some aftermarket brakes for F430 | FerrariChat
Discussion in '360/430' started by aldogt3, May 31, 2006.
  1. aldogt3
    aldogt3 Rookie
    Dec 1, 2004
    20
    Does anybody have some idea about some 6 pot caliper and 380 mm discs for F430 (not carbon)?? I have normal brakes on my F 430 but I am not very pleased with it.
  2. TBond8
    TBond8 Karting
    Feb 7, 2006
    136
    CT,CA, Europe
    Thomas
    May I ask you a question?
    What is it about the regular brakes you are not too pleased with? Stopping distance? The way they feel? Etc..?
    Thanks,
  3. aldogt3
    aldogt3 Rookie
    Dec 1, 2004
    20
    The regular brakes are good up to 150 km/h but after that I don¨t liked, to week for the car like that (I have Porsche GT3 and 996 Carrera 4S both with 6 pot calipers and 350 mm discs and it is much better).
    And the look of this discs on 430??!!!!!!!!! This discs in 19 inch wheels are to small.
  4. TBond8
    TBond8 Karting
    Feb 7, 2006
    136
    CT,CA, Europe
    Thomas
    I understand. As I have owned several different Porsches. Yes Porsche brakes are very good.
    Is there a reason why you did not get the carbo brakes on your F430 other than the cost of the option?
    Have you had carbon brakes on your Porsches?
    Thanks,
  5. aldogt3
    aldogt3 Rookie
    Dec 1, 2004
    20
    I bought used F430
    No, I do not have carbon brakes on my Porsche but I try it, very good feeling but the stoping distance are not so much better than steel.
  6. Harmonyautosport
    Harmonyautosport Formula Junior
    Apr 28, 2006
    683
    New York
    Brembo offers a big brake kit for the F430. It is a 6 piston caliper on a 380mm 2 piece rotor. They only offer a front kit and it is $4,295. Please contact us to order.
  7. aldogt3
    aldogt3 Rookie
    Dec 1, 2004
    20
    I am in Europe, any dealer here??
  8. Harmonyautosport
    Apr 28, 2006
    683
    New York
    No idea we can ship there also.
  9. aldogt3
    aldogt3 Rookie
    Dec 1, 2004
    20
    Thanks, but if I buy it in Europe I do not have to pay duties (about 50 % here)
  10. RossoCorsaItaly
    RossoCorsaItaly F1 Rookie
    4,684
    LA & OKC
    Kevin
    You have PM.
  11. Fly'n DutchMan
    Fly'n DutchMan Karting
    Oct 4, 2005
    248
    Agoura Hills CA
    Sander Brouwers
    Brembo is coming out with a new line of perforamance calipers, including a 6 piston. I don't know when they will release an application for the F430 but you can call the master distributor www.racetechnologies.com
    Alternatively you could try a more aggresive pad for the time being with Brembo's two piece aluminum hat and rotor combo. They're six pounds lighter per rotor. The full set cost about $3400 the first time which includes the hats, but after that you only need to buy replacement rotors with are about 1/3 the price of stock F430 OEM rotors. The two peice replacement rotors are available now.
    I would not use a 380mm rotor, you don't need that much brake torque and those rotors will probably weight more than stock. Do not install a any brake upgrade kit from ANY company without checking the math and making sure the brake torque increase is with in the range of the EBD. You'll more than likely need to install an front an rear upgrae. To give you an idea of what the math looks like...you can see the spread sheet I had to do for my BMW applications in this link. http://www.brouwersusa.com/Master E46 M3 BBK Chart.xls
    If you have any questions PM me.
