Some TLC for my QV | Page 13 | FerrariChat
Some TLC for my QV
Discussion in 'Mondial' started by afterburner, Mar 25, 2015.
  1. afterburner
    afterburner F1 Rookie
    3,513
    Switzerland
    Urs STEMMLER
  2. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Thanks - Nippon Paint Flat Black
  3. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,765
    Argent/Brasil
    Guido
    My seats adjustment handles have a leather strap wrapped around it.
  4. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Posh! Picture please :D
  5. theunissenguido
    Jan 21, 2004
    2,765
    Argent/Brasil
    Guido
    By looking closer seems to be some rubber stuf that looks like leather. I believe I already put an extra layer on the passenger side years ago, but you can see the original stuf where the blue ribbon is. The other side is still oem....I think...I'm not sure this is original. Some other owners have to confirm...
    Have to do something about that look !!.Me to I'm working on the car. I went to the MOT and 2 employees did beat with a pick hamer under the car until they punched a hole in the bodem. So I need to remove all interior to get that fixed.
  6. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Oh no...where is the corrosion?
  7. ronfrohock
    ronfrohock F1 Rookie
    4,181
    MA
    Ron Frohock
    Does anyone else fear the end of this thread?
    I hope we don’t need to quit this cold turkey....
    afterburner likes this.
  8. JLF
    JLF Formula 3
    Sep 8, 2009
    1,711
    I want to see the first start and drive video and a good walk around.
  9. ronfrohock
    4,181
    MA
    Ron Frohock
  10. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    The front coolant pipe delivering to the radiator showed severe corrosion in the areas below the rubber hoses:
    A replacement hose was ordered but despite being the correct one according to the book, it clearly wasn't and it didn't fit.
    What I needed nobody had for sale... so the wrong pipe was cut up to fix the correct pipe
    like that:
    Since only straight pipes at the end were cut, no angular issues would arise
    The welder did a great job!
    One of the smaller engine-side tubes was in good condition, it was cleaned up and painted:
  11. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    and... same story with the radiator exit pipe! Cleaning it up revealed an amazing state of corrosion - and my car didn't leak coolant at any measurable rate before
    Oh dear... heater water return flange:
    That needed a new part
    Both done
    and the new centre tunnel hoses ready
  12. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Exhaust hangers
    Chemical cleaning
    and replated:
    The steering wheel had suffered badly from the storage issue as well:
    I used ColorPlus cleaner, conditioner and redyed it black - carefully avoiding the white stitching. The result is perfect - thanks Joanne for your superb products and friendly advice!
    moysiuan and Eddie.h like this.
  13. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Centre console inserts - newly trimmed:
    Cassette storage cover
    Foam insert to stop cassettes from rattling - but rattling is part of it, isn't it??
    Refitted
    Hazard Switch needed attention
    Cleaned up and matt repainted translucent top, assembly with plastic grease
    assembled - clean now
    new self-made symbol applied
  14. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    rear passenger storage box - re-application of original internal felt on original backing plate - note the lovely round hole for passing the trunk emergency handle...
    assembly with pop-rivets
    Done - I love the interior color!
    Check control display - the frame had a dent and the screen was scratched
    Dent
    filled
    repainted
    screen painted matt so it doesn't reflect
    Eddie.h likes this.
  15. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    One of the 3 bulbs behind the green/amber/red fields was broken - those are to my knowledge "home-made" by Ferrari: A 1.2W bulb on an extension. Can you spot the discontinuity?
    Disassembly
    The standard bulb is crimped onto the custom support to lift the bulb closer to the surface
    I carefully opened up the brass tubes so they can be reused:
    and re-crimped the new bulb on the existing support
    and soldered it in place - it works
    some of the black condensers were bulging so I replaced all of them
    Done
  16. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    More wiring - starter motor relay - visibly got hot
    unpacked and cleaned
    retaped
    dome lights - this one was "perfect" and only needed cleaning... wonder why
    I also ran the 3rd stop light cable along the outside of the #4 - the red one for linking to the pedal switch and the small plug for the LED unit:
    Sunroof cables
    Antenna cables
    after much cleaning - as new
    original rear speaker cables - cleaned up but they were not in good condition so I redid them later. Interesting that there were cables at all:
    HVAC push button unit wires
  17. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Front end wiring as removed:
    and "naked"
    related hardware
    side repeaters restoration see post #281, but here some images along the way
    some plugs are color coded with a clip-on sleeve - like this white one for the headlights:
    The cable needed re-coding after cleaning:
    looks good when done
    damage control - previous repair left but properly insulated
  18. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    before
    after
    this still worked but...
    done
    cleaned clips and grommets - color coding with 3 yellow ones to mark the centre and sides for refitting
    restored P-clips with new rubber protections Image Unavailable, Please Login
    trigger wire for the daylight running lights (yellow/black open ended), all plugs marked:
    DONE!
  19. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Engine bay 12V socket - not restorable - I could not get the screw out by any means:
    Replacements are available
    This was the exception - it's a restoration project with the goal of retaining the maximum of original parts:
    Alternator main lead and ground strap
    "silicon" hose plus heat protection hose
    cleanup and new protections
    Done
  20. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Centre console wiring - sheathing still soft! Only cleaning needed...as removed
    and cleaned and checked - all well:
    Main loom from the fusebox to the dashboard
    Some impressions - you can guess how much work was needed on this one:
    lots of sheathing had to come off - hard stuff
  21. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  22. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    AC condenser fan heat switch as removed
    cleaned up and clip repainted
    Negative Terminal Switch
    cleaned and ready
    I also filled the "instructions" with white paint - easy to see in the dark frunk
    Brake pad wear warning light circuit with some badly corroded plugs that needed repalcement
    Done
    restored fuel filler flap solenoid
  23. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Cowl drains (below the windshield air intake - molded hoses and angle grommets going from inside the dash through the firewall
    They were luckily in excellent condition - both hoses and grommets - type and date marked
    restored and ready, incl original clamps Image Unavailable, Please Login
    HVAC drain with molded-on grommet
    cleaned up perfectly
    Heater valve to rad exit pipe molded hose with grommet
    very good condition too - no image of it cleaned up but that's the shape of it.
    Here the wiring of the DRL:
    And here the additional loom that powers, via a small fuse box, the window relays, the blinker relay, the DRL and the electric power steering:
    It draws power from the battery and distributes it via a bus bar to the various users, nicely labeled cover, spare position for later
    It's positioned on the rh front wheel arch and the wiring goes into the dashboard via an existing opening.
