Some TLC for my QV | Page 11 | FerrariChat
Some TLC for my QV
Discussion in 'Mondial' started by afterburner, Mar 25, 2015.
  1. JLF
    JLF Formula 3
    Sep 8, 2009
    1,708
    What method do you use to clean the wiring?
  2. ronfrohock
    ronfrohock F1 Rookie
    4,174
    MA
    Ron Frohock
    Honestly, I wish I had half the skill set that you have. Your work is remarkable. I continue to be in awe!
  3. afterburner
    afterburner F1 Rookie
    3,498
    Switzerland
    Urs STEMMLER
    Magic.
    Mostly lacquer thinner. On many wiring looms, there are hand-striped wires included (I love that - it doesn't get more hand-made than that). Those cannot be cleaned with thinner as the paint comes right off. So other solvents need to be used - or as in some cases, I just re-striped the wires after cleaning.
    The grey wire I replaced in the above example was clearly hand marked - which I did as well. Doesn't get more original than that! More samples later on.
  4. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    Thanks Ron!
  5. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    The next series of photos tells the restoration story of the trunk liners and heat insulation - which works perfectly once it's back to original. No heat soak in the trunk. Zero. Amazing. However, some of the molded panels were originally too large to fit and the only way to make them go in was obviously with force, which led to them being in bad shape, needing a lot of work and finally, much cutting down to make them fit. They do fit quite well once adjusted to the correct dimensions.
    LH wheel arch cover - FRP, and in almost perfect condition once cleaned up, hole is for emergency release handle of the engine bonnet. Carpet needed re-glueing and trimming in the corners to avoid additional thickness:
    LH quarter panel trim (covering the sunroof motor) - FRP with cracks:
    FRP repairs are easy
    Done
  6. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    RH wheel well cover with passages for the electric antenna - molded plastic with integrated "carpet" - cracked in many location, stained:
    repairs with superglue
    afterwards
    RH quarter panel trim - molded plastic with integrated "carpet" - totally broken because it was, as I found out later, over 30mm too large in some areas for the actual space available = not trimmed at the factory, but just shoved in:
  7. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    initial repairs with superglue
    re-inforced with a thin layer of glassfibre - it does bond but not extremely well. The molded plastic is sort of "greasy" on the surface
    The result is perfectly presentable for a trunk liner
    The two rear panels with tail lamp access covers were in sorry state, again due to their excessive size. Once trimmed during the re-installation process, they fit surprisingly well. But much work was required till that point.
    LH side
    Many attempts to fit them...
    Due the wrong initial placement, the trunk illumination holes were misplaced and corrected as well:
    Superglue repairs
  8. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    Finally, as good as new. Behind that liner is a FRP cover acting as a heat shield - covered in asbestos??
    That had to come off:
    Also, lots of metal inserts for fixing the liner and trunk floor - all corroded badly with the resulting expansion and destruction of the FRP.
    Front side paint had to come off, but safeguarding the hand-written original part number tape:
  9. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    Part cleaned and ready for repairs
    After lots of FRP work, and equipped with new aluminum inserts - holes not drilled yet, waiting for their positions during the installation of the liner:
    Carefully repainted around the original markings:
    The heat shield was recreated with alloy covered glass fibre mat - 2 layers to get to the same thickness as the original packing:
    All the edges were taped up with aluminium tape so no loose glass fibres can escape
    ellum and Mike Morrissey like this.
  10. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    The trunk floor pack (heat protection from the exhaust) is composed of a
    1" thick glass fibre mat
    floating FRP plate
    trunk floor board with "asbestos":
    undersides:
    Same issue with inserts
    Step one was the removal of whatever that was:
    and the paint on the fibre glass parts
  11. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    JLF likes this.
  12. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    One of the trickier parts to restore turned out to be the battery cover, in bad overall condition and as it turned out, similarly to the trunk liner parts, way too large to actually fit - which lead to some of its damage. As removed:
    too many rivets there... previous repairs
    disassembly
    "insert"... note the 3rd hole that doesn't really go through the insert...
    First I cleaned up the washer tank bracket:
  13. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    Which turned out to be heavily corroded but structurally still sound:
    repainted with zink paint and ready
    Next removal of all of those rivets - original and supplemental ones
    Both FRP parts cleaned for damage assessment
    FRP repairs
  14. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    Front panel repaired
    Base panel repaired and ready for new, reproduced insert (as for the trunk liner inserts, I chose to make them in aluminium to prevent future corrosion)
    new insert before lamination
    fitted and ready for paint
    parts painted and ready for reassembly - only original rivet holes redrilled:
  15. afterburner
    3,498
    Switzerland
    Urs STEMMLER
  16. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,740
    Argent/Brasil
    Guido
    Urs, you are a real inspiration for all of us ! Thanks and keep this good work going.
  17. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    Thanks for your comments, appreciate it.
  18. afterburner
    3,498
    Switzerland
    Urs STEMMLER
  19. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    Damage-repaired area at the bottom of the wheel well - badly done, almost 1/2" think in certain spots
    This is not fixable, so I decided to rebuild the area. Zone removed:
    Mold with the "hopefully" same curvature taken nearby:
    plaster poured
    mould removed
    resulting insert:
    Insert positioned and glass fibre mats prepared
    Dining tables are useful!
  20. afterburner
    3,498
    Switzerland
    Urs STEMMLER
    Hand-lay up:
    View from the inside with insert removed
    Sanded to basic shape
    Filler applied to get back to the original surface finish - and missing drain hole marked
    Repair done
    Edge repairs
    Rear section ready for paint, some more areas needed repairs as seen with the yellow zones:
