Some TLC for my QV | Page 15 | FerrariChat
Some TLC for my QV
Discussion in 'Mondial' started by afterburner, Mar 25, 2015.
  1. afterburner
    afterburner F1 Rookie
    3,513
    Switzerland
    Urs STEMMLER
    Centre tunnel front cover - removable to access radio, throttle cable and everything else. On top I added the EQ bracket and a cable passage hole.
    The right side includes the left foot rest and a chromed kick panel:
    The left side has a velcro-secured carpet that reveals a removable side panel to access all the radio wiring.
    Head unit belt change - here the replacement belt
    It requires the removal of the cassette drive and cover plate:
    head and roller cleaning
    head unit
    EQ
  2. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    HiFi wiring for a 4-speaker layout - similar to the contemporary BB
    Y junction for separate power supply to the memory and head unit via the EQ
    Here we go
    The front seat belt exits in the rear quarter panels are too short to compensate the belt movements back and forth when the angle of upper belt return changes angle during usage. My belts ended up frayed around the edges and got refused at the MOT. I made new, larger exit covers:
    They are stuck with 3M automotive tape before the slot is cut
    Done
    front door shoulder panel
    mirror defroster exits
    rear ends
    Eddie.h likes this.
  3. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Eddie.h likes this.
  4. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Window Regulator Sheaves - upper set, as removed
    cleaned
    ready
    Front Bumper Side Section - They are corroded on the inside. Nothing can be really done about that, but I cleaned out all the loose bits and rust protected the rest with anti-corrosion paint where accessible and drenched it all in Dinitrol. The outside was cleaned off all the paint layers, sanded finely and protected with a black rubber bumper dressing:
    The mounting spacers looked worse than they were
    cleaned
    Front Bumper Side Section - same story but one of the spacers was missing and one of the mounting studs had corroded away, so a repair was made and the missing spacer cut from hard foam - contrary to the front, there are 2 different thicknesses:
    On the lower (rh) front attachment you can see the screwed on repair bracket. It holds up quite well.
    The outside surfaces show slight deformations from the internal corrosion but it's acceptable now that the surface is matt black natural rubber. In the longer run, I will source replacement sections but at the moment, the restored original parts will do just fine.
    It looks way better than the painted, scratched and cracked look when I bought the car. So all in all a good restoration result.
    Jeka likes this.
  5. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Headlight Motor Restoration
    One of the eyelets was hand made!
    Teardown
    Rubber caps removed - one of the emergency hand wheels was different with a hole at the top
    This is interesting - the rubber housings are marke Sx = LH and Dx = RH. However in the Mondial the Sx is fitted to the right side.
    Sometimes it pays to mark parts before you remove them. Trying to refit to the wrong side would have cause some headaches...
    Metal parts corrosion free
    Cleaned and repainted parts
    Ready
    A replacement actuator rod was eventually sourced and the eyelets used
  6. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Removable rear inner wheel arches - as removed, in pretty bad shape, with lots of underbody coatings, destroyed mounting holes, add-on metal plates to compensate, cracks, missing edges, overspray in the engine bay side etc:
    LH:
    Drain hoses clip (sunroof & filler neck)
    RH
    sunroof drain hose clip
    metal mounting holes
    all removed:
  7. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Luckily, the many layers of underbody coating and paint was very thick and came off relatively easily:
    Tons of it
    The other side's weight before stripping:
    After
    Both stripped
    To find the original shape I superimposed both and marked the common holes, note the cracks in the gel coat:
    All identified
  8. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Edge templates for repairs and redrilling - between both I was able to reconstruct the original outline and hole pattern
    Preparing the FRP work - edge feathering and removal of all rotten areas
    repairs
    repairs completed, edge trimmed and holes repositioned
    engine bay side repainted
    wheel well side recoated Image Unavailable, Please Login
    weight now
    new P-clips for the drain hoses fitted; repair complete:
  9. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Filler Neck as removed
    Cleaned - nice alloy construction Image Unavailable, Please Login
    Painted
    Cap - when it's not tightly closed, it can vibrate itself loose and the edge gets damaged by the hinge:
    The shape got corrected on the lathe (!) and I added a textured adhesive in the middle to clean up its look
    Rigid pipe between the fuel pump and pressure accumulator
    Corrosion-free
    repainted
  10. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    brake booster vacuum hose check valve as removed
    and after check, corrosion removal and repainting
    Coolant pipe P-clips
    after restoration, with new rubber sleeves
    New injectors with the wrong gaskets - those aren't the once we need on the QV:
    Intake Tube - perfect condition but very dusty
    Cleaned up
    Lots more P-clips!
    more restored
  11. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Ignition Coils
    Rust free and magnets repainted by hand
    Done, with + - marked
    more presents
    more clips
    Locally sourced hoses with samples
    centre tunnel coolant hoses
    fuel & vent hoses
    Interesting and original hose joint making up for 2 different diameter and either end (aux air valve > air filter housing)
  12. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Fixed Fuel Lines - from tank to pump
    and from accumulator to CIS and back (rh side above rear wheel)
    mechanical cleaning and checking - they are fine structurally
    chemical corrosion removal
    very nice looking afterward
    repainted and clips refitted
  13. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  14. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,767
    Argent/Brasil
    Guido
    #366 theunissenguido, Jun 5, 2021
    The metal part of the coil ( you painted it black) is ocher colored original. Between brown and red. Model looks a bit different on Euro cars.
  15. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Yes and didn't have the right color at the time - those are actually FIAT coils I bought a few years ago and they were black. I will repaint that in the future one day.
    theunissenguido likes this.
  16. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    CIS Restoration - fuel metering unit, WUR, Aux Air Valve and Cold Start Injector were rebuilt and calibrated:
    Cold start injector and Aux air valve repaint:
    Rebuilt and tested WUR - I have requested my own, not an exchange
    Fuel metering unit - same here, mine rebuilt
    all ready
    FerrariJB likes this.
  17. JLF
    JLF Formula 3
    Sep 8, 2009
    1,712
  18. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    There is a hardware shop in Mongkok that sells stainless steel P-clips with the correct section of sleeves. I bought a bunch of them just for the rubber sleeves.
    JLF likes this.
  19. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  20. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Lower half ready incl. new gasket Image Unavailable, Please Login Image Unavailable, Please Login
    Upper Section - die cast Bosch part - teardown. Back-fire rubber stop with increasing resistance:
    The hinge axis is lateral play compensated with a spring.
    Other side
    Roll-over Safety Switch
    Cleaned
    Metering plate refitted
  21. greatscott73
    greatscott73 Formula Junior
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    In case you aren't planning a trip to Mongkok in the near future,I have purchased the entire clamp assembly at McMaster-Carr. Look under "loop clamps."
    afterburner likes this.
