Solution for problem with trying to fill gas in 360 | FerrariChat
Discussion in '360/430' started by MalibuGuy, Mar 30, 2011.
  1. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,892
    Like a number of 360 owners, I would like to find a solution to the problem of the having premature shut-off while trying to pump gas.
    I have resorted to holding the gas pump handle upside down. But this is less than satisfactory because fuel often squirts out or leaks.
    It has been suggested that replacing the Fuel Vapor canistor might solve the problem.
    Has anyone done this?
  2. concours
    concours Karting
    Jan 10, 2008
    120
    Palos Verdes, Ca
    Richard
    Premature shut off never happens when filling my ['03] 360 and none of the guys I know with 360's have ever complained about this. However it happened frequently with my 328 and after checking around I found that some gas stations seemed to pump slower than others [my local Mobil for one] resulting in no premature shut off. The only other solution was to hold and squeeze the gas pump trigger to slow down the flow while refuelling which solves the early shut off but cramps your hand. Incidentally the "tank full shut off" still works, so no problem with overflow
  3. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,166
    Wash DC area
    Robert
    Yes, at times I have experienced this as well and I just turn the handle upside down as well. Another solution is just not to squeeze the handle as hard, pump the gas a little slower.
    For me it does not happen all the time and is not that big a pain.
  4. C4YES
    C4YES Formula Junior
    Apr 7, 2008
    992
    Orange County, CA
    Todd
    Tilting the handle upwards, nozzle downward opposite from jst letting it rest in the tube works for me.
  5. swilliams
    swilliams Formula 3
    Jun 14, 2006
    1,407
    Bowling Green, KY
    Scott
    I just push the nozzle all the way in and then out about 1.5 inches. I can go full blast there until its full. I go to the same gas station most of the time so that helps also.
  6. Camdon53
    Camdon53 Formula Junior
    Jul 18, 2006
    507
    Texas, USA
    Jim
    The guys at my dealer diagnosed this and replaced my vapor canister some time ago. The situation was greatly improved although slow fueling is still needed if I want to really top it off. Toping up all the way like that (i.e., filling the air baffles) is pretty much the same in regular cars and may not be a recommended practice.
  7. TAFORZA
    TAFORZA Formula Junior
    Jun 5, 2008
    296
    San Francisco, USA
    Tony A.
    It is not advisable to fully top off any car. When you do that, raw fuel "not vapor" will end up in the vapor canister and eventually will damage it. You should stop pumping gas when the gas nozzle clicks due to back pressure from the tank being full. Toping off by continuously by making the the gas nozzle "click" several times will damage your EVAP system. New California regulations in the past couple years have mandated different gas pump designs that are more sensitive to shutting off. Try few different gas stations and see if the problem is consistent. There are several different nozzle designs that are approved by the State and one of them might work better if the problem is not related to the car.
  8. Dougb450
    Dougb450 Rookie
    Jun 8, 2010
    37
    DougB
    Gents,
    My solution is to fill it until the nozzle pops. Then stand around chatting with the attendant for two minutes. This gives the fuel time to transfer to the other tank. Then start pumping gas again. After the second pop, you're done and your tanks will be full without overfilling.
    Doug
    2004 360 Modena F1
  9. testdrv321
    testdrv321 Formula Junior
    Oct 31, 2010
    259
    Long Island, NY
    Edward Newman
    Don't they have a pill to help with that?
    Seriously, we run into this alot with the trucks we have made with aftermarket bodies. It is usually a kink or other problem with the fuel filler line or the vent line. Have you shop take a peek and see if anything is out of wack. Maybe blow out the vent line too.
    Ed
  10. MalibuGuy
    Sep 18, 2007
    5,892
    My situation is pretty bad. Unless the handle is upside down at 12 o'clock, it shuts off in 2-3 seconds. Impossible to fill. So I turn the handle upside down and it still pops off but every 20 seconds. Yes if I just barely trickle the gas in things are a little better. But then gas squirts out on my shoes and leaks out on the paint.
    I just ordered the fuel vapor canistor from Ricambi. I hope it will improve the situation.
    Thanks for the feedback.
  11. dicin
    dicin Karting
    Sep 6, 2009
    78
    Montreal / Canada
    Nick
    Replaced vapour canister and solved the problem. This fixed my problem. I was also told never continue to fill to the top as the raw fuel in the canister creates the problem in the long term.
  12. ttdang123
    ttdang123 Formula Junior
    Nov 28, 2009
    706
    North San Diego CA
    Tung
  13. TheMayor
    106,167
    Vegas baby
    #13 TheMayor, Apr 1, 2011
    This is a real problem in LA. They have special nozzles. When I had my F430 in LA it was hard to fill. In Nevada it's no problem.
    My Maserati is worse if you can believe that. I'm lucky to get it 7/8's full even with the shut off stopping the flow 6 or 7 times.
    Many times I left the station thinking it was completely full only to see the gauge say 3/4.
    Believe it or not try a different pump or service station. I found that some work better than others. They are not 100% identical.
  14. MalibuGuy
    Sep 18, 2007
    5,892
    Solution found: replace the fuel vapor canister!
    I just had the canister replaced and filled up my gas tank at a station in So Cal without any fuss!
    Should have done this months ago instead of listening to FChatters suggesting holding the nozzle upside down! That is not a Real solution with gas spraying out.
  15. ttdang123
    Nov 28, 2009
    706
    North San Diego CA
    Tung
    MalibuGuy
    Where and what part number did you buy? Thanks
  16. rmani
    rmani F1 Veteran
    Nov 1, 2003
    7,334
    NJ
    RMani
    twist the pump upside down
  17. MalibuGuy
    Sep 18, 2007
    5,892
    #17 MalibuGuy, Apr 14, 2011
    Call Ricambi. The canister part varies according to the version of 360. Mention that you are on F-Chat for a little discount too.
  18. MalibuGuy
    Sep 18, 2007
    5,892
    Replacement of the fuel vapor canister is the proper solution.
  19. Black360
    Black360 Formula Junior
    Oct 11, 2010
    437
    East of Eden
    Steve
    Did you replace the entire canister, or just the fuel vapor filter?
  20. MalibuGuy
    Sep 18, 2007
    5,892
    The part I replaced is called the fuel vapor cannister and is a black plastic part about the size of a sboe box.
  21. vm3
    vm3 Formula Junior
    Apr 12, 2007
    728
    California
    My 360, CS, and 458 all have this problem in California.
    Two solutions:
    1. Pull back the accordion seal slightly and hold it there until filling is done.
    2. Cut a 0.5" section of a 2.0" plastic pipe and insert the gas nozzle through it. This keeps the accordion back to let the gas fill.
    Works great for me.
  22. colorinc
    colorinc Karting
    Nov 8, 2010
    61
    Austin TX
    Tim Kasberger
    confirmed ...if its a pain in the butt to fill your 360 with fuel (constantly clicking off upon fill up) replace the charcoal vapor canister ... fixed all my slow fill woes
  23. BSU
    BSU Formula 3
    Mar 30, 2008
    1,012
    TX
    I can get to 7/8 no problem. No real need to top it off.
  24. hairman
    hairman Karting
    Nov 25, 2013
    94
    south jersey
    Dino
    i took the charcoal canister hose off and used a piece of stiff yet pliable wire and pushed it in and out in the canister where i removed the hose. it broke up the charcoal and i can get a full top up when the pump clicks off. I do not use the full speed fill on the nozzle ,i cut it back a bit. that depends if the pump is mad fast.
    worked for me
  25. hessank
    hessank Formula 3
    1,928
    Canada, Florida
    Fred
    I have the same problem and I believed that it was the design of the filler pipe that created a backpressure (splashback within the fill pipe) thereby shutting off the pump.
    My solution was to pump the gas slowly and I don't have that problem anymore.
