Some TLC for my QV | Page 16 | FerrariChat
Some TLC for my QV
Discussion in 'Mondial' started by afterburner, Mar 25, 2015.
  1. JLF
    JLF Formula 3
    Sep 8, 2009
    1,712
  2. afterburner
    afterburner F1 Rookie
    3,513
    Switzerland
    Urs STEMMLER
  3. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Firewall main heat shield - aluminium, 2-part construction, bent, oversprayed, corroded, damaged:
    small angled section
    main panel
    Broken engine mounts = displaced engine = contact damage. Panel flattened:
    Damage repair:
    Repainted with high-heat paint
    Reassembled
    Potential repro job in the future, but fully functional for the time being.
  4. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  5. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  6. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    .... more storage damage, evidence of damp and hot weather:
    luckily only superficial:
    I added a helper relay to power the ac clutch to relieve the current on the integrated mini relay of the ecu. It also cuts the ac compressor during cranking as it received power from the permanent pin of the starter relay:
    previous proof-of-concept wiring (runs from the coils across the firewall to the compressor):
    final version:
    ... markings help while you are in there...
    this setup works very well for both the starter (no more non-starting events) and the ac (no more burned out ecu relay).
    In case someone wants to add the starter motor relay:
  7. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  8. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    for later - that color code matches the original color of the beige handles quite well - checked in the parts inside the headliner that never saw sun:
    and a very useful selection of tools...
    final version of the glove-box wiring with detachable USB socket for servicing without removal of anything else:
    oil cooler clean-up and fins straightening:
    after
    masked
    ready
  9. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  10. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    New Brake Master - externally a rather rough part...
    New battery - this is the correct type:
    That's what I got:
    Correct AC compressor oil for R134a converted Sanden compressors
    New hi-lo pressure switch
    Missing rim centering studs replacements arrived
    These H2 bulbs (front fog/add hi beams) are NOT known in Hongkong - nobody sells them:
  11. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    AC compressor restoration (more storage damage...) - looks ok-ish from the outside and was fully functional when removed:
    pipe cleanup
    masking
    repainted and generally cleaned Image Unavailable, Please Login
    oil change - some residue
    for the record - ± 90grams retrieved
    New full charge according to the book
    Here we go
  12. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Decision to pull the head and have a look... new gaskets ordered
    luckily the correct size was supplied... there are two but the suppliers don't indicate which one they supply... so the valve cover comes off:
    corrosion on the valve plate... residue in the oil!
    and in the valve cover
    surface corrosion only
    head removal - all very oily, which is good
    but some corrosion in some cylinders and on top of some pistons
    head piston side with valves:
    But it cleans up nicely Image Unavailable, Please Login
  13. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Cylinder and Piston clean-up - there is a lot of play in this so I am not worried about the very slight pitting at the moment:
    Reassembly with clean parts and lots of oil - head gasket re-used as none was supplied
    valve plate re-installed - it's indexed
    new valve cover gasket
    Done - torquing really slowly to avoid compressing air in the bolt holes and fracturing the block - wiggle the bolts, 1/4 turn, wiggle etc, one by one. Done, ready for installation
    So, this is an original Sankyo compressor!
  14. greatscott73
    greatscott73 Formula Junior
    Sep 1, 2017
    458
    Eastern Tennessee
    Howard Scott
    I'm curious if you changed out the front shaft seal as well. Mine is leaking and will need that done as soon as I can get to it.
  15. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    ... no, I didn't... but now you mention it... well, it's not leaking (yet) :D
  16. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  17. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Headlamp Restoration - as removed
    1 missing dust cap!
    Hi-lo beam
    Hi-beam with adapter:
    Fossil inside
    Disassembly:
    Retaining springs:
    Adjustment screws - some aren't recoverable due to stripped cross slot
    Nut cages in spring steel - nuts in plastic and stripped - no adjustment possible
    Headlight wiring looms
  18. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Chrome lens retainers cleaned up - front clean, rear as removed
    Retapping the base frame
    Wiring looms cleaned up
    Springs cleaned up
    Adjustment screws re-manufactured
    Metal parts chemical corrosion removal
    Successful
    Frames repainted
    Masks repainted
    Standard nuts fit the cages
  19. afterburner
    3,513
    Switzerland
    Urs STEMMLER
  20. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    ... when the HT leads return this type of resistance, it's time to replace them - missing sparks a lower revs etc:
    All the extenders checked out normal (basically 0 resistance) and visual inspections showed no signs of any issue. New parts:
    1 damaged end:
    repaired
    and refitted to the caps:
    Results incl. resistors (cap to sparkplug)
    Prepping
    Installed:
    and then this: NOS aerial doesn't deploy all 5 segments!
  21. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Dashboard Restoration - first a backside shot as removed for future reference
    Instruments, warning lights and switches removal
    Defroster outlets:
    Side vent outlet removal with home-made special tool (welding rod...)
    Centre support (below windshield edge)
    Cabin air temp sensor and suction pump
    Lateral face level vent frames - 1 side missing a screw since new...? Image Unavailable, Please Login Image Unavailable, Please Login
    Glove box removal
  22. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Glove box flap removal
    Side vent duct mount and suction motor mount will remain Image Unavailable, Please Login
    View around the air distribution and IP corner - quite tight
    dash mount in the corners will remain as well
    Zoom on the assembly screws between the upper and lower dash sections
    Disassembled - note the modified washers so they fit into the tight areas
    IP pod removed
  23. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Lower dashboard mounting brackets painted black
    Centre vent "fix" - it had a tendency to pop out aver time:
    Covered up:
    The defroster air distribution air channel had become lose: Image Unavailable, Please Login
    Removed and cleaned up
    Refitted with industrial-grade PU adhesive
    Done
    It really does rigidify the upper part of the dash!
  24. afterburner
    3,513
    Switzerland
    Urs STEMMLER
    Fitting the instrument cluster with a spacer to change it's angle towards the driver's line of vision:
    Original cluster mounting point were broken:
    Cluster fitted with spacer:
    New gap filled with trimmed piece - that's how much tilted the cluster now is:
    MvT likes this.
