webbers but I wanted to know if you any of you have photo shots of your side draft carburetor rebuild.
    I have the most part figured out but I found a metal plate wedge that is on 1 side of the carbs wanted to see if any ones webbers are the same on the internals ????
    thanks for any photos if some one would like to share them.
  2. Racer98
    Racer98 F1 Rookie
    4,766
    Encino.
    K-Fence.
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,804
    The twilight zone
    Is there a ferrari that uses those carbs? If so, you might try posting in the correct model specific section particularly if it's pre 1976....there isn't a lot of vintage activity in tech for some reason.
  4. Bryan
    Bryan Formula 3
    While there are always exceptions, almost all Ferraris used Weber carbs. The major side draft Weber in a Ferrari is the DCOE in the 365 GTC4.
    I can't guarantee that a Solex or Mikuni side draft will have similar detailed parts to a DCOE, but if you can describe the part that you interested in, I'll try to give you my opinion (I own a 365 GTC4).
    Alternatively, you can look at the exploded parts diagram for a DCOE at
    http://www.webercarburetor.com/weberexplode.htm
  5. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,456
    Dumpster Fire #31
    SMG
