Some TLC for my QV | Page 14 | FerrariChat
Some TLC for my QV
Discussion in 'Mondial' started by afterburner, Mar 25, 2015.
  1. afterburner
    afterburner F1 Rookie
    3,513
    Switzerland
    Urs STEMMLER
    Seat Belt restoration, first lower front sill return mechanism (to get it out of the way for rear pax entry)
    rust free
    repainted
    Belts got washed and thoroughly dried
    worth it....
    Rear belt reels had corroded supports
    Belt pulled out and blocked for cleaning and rust removal:
    cleaned up and masked
  2. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    painted rear belt reel brackets - looks new and will be invisible when refitted :D
    rear seat belts ready incl. trim
    and assembled
    front seat belts ready
    Heater valve restoration:
    cleaned
    Internals
    Reassembled and arrows marked - helps when fitting all pipes...
    more parts restored - amazing how many p-clips there are on one car
  3. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  4. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  5. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    HVAC vacuum tank and associated hoses - the check valve is missing and was replaced with a straight pipe connection!
    paint removed from tank revealed rust...
    sand blasting after careful masking:
    repainted:
    rust protection applied
    check valve bought:
  6. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  7. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    All parts cleaned and housing repainted
    Old and new reverse lock spring and ball joint cup - it wasn't worn/necessary to change but I only knew after I removed it
    New gear shift bushings - necessary!
    spring compressed for refitting
    Reassembled
    with repainted internal housing
  8. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Ignition ECU Restoration - as removed on the left, nut-shell blasted on the right
    blasted
    opened up - 1 bolt broke and needed careful extraction...
    housing masked and ready for paint
    and painted and new labels created
    Inside cleaned up as well
    assembly with sealant - the cardboard gaskets did look a bit tired
    reassembled
    With vacuum hose and bracket
  9. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  10. greatscott73
    greatscott73 Formula Junior
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    I'm printing off every page of this thread and making a binder. I may never have to open the service manual again.
    ronfrohock likes this.
  11. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  12. ronfrohock
    ronfrohock F1 Rookie
    4,181
    MA
    Ron Frohock
    It’s interesting to go back to page one to see how innocently this project started.
    I’d love to know the back story in this car. Where did you did you find it and what condition is was in.
  13. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    I found it locally, it was registered but other than shiny paint in pretty bad shape overall. However it ran and I gradually repaired, completed and improved all items I was able to do myself and in parallel had an independent service centre take care of the necessary mechanical work so I could use the car on a daily basis. That worked for 10 years but then the combination of 2 cracked windshields, fairly serious corrosion on the lower body work and a big service combined forced the decision of abandon or redo.
    It's hard to sell your family dog...
    ronfrohock, JLF and Eddie.h like this.
  14. Eddie.h
    Eddie.h Karting
    209
    Hillsborough, NC
    Ed
    Very true on the hard to sell. I have a 67 MG Midget that I bought in 1974, 3 different colors and would not start. Looks like my 83 Mondial is on the same path (I now have two “family dogs”). Thanks for all the photos and inspiration.
  15. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Pleasure Ed. Please share a picture of your MG - secret MG fan here!
  16. Eddie.h
    Eddie.h Karting
    209
    Hillsborough, NC
    Ed
    #343 Eddie.h, Jun 1, 2021
    JLF likes this.
  17. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Thanks! I have been in a Midget twice and found them admirable.
  18. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    RHD gas pedal assembly restoration - it needs to transmit the movement across the footwell to the centre tunnel. There is cover for the torsion rod fitted to the floor pan, visible later.
    On my car, with both pedal stops at the maximum maximum, the throttle wouldn't rotate 180° = not fully open.
    I fabricated a slightly longer arm on the pedal assembly:
    and added a return spring for the pedal - in case the throttle side doesn't do its job for what ever reason. Here the hole for that spring
    The finished assembly, clean, painted, lubricated
    Fueltank vent check valve - fitted at the rh side low on the firewall near the fuel pump to prevent fuel leaking through the vent in case of a roll-over accident. It's no longer available but this one check out ok so I cleaned it up and refitted it:
  19. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  20. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Cabin temperature suction fan assembly as removed
    The sensor is a Mercedes part
    Sensor test according to the manual - ok
    If you want your HVAC to work properly, your sensors need to deliver the correct values to the ecu.
    Disassembled
    The suction fan motor housing has a BOSCH part number - the motor inside is a Johnson Electric part, made in Hongkong. I renewed the blue part, just in case
    all parts cleaned
    done
  21. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    ECU panel (HVAC, Check Control, Interior Lights Timer) behind passenger kick panel.
    The panel itself is powder coated - the leaking heater core has had its effect on it:
    actually quite pretty
    Visual check of HVAC eco internals
    courtesy lights timer
  22. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  23. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Restored ECU panel
    The original blinker relay is bolted to the firewall high up behind the dashboard and totally inaccessible. I added an extension wiring with a remote relay socket to relocate it low and accessible inside the dashboard.
    It also receives direct 12V via the supplemental fuse box, which cured the slow and dim blinker via the original wiring.
    Restored centre console fibre optics pack; big bunch for the front section, 3 lines for the rear passenger section
    Repainting of the temp and fan speed knobs
    Fan speed pot fuse:
    Fan speed "full" power transistor bypass microswitch
    Centre console front section assembly
    JLF likes this.
