Some TLC for my QV | Page 12 | FerrariChat
Some TLC for my QV
Discussion in 'Mondial' started by afterburner, Mar 25, 2015.
  1. afterburner
    afterburner F1 Rookie
    3,513
    Switzerland
    Urs STEMMLER
    Front section clean-up and repairs. Note the two humps for clearance of the radiator fan motors and the inclined surfaces fading of the side/rear of the car. This is an exit air guide guiding the air sidewise away from the centre section, which has blocked exit on the bonnet.
    This deviates the air away from the centreline section of the car and over the front wing, helping reduce front end lift.
    Battery-cover side repairs
    Some holes needed to be filled and cracks repaired
    Parts painted
  2. ronfrohock
    ronfrohock F1 Rookie
    4,181
    MA
    Ron Frohock
  3. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  4. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  5. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  6. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    HVAC restoration - the elephant in the room > heater leaking, fresh air flap inop... and what else once it's opened up? Here how it looked removed:
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    The fan motor looks tired - and see the rust...
    Heater core has badly leaked. My guess is that some cheapskate used water instead of proper coolant...bust tubes:
    drain plate inside the housing has corroded away
  7. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  8. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    The exit flap is in metal - the foam gone
    cleaned up and foam cut
    done
    Replacement heater core as removed - lots of bent/blocked fins, pressure tests ok
    There is a foam sealer strip on the top front edge:
    Cleaned up and masked:
    repainted end plates with zinc paint and all fins straightened and cleaned out, new rubber gasket
  9. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  10. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  11. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Core pack fitted to housing base
    Fan assembly - new motor, old drums and rubber dampers. Rivets had be drilled open and need replacement with bolts.
    there's a grommet at the cable passage:
    new motor's cable were shorter than original - lengthened and original colors used at the plug side so it turns the right way round...
    Fan assembly completed
    and fitted to the base
  12. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    There is an inconvenient wiring setup for the evaporator temp sensor, which goes directly from the relay set through the top housing:
    This means you need to have those relays dangling with the top housing. Very impractical for assembly and potential trouble shooting.
    I added a plug (yes, another potential source of trouble) but really convenient for reassembling the HVAC and refitting it to the car:
    Now, the relay set can be fitted once the rest is in place - no ripping cables out while fitting the HVAC. Sensor testing while it's convenient:
    Checks out fine. Bleed air sensor:
    So reassembly continues with the exit air section; parts ready:
    completed, with previously restored power transistor and checked vacuum actuator
  13. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Top section with intake flaps is next. Those flaps have surrounding gaskets which were broken:
    Cleaned up and new gaskets made
    Parts ready, with brackets repainted and vacuum actuators checked
    Assembled top section
    Note the little centre stop that prevents the fresh air flap from completely closing - it will always allow a minimal external air enter the car even when AC is selected (internal air circulation)
    Hypoxia prevention???
  14. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Final assembly of the unit's top and bottom sections include a bead of Seal'n'Peel on all touching interfaces, which do have a groove and tongue section, to prevent air leaks and rattles:
    That includes the external footwell outlets - and don't forget to connect and route the vacuum hoses. Easy now, a pain later:
    Evaporator sensor gets sealed in too
    I built a water tap vacuum pump to test the flaps via the centre console control box before installing it into the car
    It all worked perfectly.
    That's what your control box should show electrically:
  15. 2cam
    2cam Formula Junior
    Aug 28, 2014
    751
    Austin, Texas
    MikeS
    I'm continually impressed by your commitment to the project and ability! VERY cool!
    2cam
  16. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Thanks Mike! More to come :cool: till the car is back on the road.
  17. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Main wiring loom restoration - front fire wall to centre tunnel - engine bay - trunk. As removed:
    Some detail shots:
    Rock-hard sheaths, oil, tape ....
    All cleared sections secured with cable ties to keep the junctions correctly located
    engine bay connectors...
    all removed
    cleaning
    before/after
    re-color coding after cleaning
  18. stoked_7
    stoked_7 Karting
    234
    Fantastic work, can't wait until you have this back on the road.
    What paint are you using for the black interior plastics like the pedal cover you repainted?
  19. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Ignition multi-plugs cleaning and re-insulation on damaged zones
    retaped and ready
    Next lower engine bay wiring loom cleaned - main power supply bypass visible:
    retaped
    Upper engine bay loom as removed
    Some damage detail - often caused by hardened sheathing and dried out rubber boots
