Solving heat and noice problems in cabin | FerrariChat
Discussion in '308/328' started by Sigmacars, Jan 16, 2012.
  1. Sigmacars
    Sigmacars Formula 3
    1,220
    #1 Sigmacars, Jan 16, 2012
  2. Sigmacars
    Sigmacars Formula 3
    1,220
    #2 Sigmacars, Jan 16, 2012
  3. Sigmacars
    Sigmacars Formula 3
    1,220
    #3 Sigmacars, Jan 16, 2012
  4. Sigmacars
    Sigmacars Formula 3
    1,220
    #4 Sigmacars, Jan 16, 2012
  5. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,325
    Southern New Jersey Shore
    Phil
    Nice!
    What product are you using for sound/heat shield?
  6. Sigmacars
    Sigmacars Formula 3
    1,220
    the trunk has very little insulation from ferrari it gets very hot inside no good to bring ice cream home from the store lol.even my golf clubs get hot going to the course.this should help
  7. NWA James
    NWA James Karting
    Jun 27, 2011
    98
    Northwest Arkansas
    NWA James
    Definitely don't put a good bottle of wine back there!
  8. Sigmacars
    Sigmacars Formula 3
    1,220
    #8 Sigmacars, Jan 16, 2012
  9. Sigmacars
    Sigmacars Formula 3
    1,220
    B-Quiet shield
    Product B-Quiet Utimate
    it is good to 320 dgr.F and it cost $20.00 for 12 sq. feet
  10. Sigmacars
    Sigmacars Formula 3
    1,220
    I forgot to tell you of course i put the origional insulation back on top of the new shield in the trunk
  11. lostbowl
    lostbowl Formula 3
    Apr 30, 2009
    1,246
    Michigan
    Tom
    nice cutting in on the insulation, Lost! Please. feedback on the improvement if noticeable.
  12. BigTex
    79,386
    Houston, Texas
    Bubba
    You need 'quiet" in the luggage compartment??
  13. Jonny Law
    Jonny Law F1 Rookie
    3,203
    Over yonder.
    IT Guy
    Where did you source this from? The website shows $54 for 12 sq ft.
  14. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,327
    I think that was for the heat.
    I have done some of this stuff on my 328 (using Dynamat) and being objective, I don't think its cut the overall noise levels very much at all. All these mat products are sound deadeners rather than barriers, so what they do is to stop panels from resonating which, theoretically cuts noise levels. I think there is a difference, but its more of a change (for the better) rather than a reduction in the overall volume level. No way are you going to turn the thing into a Lexus!
    One of the things about sound deadening material is also that you do not need to cover 100% of a panel for it to be effective. This saves both material and weight.
    See http://www.sounddeadenershowdown.com/products/cld
    There are a couple of wav files on that page that demonstrate quite well what the stuff does.
    For the trunk floor I used a sheet of Zircoflex 1 (http://www.zircotec.com/page/new-flexible-ceramic-products/97) underneath the trunk floor - so its above the heatshield above the silencer. Its not cheap but it has significantly reduced the heat in the trunk area. I figured that it was better to keep it out of there altogether. It also weighs basically nothing & is very thin. Clever stuff.
  15. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    #15 cavallo_nero, Jan 17, 2012
    Hello, I have been trying to remove my rear header and cant seem to get it out of the car. In your post, it looks like you have removed it successfully (see pic with red circle). I have drilled out the rivets and removed the screws, it looks like it is channeled on the sides toward the back and just slides out??? Please let me know how you removed this piece. thank you - and nice job BTW...
  16. Sigmacars
    Sigmacars Formula 3
    1,220
    No in there it is for the heat,i say that in my post.
  17. Sigmacars
    Sigmacars Formula 3
    1,220
    Take the Brake light off,take the 2 targa clamps off and pull the header towards the front NOT down there are 2 clips beside the Brake light where the header slides in.
  18. Sigmacars
    Sigmacars Formula 3
    1,220
    Yes sorry i got mixed up for the Cabin i used the Extreme $39.00 12sq feet (2 rolls)
    for the trunk Utimate $54 12sq feet (1 roll)
  19. cavallo_nero
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    #19 cavallo_nero, Jan 17, 2012
    thank you for the reply, i dont have the brake light back there - i have a 1978. I thought it would slide out, but it wont budge so far. the headliner is channeled back there by the quarter window - right?? see pic again with red oval indicating where i might be hung up.
  20. Sigmacars
    Sigmacars Formula 3
    1,220
    i have a 328 is yours a308? if so the 308 owners would help you out
  21. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,814
    Cerritos, CA.
    Sigmacars, all the work and insulation you have done are excellent specially if you're trying to keep the heat out of the cabin. But, if you don't solve the problem of how the heat are sneaking in from the front radiator to the inside of the car, it will always be warm in the cabin. So, if you can figure out how or where the hot air is going through please let us know. Thanks.:)
  22. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,325
    Phil
    This is like the holy grail....I've been searching for a clean, appropriate way to deal with this for years.
    I thought maybe by giving the heat/air flow an easier way to evacuate from the front end, this would lessen to transfer into the cabin. I added one of Gleggy's louvered panels under/behind the radiator. I was also thinking of replacing the inner front wheel well "stone guards" with a mesh that would allow air to flow freely out of the spare tire/radiator cavity....but this is still on my "to-do" list for the moment.
  23. Sigmacars
    Sigmacars Formula 3
    1,220
    I know and i am working on it also i will send pics tonight.
  24. Sigmacars
    Sigmacars Formula 3
    1,220
    I did the front also,first i insulated the heater hoses,also changed the filters in front of the heat exchanger ( the foam ones where gone) then sealed the the space behind the spare tire moulding but you must be able to remove it for service, also closed the opening under the batterie so no more water,dust, stones, can enter from the bottom also heat would warm up the batterie cover and heat up the spare tire cavity.i have pic,s tonight.
  25. Sigmacars
    Sigmacars Formula 3
    1,220
    #25 Sigmacars, Jan 17, 2012
