Some TLC for my QV | Page 10 | FerrariChat
Some TLC for my QV
Discussion in 'Mondial' started by afterburner, Mar 25, 2015.
  1. afterburner
    afterburner F1 Rookie
    3,485
    Switzerland
    Urs STEMMLER
    Rear speakers rubbers were rotten away too:
    Old surround cleaned up and new items ready: Image Unavailable, Please Login
    repaired: Image Unavailable, Please Login
    Door panel parts restored and ready
    refitted
    Done
    Glove box lettering restoration - old paint removed Image Unavailable, Please Login
    refilled
    cleaned up
  2. afterburner
    3,485
    Switzerland
    Urs STEMMLER
    punching holes into the new leather...
    finished rear speaker panels:
    The cabin air intake rain protection below the wiper finishers looks pretty bad and was cracked in various places:
    All old paint was removed and the cracks and gasket support repaired to guarantee its continuity on the cowl, without which it would leak in to the HVAC, then repainted:
  3. afterburner
    3,485
    Switzerland
    Urs STEMMLER
    Done:
    There is a plastic cover below the carpet on the front door entrance. It covers the AC hoses:
    It did need a cleanup too Image Unavailable, Please Login
    Now - the left side was missing - and the one sold by Ferrari didn't fit (it was for the right side). I decided to reproduce the part based on an optical scan of the lh side:
    The scan looked useable:
    So it was used to create the 3D data for printing:
    Here the 2 prints before assembly:
  4. afterburner
    3,485
    Switzerland
    Urs STEMMLER
    Since the lh side panel is covering the wiring loom, brake booster vacuum hose and heater hose, it needed some modifications to allow all passages. Those were done by hand, cutting away offending areas and re-fitting them with the appropriate clearances.
    It finally looked like that:
    And it works
    Since it will be covered in carpet and was quite strong despite the cutting and glueing I didn't re-scan, reconstruct and re-print but used the part directly.
    rh side in position
    kartboy1234 likes this.
  5. afterburner
    3,485
    Switzerland
    Urs STEMMLER
    Interior Fan power transistor replacement:
    markings
    removed
    new parts Image Unavailable, Please Login
    fitted
    done
    I also replaced the pop-riveted mounting of the bracket with 2 bolts so the transistor could easily be removed again:
    easy vs a pain once installed behind the dash:
    ronfrohock likes this.
  6. afterburner
    3,485
    Switzerland
    Urs STEMMLER
  7. afterburner
    3,485
    Switzerland
    Urs STEMMLER
    One of the passengers foot well rubber mats had hardened and broke:
    As these are not readily available for a RHD car, we reproduced them (3d data, milled, silicon mold, vacuum casting)
    One of the vacuum tank brackets on the rh air intake was missing too - it needed to be reproduced as well. It was replaced with a bolt...
  8. JLF
    JLF Formula 3
    Sep 8, 2009
    1,707
    Awesome interior, gonna be the nicest Mondial!
    afterburner likes this.
  9. ronfrohock
    ronfrohock F1 Rookie
    4,163
    MA
    Ron Frohock
    All this work, this fast! Must be an army of people helping out!
    what are you going to do with your molds? You should consider reproducing parts.
  10. afterburner
    3,485
    Switzerland
    Urs STEMMLER
    Ron, all this happened over a longer period - most of which was spent waiting for... people to do what they said they would but finally didn't. I had the mechanical, body, painting and trim work done outside, since I lack the skills, equipment and space for it. The rest was done by me, bit by bit. Most of the molds have been discarded for lack of space, which is a premium here.
  11. afterburner
    3,485
    Switzerland
    Urs STEMMLER
    That was the mold
    made from this data
    Another part I couldn't source was the grommets in the front wheel arch where the gutter drain passes through. They were brittle hard and broken, and no part number available:
    Again, measurements, 3d data, silicon mold and vacuum casting:
  12. afterburner
    3,485
    Switzerland
    Urs STEMMLER
  13. afterburner
    3,485
    Switzerland
    Urs STEMMLER
  14. afterburner
    3,485
    Switzerland
    Urs STEMMLER
    same here - repair around the drain close to the oil cooler:
    parts ready, replated frame and cleaned up mesh, with their openings directional... the lh would sort of block the air if fitted to the rh.
    One bracket original, second one reproduced:
    done
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  15. afterburner
    3,485
    Switzerland
    Urs STEMMLER
    Glovebox restoration - as removed:
    preparation for the integration of a hidden USB charger port:
    wiring change for it - only functional with ignition ON to prevent battery drainage
    restored parts
    with a spare piece of leather I made an insert, which should stop things from rattling.
    reassembly
    USB
    Done
  16. afterburner
    3,485
    Switzerland
    Urs STEMMLER
  17. afterburner
    3,485
    Switzerland
    Urs STEMMLER
